April 29, 2026, 11:38:59 11:38
Author Topic: Camtrax, Geartrax, Camtraxmfg 2k9 for Solidworks  (Read 56102 times)
jesse
-Receive: 101
« on: October 11, 2008, 08:29:42 20:29 »
  Geartrax
  GearTrax provides the designer with an easy to use tool for creating solid models of drive components. Create spur, helical, straight bevel and involute splines with true involute tooth profiles.
GearTrax is intuitively easy to use for the designer with limited gear experience yet powerful enough for the gear expert. The animation window shows the spur/helical gear mesh which updates as the data is changed. It is extremely useful in understanding how changes to the gear parameters reflects on the gear mesh.
GearTrax is more than a library program.  Each part model is created with it's specific requirements just as a designer would, but rather than taking hours or days, the part is created in seconds.  GearTrax creates solid models of spur and helical gears, bevel gears, worm gears, involute splines, timing belt pulleys, chain sprockets and V-belt pulleys.  GearTrax also integrates with Excel to create data sheets.
  Camtrax
CamTrax helps the designer create solid models of virtually every type of cam with the dynamic motion control parameters your system requires. During the design, CamTrax™ generates charts when linked with Excel and adds a profile list to your drawing.  Camnetics, Inc. is dedicated to providing the design engineer with accessible software for developing high speed machine cams!
CamTrax standard cam types include cylindrical cams, plate (aka disk) cams and linear cams.  Choose the follower type that the design requires; on center translating, off center translating, swinging arm and flat-faced reciprocating.  Selecting different motion synthesis is a snap with CamTrax.  Choose between virtually any standard cam motion with a couple mouse clicks.  With Excel the designer can analyze the cam motions and compare different motion synthesis.  Don't have Excel?  Output can also be to a text file!  Charted are displacement, velocity, acceleration, pressure angle, cam shaft torque, radius of curvature, contact stress and normal force.
     Programs
    _ http://www.camnetics.com/downloads/camtrax2009install.exe
    _ http://www.camnetics.com/downloads/camtraxmfginstall.exe
    _ http://www.camnetics.com/downloads/geartrax2009install.exe
    Crack
   _ see below .... above links still working
        Saludos
« Last Edit: July 05, 2012, 12:34:45 12:34 by pickit2 » Logged
joker12
-Receive: 80
« Reply #1 on: November 12, 2008, 02:53:15 02:53 »
You can find the crack here:
www.jxcad.com.cn/read.php?tid=731623&page=e
You will need to register. It's a Chinese board so you will need to translate. Depends how much you need it Shocked
« Last Edit: November 12, 2008, 03:01:53 03:01 by joker12 » Logged
sgoum
-Given: 94
-Receive: 68
« Reply #2 on: November 12, 2008, 07:35:48 07:35 »
Here it is
http://rapidshare.com/files/162980080/camnetics2k9_crk.rar
« Reply #3 on: February 10, 2011, 09:25:33 09:25 »
Anyone have the exe? The exe link got smart alecky by being replaced
thx
Better yet if u have 2k10 that is not the LZ0.  LZ0 stuff never seems to work
« Reply #4 on: December 29, 2011, 04:17:51 04:17 »
Camnetics CamTrax64 v2012.20.0.182
5.7 MB
http://filepost.com/files/92459fa4/Camnetics_CamTrax64.v2012.20.0.182.Incl.Keygen-Lz0.rar/
-Receive: 4460
« Reply #5 on: June 13, 2012, 12:14:25 00:14 »
new link
http://www.filestube.com/6369861f4ae137c403e9/go.html
Redhouse
-Given: 90
« Reply #6 on: October 12, 2012, 02:53:15 02:53 »
Can anyone re-post the "stand-alone" version of Camtrax?
(ref: http://www.sonsivri.to/forum/index.php?topic=47705.msg138953#msg138953)
GunMage
-Given: 11
-Receive: 35
« Reply #7 on: October 12, 2012, 02:23:42 14:23 »
I had no issues with the link Pickit2 provided, however here is the direct link:
http://depositfiles.com/files/eyijzb08z
CocaCola
-Given: 170
« Reply #8 on: October 12, 2012, 08:54:14 20:54 »
Link and Password in attached...
CamTrax 2010 (Solidworks Plugin)
CamTrax MFG (Standalone)
GearTrax 2010 (Solidworks Plugin)
GearTeq 2010 x32
GearTeq 2010 x64
Medicine for all of them, read the Readme for fixin' instructions...
*** Edited *** Link updated with a mirror upload if you are having issues with the original link...
« Last Edit: October 13, 2012, 09:16:37 09:16 by CocaCola » Logged
« Reply #9 on: October 13, 2012, 08:32:11 08:32 »
Can't download it, only premium?
CocaCola
-Given: 170
« Reply #10 on: October 13, 2012, 08:51:43 08:51 »
I confirmed the download right after I uploaded on a different computer and it was working, but yes now it appears the site is acting funny, even more so if you have an adblocker installed...
I'll get it uploaded to a mirror in a bit and update the txt file...
« Last Edit: October 13, 2012, 09:11:30 09:11 by CocaCola » Logged
« Reply #11 on: October 13, 2012, 08:59:08 08:59 »
Yep it works, downloading now - thank you then.
I put the link on JDownloader before, and it always reporting server error - waiting xx:xx:xx...
CocaCola
-Given: 170
« Reply #12 on: October 13, 2012, 09:21:17 09:21 »
Good to hear it's working now for you, it also took me 7 tries before it worked on my end just now, so something must be up with the site...  Anyway I just updated the attached text file and included a mirror site hopefully that will help eliminate any future issues...
-Receive: 4460
« Reply #13 on: October 13, 2012, 12:36:11 12:36 »
I found this to be true: if it don't work leave it for awhile and try again..
strange I even got file removed... but it's still there, site must be using an early version of wizzC
