April 29, 2026, 12:30:27 12:30
Author Topic: RTC DS3232 Time,date and temperature  (Read 5351 times)
smainj
-Given: 70
-Receive: 75
« on: September 06, 2009, 03:52:43 15:52 »
i wanna read the time from DS3232 with mikroC compiler
with I²C Library use MSSP module in PIC don't work (RTC_DS3232_2.hex)
with Software I2C library work fine (RTC_DS3232.hex)
pls anyone can resolve this problem thank you
 Undecided
« Last Edit: September 07, 2009, 03:29:17 15:29 by smainj » Logged
bajrang
-Given: 245
-Receive: 79
« Reply #1 on: September 07, 2009, 04:30:26 04:30 »
Dear smainj,
Instead of analog resistors for pulling up SDA and SCL  lines just use pull-up category resistors in proteus. Your problem should be solved.
riteshjain_82
-Given: 31
-Receive: 33
« Reply #2 on: September 07, 2009, 07:51:46 07:51 »
or by just remove these resistor it works fine
smainj
-Given: 70
-Receive: 75
« Reply #3 on: September 07, 2009, 10:28:06 10:28 »
@ bajrang
it is OK
@ riteshjain_82
don't work
thank you dear friend Smiley
« Last Edit: September 07, 2009, 10:34:46 10:34 by smainj » Logged
smainj
-Given: 70
-Receive: 75
« Reply #4 on: September 07, 2009, 03:33:22 15:33 »
Full project
compiler mikroC
display time , date , temperature
