April 25, 2026, 10:52:16 10:52
Author Topic: Self Bootloader  (Read 5185 times)
Help
-Given: 33
« on: November 01, 2008, 06:10:15 18:10 »
Currently i have success download the hex data to SRAM and running the program. Now I would like to save the CODE data on external eeprom whenever power is ON will automatically download the data to SRAM and start running the program without manualy set the /EA to GND.
I have found this method 8051 von Neumann Memory ( http://www.keil.com/download/docs/192.asp ). I'm not sure this method will solve the problem not.
void main (void)
{ load_vonNeumann_memory (); // Load VN memory
((void (code *) (void)) 0xE000) (); // Call function in VN memory
while (1) // Loop Forever { }
May i know this load_vonNeumann_memory (); function will be the bootloader portion? Download the hex data to SRAM. The next ((void (code *) (void)) 0xE000) (); function will be the external CODE execution start at 0xE000 address. Am i rite?
I have tested but no work. May be is the "Options for Target" Off-chip Code Memory and Off-chip Xdata memory setting is wrong.
Let say, my application code define is :-
Off-chip Code Memory: start = 0x0000, size = 0x4FFF
Off-chip Xdata memory: start = 0x5000, size = 0xAFFF
I'm using 2 32kB SRAM.
How can i do the setting on the 8051 von Neumann Memory?
If this method can't make it. Is there any other method to run the external code without doing the /EA to GND setting?
Thank you.
