April 21, 2026, 10:37:05 22:37
Author Topic: MiWi P2P (Question)  (Read 6568 times)
niktesla
-Given: 166
-Receive: 280
« on: September 26, 2009, 03:32:32 15:32 »
I'm trying to learn a bit about the protocol and downloaded the MiWi AN1204 Microchip's Web site and downloaded the MiWi P2P stack, after installing I found there was already an example that is nothing more than an LED light via wirelles.
I mounted the project and i got the headaches, because it was with several errors like syntax and others.
Someone already tried to run this example, if so could you help me?
Niktesla
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en536181
ALLPIC
-Receive: 72
« Reply #1 on: September 28, 2009, 04:07:34 04:07 »
I used this code for lot of time. there is not problem in code there might be problem in your project dir. Please check build option for include path. that might solve your problem
