April 29, 2026, 07:13:54 07:13
Author Topic: Digital Speedometer  (Read 17006 times)
srspinho
« on: December 08, 2006, 03:52:03 15:52 »
Hi Guys,
do someone have a project of a digital speedometer for cars ?
Thanks !
Sérgio
fmssp
-Given: 42
-Receive: 109
« Reply #1 on: December 08, 2006, 06:48:08 18:48 »
http://www.siliconchip.com.au/cms/A_103208/article.html
http://www.siliconchip.com.au/cms/A_103355/article.html
http://www.edn.com/article/CA529384.html
Success!
Sergey  Wink
« Last Edit: December 08, 2006, 07:07:04 19:07 by fmssp » Logged
From Russia with love... ;-)))
darksky
-Given: 183
« Reply #2 on: December 09, 2006, 03:49:53 15:49 »
What about using GPS - this is the best way.
srspinho
« Reply #3 on: December 11, 2006, 03:47:22 15:47 »
Thank you Guys !
frasenci
Translator
-Given: 142
-Receive: 85
« Reply #4 on: December 14, 2006, 09:35:12 21:35 »
Hi there ,
From the 3 excellent links we got from fmssp , I liked the 3rd most because of its simplicity srspinho.
But you can make it simpler on replacing the Hall-Effect sensor with an Optical one .
In my experience , once you are done with the Hardware-Software part , comes the trouble to attach those magnets on to the rotating part you want to sense,.....
I succesfully use QRD1114 as a sensor , only thing needed to sense the movement is a tiny White-Black transitions spot on rotational part,... ( Can also use OPTEK 703 ). I commonly use Girls Nail Paint for this painting ( clean part before apply).
I have some real world applications of this using Basic PIC processor and very simple PULSE IN code to get an speedometer for a few $.
Moreover , QRD1114 can easily be used as a proximity sensor , or distance measure in the 0 - 100 mm range. A nice IC I must say and cheap.
If still interested , maybe I can help you set up one of these,
Greetings
FAA
 Wink
srspinho
« Reply #5 on: February 15, 2007, 10:34:55 10:34 »
Hi friend,
first of all, excuse-me for my Biiig delay answering your Post.
I was on vacation and far away from computers !
Well, I´m doing my speedometer using PicBasic Pro.
The Timer 0 counts a 250 ms period and Timer 1 works as a pulse counter.
I know that my Opel Corsa has a Speed Sensor (VSS) which could be used to give me the right number of pulses for each car´s wheel revolutin (i guess it is 8 pulses / revolution in a 14 inch wheel)
I´m trying to do a Schmitt Trigger with a Ne555 to capture de pulses from a sensor
The problem is that here in Brazil No one wants to give the right information about the sensor. Everybody wants to sell the information in book for about US$ 80,00 ! ! ! ! ! !
have you ever did something with car´s Speed sensor ?  Is the output of this kind of sensor in low voltage enough to work with the 555 ?
If you have any information about the speedometer´s implementation... Anything.... Iwould be happy !
thank you !
Sérgio
« Last Edit: February 15, 2007, 02:29:20 14:29 by srspinho » Logged
fmssp
-Given: 42
-Receive: 109
« Reply #6 on: February 17, 2007, 07:57:48 07:57 »
Hi friend,
thank you !
Sérgio
Hi Sergio!
The speed sensor has on output NPN OC. With the uC it is enough For the interface here such scheme. At the European cars - 1000 turns of a speed sensor = 1 kilometer of road. At American = 1 mile. The quantity of impulses on one turn of the gauge can be 6, 8 or 10.
Success!
Sergey.
nileshhande
-Given: 23
« Reply #7 on: February 17, 2007, 10:30:30 10:30 »
Hi friend,
thank you !
Sérgio
Hi Sergio!
Success!
Sergey.
HI,
please share the source code..
Thanks..
fmssp
-Given: 42
-Receive: 109
« Reply #8 on: February 17, 2007, 12:35:33 12:35 »
HI,
Thanks..
http://analarc.narod.ru/hobby/panel/speedmtr/spedometr.html
Digital speedmeter on 16f84. The scheme and an source code.
In Russian!
fmssp
-Given: 42
-Receive: 109
« Reply #9 on: February 20, 2007, 12:58:06 12:58 »
Here still the interesting schematic of the multiple-purpose interface for different types of speed sensors.  The choice of type of the gauge is made by the software: pull up or pull down resistance or AC.
http://203.57.155.69/cms/A_108157/article.html
srspinho
« Reply #10 on: February 22, 2007, 12:45:06 00:45 »
Hi Friends !
many many thanks for your Reply !
Recently, I discovered that my Opel Corsa (or Vauxhall Barina) has a "Distance sensor" which gives some pulses to Corsas´s digital mileage counter.
Whell, a Friend told me that this sensor works like that :
(This data are for a 13 Inch wheel )
1) The sensor is conected to ther gear Box
2) For : 10 Km/h -> 45 Hz
    For : 20 Km/h -> 90 Hz
    For : 40 Km/h -> 180 Hz   and so on...
in this case, velocity is :  V = 0.2222 * F
If using uC : V = (10 * V) / 45
well...
Is late night here in Brazil, so, I will have to check my Tire´s rolling radius in order to calculate the quivalence for me, because my Corsa has 14 Inch wheels.
When i get the calculations ready, I will post it here !
Thanks every body
Sérgio
milan
-Given: 38
-Receive: 126
« Reply #11 on: December 20, 2007, 10:40:38 10:40 »
Fiat tipo have digital board and digital speedometer. You can find shematics searching google.
