April 27, 2026, 01:43:28 13:43
Author Topic: Cheap, easy PIC USB Programmer based on DIYpack  (Read 15029 times)
Tics
« on: October 06, 2006, 02:46:39 14:46 »
month ago I found USB Programmer DIYpack
oryginal site: http://kitsrus.com/pic.html
and direct for all_pack: http://kitsrus.com/zip/diypack25.zip
I rebuild a little this project, so that it was simpler to make in household conditions.
In my version, standard PC connection is realized by RS232,
so, now is posiible to use most popular RS232<->USB converter.
Eagle projetc is attached:
maybe it will be usefull  Wink
Tics
mizk_electro
« Reply #1 on: October 06, 2006, 06:48:31 18:48 »
Tics
Tics,
How about hex file for 16F628 ?
Any source code ... so that I can change it if I cannot find 16F628 IC or...... if you have hex code for 16F877A, that much better.
Anyway thanks alot for your sharing with us.
Tics
« Reply #2 on: October 06, 2006, 08:20:19 20:20 »
all needed hex are included into diypack25.zip
I'm not an autor of this hex, than i'm not possess any source
so, I will test it on 16F628A if work,
in fact they are only a little difference between 628 and 628A
mizk_electro
« Reply #3 on: October 07, 2006, 07:41:07 07:41 »
Tics,
hope to hear your successstory.  Wink
mizk_electro
« Reply #4 on: October 07, 2006, 07:43:03 07:43 »
Tics,
I mean ...  your success story . Smiley
Tics
« Reply #5 on: October 14, 2006, 08:21:28 20:21 »
It working on 16F628A !
Following autor info "To load into 628A chips go into Fuses and turn all code protection OFF".
Programmer works beauty Wink
« Last Edit: October 14, 2006, 08:23:33 20:23 by Tics » Logged
mizk_electro
« Reply #6 on: October 15, 2006, 08:44:20 08:44 »
Tics,
Which hex code do you use in 16F628A & 16F628.
Maybe you can share over here the code (working code of 16F628A & 16F628) for your friends  Wink
Thanks alot
cesarman
« Reply #7 on: October 15, 2006, 07:07:09 19:07 »
Thanks, working good, i USE this hex k149a.HEX is inside of the file diypack, on PIC16F628A
but the way, a new version of the software you can download here.
___http://www.newfoundelectronics.com/diy/diypack26.msi
Tics
« Reply #8 on: October 16, 2006, 08:47:33 08:47 »
mizk_electro,
I use diyk182.HEX from diypack25.zip,
it's attached,
cesarman,
Thanx for newest link, I will test it.
mizk_electro
« Reply #9 on: October 16, 2006, 12:38:14 12:38 »
mizk_electro,
it's attached,
cesarman,
Tics,
Thanks a lot .....  Smiley
Mizk
dech
« Reply #10 on: October 21, 2006, 06:11:38 18:11 »
Thank!! for diypack_26.msi
chandra2sekhar2000
« Reply #11 on: October 23, 2006, 06:28:38 18:28 »
HELLO !
AMONG ALL THE USB DIY PROGRAMMER ( K128,K149,K149A/B/C,K150,K182) WHICH ONE WILL SCORE MORE POINTS. THAT IS WHICH PROGAMMER WILL SUPPORT MORE PICS,EEPROMS.
THANK U
Tics
« Reply #12 on: October 29, 2006, 10:23:25 10:23 »
chandra2sekhar2000,
( K128,K149,K149A/B/C,K150,K182) they are the same project, each model support the same PICs
different is only for hardware, U must decide byself wich one U will build.
I builded own hardware based on 128 pack...
