December 10, 2025, 07:14:33 07:14
Author Topic: AT89c2051 programmer  (Read 9978 times)
nikhilele
-Receive: 22
« on: July 14, 2006, 07:17:07 07:17 »
Is there any simple AT892051 programmer that can be easily used by 8th or 9th grage school students.
I am going to start a hobby club for kids and i want to teach them controller programming.
so i am looking for AT892051 programmer  which should be small simple and cheap and easy to use
is there any link or resource:)
KhepeleSibilo
Translator
-Receive: 412
« Reply #1 on: July 14, 2006, 07:57:38 07:57 »
and three more, tell me if this is not enough to send then (i most search for them in my archive )
use bascom 8051, and 89c4051 hase 4KB and new bascom8051 demo compile 4KB!!
Program BlowIt2051;
Uses VTD;
var
base: Word;
i, j, k, l: Integer;
mem: Array[0..2047] of byte;
f: file;
Const
inc_bit = $01;
vpp_bit = $02;
prog_bit = $04; { not inverse! }
erase_bit = $08;
prog_mode = $0F;
erase_mode = $07;
idle = $09; { Idle, RST = 0 }
label
err_exit;
begin
Writeln;
Writeln(ëóóóóó BlowIT (tm) 2051 ver 1.0 beta óóóóóí);
Writeln(ëhttp://sistudio.com for schematics and latest releaseí);
Writeln;
if ParamCount<1 then begin
Writeln(ëusage: BI2051 filename.bin [n]í);
Writeln(ëusage: n=1,2,3 LPT number to useí);
Writeln;
halt(1);
end;
base := memw[$40:8];
if ParamStr(2) = ë2í then begin
base := memw[$40:10];
end;
if ParamStr(2) = ë3í then begin
base := memw[$40:12];
end;
If base = 0 then begin
Writeln(ëParallel port does not exist!í);
Halt(2);
end;
for i:=0 to 2047 do mem := $FF;
assign(f, ParamStr(1));
reset(f,1);
blockread(f, mem, 2048,i);
close(f);
If IOResult <> 0 then begin
Writeln(ëFile not found!í);
halt(2); { File error }
end;
port[base] := $FF;
{ Erase }
port[base+2] := $01;
nms(10);
port[base+2] := $03; { RST = 12 }
nms(1);
port[base+2] := erase_mode; { RST = 12, PROG = H }
nms(1);
port[base+2] := erase_mode xor prog_bit; { P3.2 = 0 }
nms(12); { This is ERASE PULSE!}
port[base+2] := erase_mode; { P3.2 = 1 }
nms(12);
port[base+2] := erase_mode xor vpp_bit; { RST = 0 }
nms(20);
{ Program ROM }
port[base+2] := idle;
nms(10);
port[base+2] := idle or vpp_bit;
nms(10);
port[base+2] := prog_mode; { RST = 12, PROG = H }
nms(1);
Write(ëBlowingí);
k := 0; l := 0;
for j := 0 to 2047 do
begin
port[base] := mem[j];
if mem[j] <> $FF then begin
delay_mks(2);
{ PROG Pulse}
EnterCriticalSection;
port[base+2] := prog_mode xor prog_bit; { P3.2 = 0 }
delay_mks(5);
port[base+2] := prog_mode; { P3.2 = 1 }
delay_mks(2);
i := 0;
while (port[base+1] and 64) = 0 do
begin
delay_mks(10);
if i>200 then begin
Writeln;
Writeln(ëError, never ready?í);
goto err_exit;
end;
if i > k then k := i;
inc(i);
end;
LeaveCriticalSection;
if l > 30 then begin
Writeln;
Writeln(ëError, no device?í);
goto err_exit;
end;
if i = 0 then inc(l);
delay_mks(2);
end;
port[base+2] := prog_mode xor inc_bit; { XT1 = 1 }
delay_mks(5);
port[base+2] := prog_mode; { XT1 = 1 }
delay_mks(2);
if (j mod 64) = 0 then Write(ë.í);
end;
port[base] := $FF; nms(1);
port[base+2] := prog_mode xor vpp_bit; { P3.2 = 0!! }
nms(1);
port[base] := $00;
BlowIT 2051
Writeln;
Writeln(ëWe are finished.í);
Halt(0);
err_exit:
Halt(1);
end.
KhepeleSibilo
Translator
-Receive: 412
« Reply #2 on: July 14, 2006, 08:04:49 08:04 »
sorry
problem with attach!!!
use:
http://rapidshare.de/files/25800898/89c2051_Programmer.pdf.html
nikhilele
-Receive: 22
« Reply #3 on: July 14, 2006, 11:13:28 11:13 »
what about hardware involved
nikhilele
-Receive: 22
« Reply #4 on: July 14, 2006, 11:19:35 11:19 »
http://sistudio.com/  this is the site for hardware the site seem like portal or just provides links
« Reply #5 on: July 14, 2006, 03:55:17 15:55 »
You can find 100% working programmer with firmware ,
http://chaokhun.kmitl.ac.th/~kswichit/easy1/easy.htm
http://www.kmitl.ac.th/~kswichit/
KhepeleSibilo
Translator
-Receive: 412
« Reply #6 on: July 14, 2006, 05:35:55 17:35 »
1-I use http://chaokhun.kmitl.ac.th/~kswichit/easy1/easy.htm myself, no printer port problem under XP( no parttalk require) , but you must have a programmer for 89c2051 in programmer
2-I try to complitly copy main project witch i download some years ago and I think http://sistudio.com has expired!!!!
and also i made TAFE programmer that work with BASCOM and 3 other simple programmer for 89cx051, tell me if you want then then I try to upload
nikhilele
-Receive: 22
« Reply #7 on: August 22, 2006, 10:20:11 10:20 »
i have a universal progammer which can support 100s or chip
but i want to make a cheap 89c2051 programmer for kids of age group 14 - 19 for hobby kid of work.
gamegurus
-Receive: 64
Oh what a wonderful morning!!!
« Reply #8 on: September 01, 2006, 09:43:05 09:43 »
Better to make this. its derived from easy and supports lots of chips.
  http://chaokhun.kmitl.ac.th/~kswichit/89prog/index.html
Indian Gaming Guru
quakeman
« Reply #9 on: September 01, 2006, 11:27:06 11:27 »
Here are two more really simple atmel AT89Cx051 programmers:
http://www.qsl.net/dl2tm/atprog/atprog.html
http://www.eit.fhbb.ch/htmldoz/mm/atmel-programmer/atmelprogrammers.html
The first one i build myself and it works. But i only used it a few months until i bought a galep32 multi-programmer because i needed other chips. Wink
vsmGuy
-Given: 11
« Reply #10 on: January 27, 2008, 10:11:32 10:11 »
Try out the excellent Sunrom programmer :
http://www.sunrom.com/files/diy.zip
