April 21, 2026, 07:07:54 19:07
Author Topic: int_ext PIC18F4553  (Read 9550 times)
bird777
« on: October 20, 2009, 12:57:48 12:57 »
Could anybody help me why do this some line the following:
The input is being pulled up and when I push the button than it pull down the input. I wanted to do that when I push the button than write out the "++" and when I leave it than write out the "__", but it do the following:
When I push the button the controller write out the "++" and when I push it again than write out the "__" only. I had have written already some prog but I can not understand why do it this?! Smiley
#int_ext
void RB0_megszakitas(void)
   if(!button_pressed)        // if button action and was not pressed
      button_pressed = 1;    // the button is now down
      ext_int_edge(L_TO_H);   // change so interrupts on release
      printf("\r\n++\r\n");
   else                       // if button action and was pressed
      button_pressed = 0;   // the button is now up
      ext_int_edge(H_TO_L);   // change so interrupts on press
      printf("\r\n__\r\n");
ALLPIC
-Receive: 72
« Reply #1 on: October 20, 2009, 03:52:03 15:52 »
simple do some think like this......
unsigned char edge;
#int_ext
   if(edge == 1)        // if button action and was not pressed
void main(void)
...... do init
edge = 0;
make GE = 1;
Posted on: October 20, 2009, 04:50:24 16:50 - Automerged
sorry previous somethin missing....
unsigned char edge;
#int_ext
      edge = 0;
      edge = 1;
void main(void)
...... do init
edge = 0;
make GE = 1;
sam_des
-Given: 138
-Receive: 161
« Reply #2 on: October 20, 2009, 06:41:41 18:41 »
Hello bird777,
I don't know what your program's actual purpose is, but I may suggest you that it is generally bad idea to use 'printf()' (or any other compiler's run-time library which makes call to function) in interrupt functions. printf() family functions usually use some statically allocated ram to parse their inputs. If you're using printf() in interrupt as well as in mainline, these static data may get corrupted, resulting in bugs which are hard to reproduce & correct.
That's why you must consult compiler manual to check if the function is re-entrant or not and I think printf() is not usually reentrant.
Hope that helps...
regrads,
sam_des
bird777
« Reply #3 on: October 21, 2009, 06:26:29 06:26 »
ALLPIC:
Thank you for your answer, but I do not understand what is the different between your lines and my line?! Smiley
sam_des:
Thank you, too, but here does not matter the pintf, I wrote there something only.
caveman508
-Given: 12
READ, REAd, REad, Read
« Reply #4 on: November 10, 2009, 07:15:02 07:15 »
Hate to jump on you.
Servicing a push button with this type of Interrupt Service Routine (ISR) is just a mistake.  Think about how many times it is referred to in a single push... Did you de-bounce the switch in hardware?Huh
I think you are not SEEING the point of what Sam is saying.
You are not listening, you are not following the rule of interrupts.  "Do very little in an interrupt"
Think about it, , how many edges does a switch make on a push or release?Huh  What is your baud rate???  How long does printf take to get a string out?Huh?  FAR LONGER than that switch will bounce ON-OFF-ON.  That my friend, is what Sam was talking about, , , Re-entrance........ big problems.
Set flags for the 'main' code to deal with.
NEVER CALL A FUNCTION IN AN INTERRUPT
NEVER
If you do, you will learn quick.  Or, , , you will be asking why it doesn't work, , , or complain it is the compilers fault.
Try the whole thing in assembly, write the whole thing and see, again, it doesn't work to do much of anything in an INTERRUPT routine.  Learn the golden rule, , just set flags, don't do anything that takes any time to speak of with respect to the rate of incoming interrupts.  The ENTIRE ISR needs to be done in less time than the expected rate of interrupts, by maybe 50%.  Otherwise, , when will the non-interrupt code run?Huh
Please listen to help,  the help given is correct, a great collection of minds from great people are here, helping you.  Your mind learns better when you are not on the defense.
Think like a chip in these cases, the devil lurks in the details.  Think like the robot you program, what does it see, how will it re-act???
Happy days
Caveman
