April 11, 2026, 07:28:58 19:28
Author Topic: Pascal compiler for 8051  (Read 5081 times)
spacetime
« on: November 25, 2008, 06:47:56 18:47 »
Some deviation from the mainstream: a free Pascal compiler for 8051
http://turbo51.com
A fast single pass optimizing compiler, Borland Turbo Pascal 7 syntax, floating point support, mixed pascal and assembler programming, full use of register banks, advanced multi-pass optimizer, smart linker, generates compact high quality code, output formats include binary, Intel HEX, OMF-51 and assembler source. Source level debugging is possible with extended absolute object file (use Keil uVision, Silabs IDE, Raisonance IDE or any other debugger/IDE that supports omf51 object files).
jabuka
« Reply #1 on: November 26, 2008, 08:39:02 08:39 »
Regarding Pascal compiler for 8051,
You should check out mikroElektronika's mikroPascal for 8051 compiler. It is comprehensive, stand-alone Pascal compiler for 8051 MCUs and
it has intuitive and friendly Pascal environment, using many advanced features and practical examples.  It is accompanied with the most advanced
IDE on the market. Plenty of practical examples and a comprehensive documentation allow a quick start in programming 8051.
More info and download here:
http://www.mikroe.com/en/compilers/mikropascal/8051/
Best Regards.
