April 19, 2026, 12:01:32 12:01
Author Topic: IS IT POSSIBLE TO SCROLL THE DISPLAY DATA OF 16X2 LCD  (Read 7135 times)
chandra2sekhar2000
« on: September 26, 2006, 01:16:27 13:16 »
HELLO I HAVE TRIED TO SCROLL THE LCD CONTENT OF 16X2 DISPLAY USING LCDOUT COMMAND OF PBP.BOTH 2 LINE DATA IS SCROLLING.BUT IS IT POSSIBLE TO SCROLL ONE LINE WHILE KEEPING THE OTHER LINE STANDING.IF POSSIBLE PLEASE PROVIDE THE CODE FOR BOTH LEFT TO RIGHT AND FROM RIGHT TO LEFT.FOR SCROLLING BOTH THE LINES I HAVE USED THE FOLLOWING SUBROUTINE.
SCROLL:
FOR B0 = 0 TO 40
LCDOUT $FE,$18
PAUSE 300
NEXT
RETURN
tasosstr
-Given: 96
-Receive: 14
« Reply #1 on: September 28, 2006, 10:57:03 22:57 »
Try this http://www.protongeeks.com/index.php?option=com_content&task=view&id=95&Itemid=27
I hoppe to help you ...
sadman
-Given: 1985
-Receive: 3216
Sow The Seeds of Love
« Reply #2 on: October 04, 2006, 06:19:30 06:19 »
here you go may this will help you
DEVICE 16F84A
DECLARE LCD_INTERFACE 4         ' 4-line or 8-line interface is required by the LCD.
DECLARE LCD_LINES 4             ' Inform the compiler as to how many lines the LCD has
DIM FORTONEXT AS WORD
DIM SCROL AS WORD
DIM ASCII, CHAR1
PORTB=0
PORTA=0
DELAYMS 500                ; to stabilized uPc
PRINT_MESSAGE:
FOR SCROL= 0 TO 800
CURSOR 1,1
FOR ASCII=0 TO 19, STEP 1                                                         ' 0 TO 19 MAKES A TOTAL OF 20 LOCATION IN THE LCD (FOR LCD = 20 CHARS)
CHAR1 = LREAD LABEL + (ASCII+ SCROL)                                                      ' Read memory location LABEL + LOOP
PRINT CHAR1
NEXT ASCII
delayms 250                ; DELAY IN ORDER TO SEE THE TEXT IN THE LCD
NEXT SCROL
GOTO PRINT_MESSAGE
LABEL:
LDATA "Fragrance"
LDATA "enjoy on sonsivri"
LDATA "PIC BASIC Proton"
GOTO PRINT_MESSAGE
i could not found any attachment option to attach file
sadman
« Last Edit: July 20, 2007, 08:02:21 08:02 by sadman » Logged
sohel
-Given: 169
-Receive: 149
« Reply #3 on: October 05, 2006, 06:01:14 06:01 »
a ton of lcd
try it
