April 29, 2026, 08:20:35 08:20
Author Topic: X10 interface  (Read 9432 times)
jibun24
« on: November 10, 2005, 05:48:09 17:48 »
Hi everybody,
I would like to add a X10 interface to my project with 18F452.
Somebody know where I can find X10 interface drawing (principaly the link with 220v) ?
Thank in advance
Jibun24
Lumos
-Given: 74
« Reply #1 on: November 24, 2005, 05:49:10 17:49 »
hi jibun24
the HCPL800j from agilent is a powerlinemodem and good for your project.
i also will use this one.
best regards
www.freescale.com/files/ftf_2005/ doc/reports_presentations/ZBA302_WU.pdf
« Last Edit: November 24, 2005, 06:26:58 18:26 by Lumos » Logged
jibun24
« Reply #2 on: November 24, 2005, 08:27:27 20:27 »
Thank you LUMOS for this information. The link is bad but the problem was a space between the word "doc". This document is very interresting.
I found also on internet a lot of informations about X10 sytem. I found a module for communicate with a PLC or any system with TTL level. This module is XM10E (E for Europe, 230V model), this module is also called (TW7223).
Jibun24
Lumos
-Given: 74
« Reply #3 on: November 25, 2005, 07:30:26 07:30 »
hi jibun24
why so many spend money?
proton (my favorite) or picbasic have got wonderful x10 possibilities and
"proteus" as a schematicplatform is a common development with "PIC" in a very interesting way.
best regards
jibun24
« Reply #4 on: November 25, 2005, 06:09:36 18:09 »
Hi Lumos,
Proton and proteus are also my favorite softwares. So I am waiting the Full PDS 3 for use with PIC 18F series. I use now Proton 2.2 beta8 but it have a lot of bugs.
My project is now about  2300 lines with PIC 18F452 (70% flash used) and all simulate with proteus and also with hardware. Now for finish my project I want to add X10 command for drives my house shutter.
I use Proteus since version 5.xx and Proton since version 2.13.
I try other basic like Picbasic Pro, Mikrobasic but for me the best is Proton.
Best regards
Lumos
-Given: 74
« Reply #5 on: November 25, 2005, 11:00:19 23:00 »
hi
with 2300 lines is mixes a whole begin.
my home control works with the "rs485" bus and a 18 f252 as a master with 760 lines.
it is 10 slaves . (weather station, parallel display, relay constituents ...) at the moment
I didn't want to use x10 directly because with "bytecommands" feels better.
« Last Edit: November 25, 2005, 11:06:50 23:06 by Lumos » Logged
Lumos
-Given: 74
« Reply #6 on: November 25, 2005, 11:03:46 23:03 »
hi
I didn't want to use X10 directly because with "bytecommands" feels better.
Lumos
-Given: 74
« Reply #7 on: November 25, 2005, 11:04:40 23:04 »
hi
Lumos
-Given: 74
« Reply #8 on: November 27, 2005, 09:57:45 09:57 »
hi jibun24
what is like your opinion on the scheme (not the beauty Smiley)
Rx-Power Filter: 50Hz
Tx Freq: ~120kHz
Schematic from Charlie Wu and HCPL800 Datasheets
« Last Edit: November 27, 2005, 02:59:11 14:59 by Lumos » Logged
koky
-Given: 171
-Receive: 157
« Reply #9 on: November 28, 2005, 07:01:46 07:01 »
here there are schematich with ST7537HS1
http://xoomer.virgilio.it/lorix/pdf/05.003.001.pdf
2400bps plm
jibun24
« Reply #10 on: November 30, 2005, 08:46:45 20:46 »
Hi Lumos and Koky,
thank you for your informations.
To Lumos, your drawing is very interesting, in first by the power supply and I have a question about it. How much current (mA) the 7805 is able to delivery ?
Jibun24
Lumos
-Given: 74
« Reply #11 on: December 01, 2005, 03:59:19 15:59 »
7805 = 1A
78M05 = 500mA
78L05 = 150mA
the "L" type suffices completely primary sided.
at the layout the separation from net side and processor side is important.
« Last Edit: December 02, 2005, 04:09:55 04:09 by Lumos » Logged
Sanjuro
-Given: 39
-Receive: 79
« Reply #12 on: December 10, 2005, 05:07:54 17:07 »
X10? You should search Microchip application notes. Look at this app:
- http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en012050
Or more directly:
- http://ww1.microchip.com/downloads/en/AppNotes/00236a.pdf
- http://ww1.microchip.com/downloads/en/AppNotes/an236.zip
Chara
« Reply #13 on: January 07, 2008, 10:26:52 22:26 »
you can find Circuit diagrams of X10 devices here:
http://www.hansotten.com/x10circuits.html
memed500
« Reply #14 on: January 10, 2008, 12:26:52 12:26 »
http://www.edcheung.com/awards/pic2k/c0700cw2.htm
http://www.x10faq.com/section1.htm
