April 11, 2026, 08:56:42 20:56
Pages: 1 [2]  All
Author Topic: CNC - PCB Mill / drill  (Read 66787 times)
DTiziano
-Given: 41
-Receive: 168
« Reply #25 on: October 04, 2009, 12:35:59 12:35 »
hi andrea11
Circuitcam is a beautiful program, but unfortunately you have to configure it before use.
Any way I made it while ago, so look at previous post (09 January 2009) were "weewee" ask for the same thing.
Download my configuration and follow the instructions.
Jum
« Reply #26 on: October 05, 2009, 04:01:49 16:01 »
One question, could send the file in visual basic to calibrate the Z axis with mach3?
Thanks.
DTiziano
-Given: 41
-Receive: 168
« Reply #27 on: October 05, 2009, 05:38:57 17:38 »
Hi Jum
Here the script for Mach3.
The script is a collection of function, the one you need is the "Drill_Z (0)".
All my VB script once started test if the probe is OK (not grounded).
Once the selected function is started, it wait for a probe touch (by ground it).
In this way I am sure that the probe is working, otherwise the mill can make a mistake.
In PCB milling the drill is at ground, while the copper clad is the probe.
« Last Edit: October 05, 2009, 08:47:00 20:47 by DTiziano » Logged
Jum
« Reply #28 on: October 05, 2009, 07:01:46 19:01 »
I am currently doing a project to use a nunchuck for the wii to emulate a jog dial for Mach 3 and wanted to add the option of seeking zero. So now I will not. Thank you.
Sorry my bad English.
tienngoc
-Receive: 45
« Reply #29 on: October 06, 2009, 03:12:23 03:12 »
Here is a little help.
http://www.vrg.utoronto.ca/~trescas/PCB/pcb_tutorial_rev1.pdf
andrea11
-Given: 34
« Reply #30 on: October 08, 2009, 07:23:40 07:23 »
hi DTiziano,
here version 5.2.713 of circuitcam that seems to work well win your serials, I added some cat files
http://rapidshare.com/files/290145222/cam52.zipx
greetings to all
andrea11
Jum
« Reply #31 on: October 17, 2009, 03:01:58 15:01 »
Hi Dtiziano:
I'm trying to make a 2 sided board and I have a problem with circuitcam. The configuration files are you sent here. The botton face no problem, but I did not face top isolated tracks. No reason. If the top face of change and I put my botton isolated tracks without problems, but when I isolate the botton and the top, the top not isolated. If you post a project with a single-sided top, not isolated to me. You know that can happen?
Sorry for my inglish.
DTiziano
-Given: 41
-Receive: 168
« Reply #32 on: October 19, 2009, 10:14:34 22:14 »
Here a sample project.
Did you put the various gerber files to the right layers place, right ?
Maybe this is the problem.
At import level you have to choose the destination layer.
Tray to play with the layers visible properties to check if it is OK.
Jum
« Reply #33 on: October 20, 2009, 04:49:36 16:49 »
My modus operandi is as follows:
1 - Gender 4 layers in Altium: Bottom, top, drill, boardoutline.
2 .- In circuitcam: New, default.
3 .- I import the 4 layers.
4 .- Insulate all layers.
In circuitcam if I choose new / 4layers, I can insulate the layers but I can not export to dfx (not shown the options).
My proyect.
Thanks.
DTiziano
-Given: 41
-Receive: 168
« Reply #34 on: October 20, 2009, 11:01:19 23:01 »
You are right.
The configuration are stored under ..\LPKF50\New_Templates\<file.cat>
My set up is in "default.cat", so you must select it before starting.
Jum
« Reply #35 on: October 21, 2009, 07:55:57 19:55 »
I copied and pasted your file default.cat. Know this well because I have option to export DXF files. But something goes wrong. In the example I put here in a file, not isolated tracks in the top layer. In the example you've listed, delete the layers and layers under my project and if isolates the top face. I do not understand where the problem lies.
Thanks for your patience.
DTiziano
-Given: 41
-Receive: 168
« Reply #36 on: October 21, 2009, 09:32:00 21:32 »
I am not sure to understand what you mean.
In your example the top trace insulation standard and small was not visible.
Goes to layer menu (type C from keyboard) and then enable them by checking the visible, selectable etc.  properties.
Jum
« Reply #37 on: October 23, 2009, 10:58:25 10:58 »
Yes,yes,yes.Do not know why but insulate the top layerstd was not visible.
Jum
« Reply #38 on: October 25, 2009, 07:54:50 19:54 »
Andrea11 :
 This file can only be downloaded by becoming a Premium member.
  Reload, please.
DTiziano
-Given: 41
-Receive: 168
« Reply #39 on: October 25, 2009, 08:07:27 20:07 »
Here a megaupload link:
http://www.megaupload.com/?d=YEZO9MWT
andrea11
-Given: 34
« Reply #40 on: October 25, 2009, 10:35:15 22:35 »
Jum:
here new link
http://rapidshare.com/files/297869921/cam52.zipx
abcsantosh
-Given: 33
« Reply #41 on: November 03, 2009, 11:31:46 11:31 »
Hi DTiziano, your work is excellent. I am also trying to make pcb's with my home made milling machine.
I used your configuration and I can able to generate dxf files with it. But how do you drill your boards with excellon files. I want to generate drill gcode for mach3. Which apps you used for it ?
Have a nice day
« Last Edit: November 03, 2009, 11:34:27 11:34 by abcsantosh » Logged
DTiziano
-Given: 41
-Receive: 168
« Reply #42 on: November 04, 2009, 06:23:30 18:23 »
"The Excellon2 data is converted to gcode by my application"
Since I did not found a working converter I write one basically for my use.
It is written in Labview, if you want to to try it here are the links.
http://www.megaupload.com/?d=LBQXII8F
or
http://rapidshare.com/files/303383407/Excellon2_install.rar
P.S.
This is my first application I built with the 8,6 version and I did not test yet the installations.
« Last Edit: November 06, 2009, 11:33:18 23:33 by DTiziano » Logged
mayli
-Given: 12
-Receive: 30
« Reply #43 on: November 05, 2009, 05:39:49 05:39 »
Do "DTiziano" try to upload rapidshare or other site?
Because our country do not support megaupload.
DTiziano
-Given: 41
-Receive: 168
« Reply #44 on: November 06, 2009, 11:34:33 23:34 »
Ok
Updated with Rapidshare link.
kalpakchiev
-Given: 34
-Receive: 68
« Reply #45 on: April 14, 2010, 01:00:28 13:00 »
I use ORCAD -> CooperCam -> Autograv. CooperCam supports a lot of different CADs and there is no need of conversion. Output files can be separated to DRILL ONLY and MILL ONLY and can be saved as *.NC or *.PLT which are widely accepted by most of CNC maschines.
« Last Edit: April 14, 2010, 01:15:30 13:15 by kalpakchiev » Logged
-Given: 405
-Receive: 545
« Reply #46 on: April 18, 2010, 01:50:32 01:50 »
hey what the hell kalpakchiev I don't see any 16f84 in that picture Smiley
kalpakchiev
-Given: 34
-Receive: 68
« Reply #47 on: April 18, 2010, 02:30:35 02:30 »
What picture, Sorry I can not understand Huh
-Given: 499
« Reply #48 on: April 19, 2010, 12:05:10 00:05 »
kalpakchiev,  bbarney is pulling your leg!  Cheesy
You have been posting a lot of 16F84 schema and designs lately  Smiley
Cmon barney, give the guy a break.
If he start posting in some other language you would be confused too  Cheesy  Cheesy
kalpakchiev
-Given: 34
-Receive: 68
« Reply #49 on: April 19, 2010, 01:33:09 01:33 »
Yeees, now I see the joke;D Grin.
It is a thousand pities but my English is a little bit rusty Undecided.
Projects are with 16F84 because I have a lot of them. It is easy having the code to translate them for use with F628, F648, F88 .....
About the picture bbarney is right - there is no PIC at all. The missing chip is 74LS165. A few PCBs like this are chain connected and form a cluster with 256 inputs which are read by a 16F877 using SHIFTIN and SHIFTOUT commands in PBP
Next time I'll be more tuned for jokes Wink Wink
Best regards
Pages: 1 [2]  All
