April 29, 2026, 11:38:32 11:38
Author Topic: PCB design considerations?  (Read 5374 times)
walido81
« on: September 09, 2009, 03:45:54 15:45 »
Dear Friends,
Nice day for all of you…
I'm interested in PCB (printed circuit board) design; actually I'm looking for the following details:
-Multi-layer PCB design considerations.
--Deferential Paris design consideration and calculation.
---EMI and EMC design considerations.
----Any related information…
Please advise any article, book, video and tutorial can help in this field!
By the way, does anyone agree to use 'Altium Designer' for small PCB projects? I have been using Eagle for 5 years.
Thanks in advance!
-Given: 582
« Reply #1 on: September 09, 2009, 07:26:43 19:26 »
I sue Altium all the time and would never use any thing esle, I think it is the best.
EMI and EMC design considerations woudl be double sisded and all the GND connections bottom layer only and non on top, I think if you do a search on here you will find some books about PCB and stuff, also do a search on google about it, There plenty of info out there it takes years of practice,
I wll try and try find a bit more info on the subject. I never use the auto router I find manual route is the best
This is someting that I found for you some good pointers in there has you can see there is lots to it and to think about
To become a professional in PCB one should have Good knowledge on the following points :
1.Drawing Schematics in different tools/pkgs (ALtium,PADS, Allegro,..etc)
2.Understanding the errors and procedure of rectifications
3.Board Details understanding
4.Datasheet understanding for footprint creation
5.Footprint Creation
6.Assigning Footprints and linking to the board layout
7.generating Netlist,BOM for different tools
8.General guidelines of layout
9.Placement of Analog ,digital and Mixed signals
10.Pre simulation
11.Adding comstraints for signals
12.Routing techniques
13.Differential and Impedance control
14.stackup upto min 6layers
15.post simulation ( hyperlynx)
16.micro strip and strip line
17.PCI CARD, MOTHER card boards
18.Generation of gerber
19.Verfication Using CAM or Gc prevue or similar to these
20.knowledge on generated files
21.manufacture process
22.Cost of Routing
23.Assembly process
24.Reflow and wave solder
25.Application of the board (used in Land or Air or water)
26.Checklists for Footprint creation,Inputs to pcb designer ,schematic,final pcb ,gerber and documents
once you have good knowledge on the above all ,try to get IPC Designer Certification - CID
« Last Edit: September 09, 2009, 07:39:09 19:39 by Wizpic » Logged
