April 20, 2026, 06:59:46 18:59
Author Topic: Engineering Solutions Catia V5 Video Tutorial  (Read 7921 times)
vaiduakhu
-Given: 27
-Receive: 349
Hutter
« on: January 20, 2009, 07:08:59 07:08 »
Learn the basic and advanced features of Catia V5 step by step with the Catia V5 Tutorial DVD by Magnitude Engineering Solutions. The DVD plays instantly on your computer and comes with its own menu and media player so there is no instillation required. Just insert the DVD and choose what lesson you want from the menu. You're able to play, pause, rewind or fast forward at anytime giving you the flexibility to learn at your own individual pace. These tutorials are made by industry professionals who will give you the tools to learn and master Catia V5 quickly and easily. This Catia V5 Tutorial is applicable to all versions of Catia V5 and comes with everything listed below.
* 135 Video Tutorials
* Project part files required to follow the tutorials
* Screen Resolution of 1280 x 800
* Audio narration for each tutorial from start to finish
* Sample projects
This is the most complete and comprehensive tutorial available. It is perfect for beginners as well as advanced Catia V5 users. These are the tutorials included on the DVD.
1. Format 46. Groove 91. Compass Translate Part
2. Workbench 47. Hole 92. Compass Translation Assembly
3. Customize Environment 48. Rib 93. Compass Rotate Part
4. Mouse Button Hot Keys 49. Slot 94. Compass Rotate Assembly
5. Catia V5 Hot Keys 50. Stiffener 95. Part Body
6. Catia V5 Documents 51. Solid Combine 96. Adding Part Bodies
7. Save Management 52. Reference Planes 97. Boolean Operations Overview
8. Product Tree 53. Basic Multi Section Solid 98. Create Boolean Bodies
9. Compass Views 54. Multiple Multi Section Solid 99. Boolean Add
10. Sketcher Intro 55. Advanced Multi Section Solid 100. Boolean Add Application
11. Dimension Sketches 56. Basic Removed Multi Section 101. Boolean Remove
12. Auto constraints 57. Multiple Removed Multi Section Solid 102. Boolean Remove Application
13. Contact Constraints 58. Advanced Removed Multi Section Solid 103. Boolean Intersect
14. Manual Sketch Edit 59. Edge Fillet 104. Boolean Intersect Application
15. Profile Sketch 60. Variable Radius Fillet 105. Draft Reflect Line
16. Offset Sketch 61. Face – Face Fillet 106. Sections Views
17. Scale Sketch 62. Tritangent Fillet 107. Assembly Intro
18. Trim Extend Sketch 63. Chamfer 108. Intersecting Components
19. Split Sketch Entities 64. Draft Angle 109. Constraints vs. Positional Assemblies
20. Construction Geometry 65. Variable Angle Draft 110. Update
21. Translate Sketch 66. Shell 111. Coincidence Constraints
22. Rotate Sketch 67. Body Translation 112. Contact Constraint
23. Symmetry Sketch 68. Body Rotation 113. Offset Constraint
24. Mirror Sketch 69. Body Symmetry 114. Angle Constraint
25. Corner Sketch 70. Mirror Body 115. Fix Constraint
26. Chamfer Sketch 71. Rectangular Pattern 116. Manipulation
27. Predefined Profiles 72. Circular Pattern 117. Compass Positioning
28. Circle Profiles 73. Scale Body 118. Snap
29. Conic Profiles 74. Parallel and Perspective View 119. Guitar Constraint Assembly
30. Spline Definitions 75. Apply Material 120. Guitar Positional Assembly
31. Spline Sketch 76. Apply Colour 121. Explode
32. Fix Together 77. Apply Transparency 122. Drawing Intro
33. Hide Show 78. Render Style 123. Insert Drawing Views
34. Visible Space 79. View Position 124. Drawing Display
35. Project Edges 80. Custom View Position 125. Section Views
36. Utilize Visible Space 81. Multi View 126. Detail Views
37. Sketch Analysis 82. Part Details 127. View Scale
38. Solid Modeling Intro 83. Measure Tools Overview 128. Linear Dimensions
39. Pad 84. Measure Between 129. Angular Dimensions
40. Drafted Filleted Pad 85. Measure Item 130. Radial Dimensions
41. Multi Pad 86. Measure Inertia 131. Diameter Dimensions
42. Pocket 87. Coating and Plating Calculations 132. Precision Dimensioning
43. Drafted Filleted Pocket 88. Plastic and Forging Calculations 133. Anchor Points
44. Multi Pocket 89. Search Function 134. Inserting GD&T
45. Shaft 90. Compass Component Intro 135. Print Settings
http://tinypaste.com/4d124
