You think I am funny guy huh?
April 29, 2026, 10:37:35 10:37
Author Topic: to pic mastres  (Read 5529 times)
aamir
-Given: 37
-Receive: 229
« on: June 08, 2006, 09:40:27 09:40 »
Hello
I am beginner to Pic Microcontoller .I am using timer1 to count 8 clik pulses using
interrupts and then toggle RB0 to output Frequency at RB0 should be 32 KiloHz
but it is 14 KiloHz only what is wrong wit code. Pic is 16f877A. frequency at TICK is
256KiloHz.
#include "D:\Timer\Timer.h"
#bit TimerOn = 0x10.0
#bit TimerFlag = 0x0C.0
#byte TimerLow = 0x0E
#BYTE TimerHigh = 0x0F
#bit Clk = 0x6.0
unsigned char Flag = 0;
void Check(void);
#use fast_io(B)
#int_TIMER1
TIMER1_isr()
Clk = ~Clk;or //output_toggle(Pin_b0);
set_timer1(0xFFFF);
Flag = 1;
void main()
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
setup_timer_2(T2_DISABLED,0,1);
setup_comparator(NC_NC_NC_NC);
setup_vref(VREF_LOW|-2);
enable_interrupts(INT_TIMER1);
enable_interrupts(GLOBAL);
TimerOn = 0;
SET_TRIS_B(0xF0 );
SET_TRIS_D(0xFF );
TimerFlag = 0;
Clk = 1;
set_timer1(0xFFFF);
//TimerHigh = 0xFF;
//TimerLow = 0xFF;
Check();
Flag = 0;
TimerOn = 1;
//while(Clk);
do
do
}while(!Flag);
Flag = 0;
}while(1);
void Check(void)
int i;
for(i = 1 ;i<10;i++)
output_toggle(PIN_B1);
delay_ms(100);
« Last Edit: June 08, 2006, 09:42:57 09:42 by aamir » Logged
telfo2007
-Given: 8
« Reply #1 on: November 21, 2007, 10:07:17 22:07 »
it could be a problem with your clock configuration. For example I used to begin with CCS compiler like this...
#include <18F4620.h>  <-- procesor type
//#device *=16
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
//#FUSES HS                       //High speed Osc (> 4mhz)
#fuses INTRC_IO
//#FUSES PLL                       //High speed Osc * 4 (> 4mhz)
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NOBROWNOUT               //No brownout reset
#FUSES NOPUT                    //No Power Up Timer
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT                    //Program memory not write protected
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOXINST
#use delay(clock=32000000)
I hope it helps you.
Bye
drovik
« Reply #2 on: November 22, 2007, 12:54:38 12:54 »
May be PWM solve you problem Huh
vibrex2007
« Reply #3 on: November 22, 2007, 07:47:25 19:47 »
What version of CCS do you have?
BLK
« Reply #4 on: January 03, 2008, 04:01:02 16:01 »
the clock is 256 divide with 32 = 8, divide with 2 is 4
                    setup_timer_1(T1_EXTERNAL|T1_DIV_BY_4);
for intrerupt use fast code :
            #int_global
             isr()
or #int_xxx FAST
#include <16F877A.h>
#use delay (clock=20000000)
#bit Clk = 0x6.0
void Check(void);
#use fast_io(B)
#int_global
isr()
   TimerFlag = 1;
   Clk = ~Clk; //output_toggle(Pin_b0);
   Flag = 0;
   set_timer1(0xFFFF);
   TimerFlag = 0;
void main()
setup_adc(ADC_OFF);
setup_spi(FALSE);
TimerOn = 0;
SET_TRIS_B(0xF0 );
SET_TRIS_D(0xFF );
TimerFlag = 0;
Clk = 1;
set_timer1(0xFFFF);
// Check();
Flag = 0;
TimerOn = 1;
do{
   do{ }while(!Flag);
   Flag = 0;
  }while(1);
void Check(void)
   int i;
         delay_ms(1);
