April 19, 2026, 04:05:14 16:05
Author Topic: Segger J-Link ARM + Keygen  (Read 39067 times)
sfabris
-Given: 8
-Receive: 23
« on: June 07, 2009, 01:15:25 01:15 »
You can find the software at usual place:
http://www.segger.com/downloads.html
Keygen:
http://ifile.it/ehlgzko
Tested and working.
sf
samir_1982
 Warned
-Given: 30
-Receive: 76
« Reply #1 on: June 24, 2009, 07:45:49 19:45 »
Plz reuplaod keygen
Portable software Flow code orcad9 protel99 Proteus ccs And more
http://www.sonsivri.com/forum/index.php?topic=20330.msg72674#msg72674
sfabris
-Given: 8
-Receive: 23
« Reply #2 on: June 25, 2009, 10:23:03 22:23 »
http://www.megaupload.com/?d=8FEPFOHF
Password: sonsivri
sf
robban
-Given: 34
-Receive: 38
Warrior
« Reply #3 on: June 30, 2009, 12:44:19 12:44 »
Hi!
I found a workaround to debug Keil software with H-JTAG(free).
Q. How to configure KEIL(uVision3.51) with JTAG?
A. In Keil, open Project>Options for target>Debug>Use RDI interface Driver>Settings>Browser and search for Yr. H-JTAG.dll in approprite folder.
With a cheap Olimex Wiggler it could work like a true debugger(tracing, stepping and so on). But watch out, unless You're a pro, practice a lot....
I actually used the H-JTAG v. 9 and - beside that Segger couldn't either download or debug my code- I was able to download my code via the RS232 interface and later correct the code until it was errorfree and, again download the correct code.
Don't fret, there's always a workaround cheap JTAG stuff
Godd luck  Cheesy
« Last Edit: July 02, 2009, 02:44:04 14:44 by robban » Logged
Code Warrior
Mega32
-Given: 273
-Receive: 37
« Reply #4 on: July 10, 2009, 10:11:39 22:11 »
Does anyone have the GDB unlimited keygen ?
Mega32
Oleg
-Given: 15
« Reply #5 on: November 30, 2009, 01:40:23 01:40 »
I need to develop an applicataion in embedded environment. It should have a touch screen interface, meaning there must be a buttons and multiple pages...
Since I'm not an embedded programmer - LabVIEW, I'm looking to do it in LV ARM.
Question is - can it be implemented in this class controller or I have to look for something else...
Thanks for advice in advance.
spasbyspas
-Given: 749
-Receive: 366
« Reply #6 on: November 30, 2009, 06:00:14 06:00 »
Yeah, maybe. In addition to practice. If menus are many and with many elements of them have added to external memory.
But how to work with these controllers in LabView??? Smiley
Oleg
-Given: 15
« Reply #7 on: December 04, 2009, 05:52:38 05:52 »
This is the question...
In the ARM toolset there are:
1. Display functions.
2. SPI and I2C functions.
3. Interrupts.
4. CAN functions.
5. Elemental IO functions.
6. Send profile data (??).
If you are interested in more details what is available, on the NI site there is 374931b.pdf file "Getting Started with the LabVIEW Embedded module for ARM.
I'm quoting from this doc: "New Memory Access VIs
The Embedded Module for ARM Microcontrollers now includes a
Memory Access palette, which includes the following VIs:
• CCG Mem Peek 8
• CCG Mem Peek 16
• CCG Mem Peek 32
• CCG Mem Poke 8
• CCG Mem Poke 16
• CCG Mem Poke 32
Use these VIs to read and write values to specific memory addresses."
Is it sufficient?
lillbear
-Given: 223
-Receive: 182
« Reply #8 on: December 04, 2009, 06:19:22 06:19 »
no such file.. plz upload again
yours
pak
« Reply #9 on: April 24, 2011, 05:16:28 17:16 »
the following link uploaded by sf is still working as 25 Apr 11.
Password: sonsivri
pak
anotherandrew
-Given: 822
-Receive: 23
« Reply #10 on: December 29, 2025, 01:17:21 01:17 »
hello friends, does any one have this keygen and can upload please?
h0nk
-Given: 305
-Receive: 272
« Reply #11 on: December 29, 2025, 05:38:50 05:38 »
LINK.TXT
Best Regards
