April 29, 2026, 11:39:02 11:39
Author Topic: Need help regarding ISOLATION TRANSFORMER.  (Read 4196 times)
jaikumar
-Given: 52
« on: May 29, 2009, 12:21:51 12:21 »
I wired up a isolation transformer like this
1) I have 2 primary 220, 50HZ. Secondary 0-12 volts
I connected the secondary's togother and one primary goes to the mains.
on the other primary I read the voltage with respect to ground i get 55 Volts, should i get zero, because the ground point should be isolated?
Thanks and Regards,
Jai
DTiziano
-Given: 41
-Receive: 168
« Reply #1 on: May 29, 2009, 03:42:32 15:42 »
But do you read the voltage between one leg and ground ?
If yes then what you get depends of the parassitic capacity between the coils.
To get zero volt you need a transformer with a (grounded) shield between coils.
-Receive: 4460
« Reply #2 on: May 29, 2009, 09:50:07 21:50 »
Bet your Neutral of your mains is at or near ground at sub station. and this is what your reading.
