April 28, 2026, 11:55:14 11:55
Author Topic: HELP voltage step down problem  (Read 4206 times)
junaid_766
« on: February 18, 2009, 12:20:08 12:20 »
i m attaching a circuit diagram which is step down the 220V AV to 7-8 V
can anyone explain the working of the  1 M ohm  resistance and 1uF capacitor ,how they work and step down the voltage?HuhHuh
Huh
vgg60
-Given: 16
« Reply #1 on: February 18, 2009, 01:07:41 13:07 »
1uF capacitor works as voltage-dropping resistor for alternative current.  1Mohm resistor is to discharge the capacitor after disconnection from ac network. R(C)=1/(2pi*f*C)
newboy
-Given: 42
-Receive: 20
« Reply #2 on: February 18, 2009, 03:35:38 15:35 »
Huh
Can you share the original file please. Seem it's useful for me.
Thanks.
FranzW
-Given: 589
-Receive: 81
« Reply #3 on: February 18, 2009, 09:17:51 21:17 »
The 1uF capacitor is used instead of a resistor in the voltage divider circuit, because it will not produce heat.
At a mains frequency of 50 Hz, the capacitive reactance of the 1 uF is 3183 ohms, this means that it is substituting a resistor of 3183 ohms.
The 1 megohm resistor is just to discharge the capacitor after the input voltage has been switched off.
FranzW
