February 25, 2026, 04:36:26 16:36
Author Topic: Could someone help me please  (Read 4943 times)
Scooter_3D
« on: November 29, 2008, 04:55:20 16:55 »
I have made this scope clock http://www.jogis-roehrenbude.de/Leserbriefe/Scope-Clock/Scope-Clock.htm
and would like to change the way the clock face looks, what would I need to change in the source files to do this ??
I know nothing about coding and Im not asking for someone to do it for me just point me in the right direction
Administrator's Note: Help & Rules board #27
http://www.sonsivri.com/forum/index.php?topic=7494.0
Use clear understandable post subject. Nobody have to read your "I need Help" subjected post.
« Last Edit: November 29, 2008, 05:57:08 17:57 by SONSiVRi » Logged
hagen
-Given: 16
« Reply #1 on: November 29, 2008, 08:13:05 20:13 »
Have a look into
                         scDataGen.c
The routine
             void MakeSimplePtr(char *name, float r1)
takes care of the simple hand
and
             void MakeTriangPtr(char *name, float r1, float r2)
generates the triangle shape hands.
Now change the math according to your specific design.
You need the compiler / assembler package used by the author.
It is a Linux program "Paul's 8031 Assembler" found at
              http://www.pjrc.com/tech/8051/
plus gnu-c.
Run make and the c- source will be compiled by gcc and started.
It will generate a set of data for the assembler program.
By redirecting the output into a file ScopeClockData.a51, it generates the
required data for the assembler program scopeclock.a51.
The resulting Hex file has to be "burned" into the chip.
You need to have a specific programmer to  do this.
A simple design is available at the Atmel homepage.
Sounds a bit frightening- but visit the above mentioned page and find a very
sufficient support for the tools required- including the programmer and also for
windows.
If you take an AT89S4051 you can easily program the chip in the system.
Find the info at Atmels homepage.
Wish you a lot of fun
Scooter_3D
« Reply #2 on: December 04, 2008, 02:51:34 14:51 »
Thanks for your reply now i need to work out how to use them programs in vista
