April 20, 2026, 10:25:42 22:25
Author Topic: Mastercam X3  (Read 28058 times)
jesse
-Receive: 101
« on: August 13, 2008, 05:26:31 17:26 »
   Mastercam X3 has arrived, take a look at it.
        Download the program from their web site:
        MasterCAM X3 Core Setup
        _http://updates.mastercam.com/x3/release/mastercamx3-web.exe
        Translators Setup
        Translators Setup for SolidEdge
        _http://updates.mastercam.com/x3/release/mastercamx3-direct-solidedge-web.exe
        Translators Setup for Autodesk Inventor
        _http://updates.mastercam.com/x3/release/mastercamx3-direct-inventor-web.exe
        Translators Setup for SolidWorks
        _http://updates.mastercam.com/x3/release/mastercamx3-direct-solidworks-web.exe
        Translators Setup for CATIA
        _http://updates.mastercam.com/x3/release/mastercamx3-catia-web.exe
        Sample Files Setup
        _http://updates.mastercam.com/x3/release/mastercamx3-samplefiles-web.exe
        MasterCAM What's New Video
        _http://updates.mastercam.com/x3/release/mastercamx3-videos-web.exe
        And here is the crack:
        _http://rapidshare.com/files/137064873/mastercamX3_crk.rar
        Saludos
          Jesus
Edit: take care posting links _http://home.com is not http://home.com   it's the same as coded links
« Last Edit: September 18, 2008, 05:53:23 17:53 by jesse » Logged
mick
-Given: 2237
-Receive: 138
« Reply #1 on: August 13, 2008, 10:10:28 22:10 »
nice work only
Translators Setup for SolidWorks wrong link
debutpic
« Reply #2 on: September 14, 2008, 03:55:27 15:55 »
Hello
Dont'work for me,when the original file"mastercam.exe" is patched Angry
jimbies
-Receive: 72
« Reply #3 on: September 16, 2008, 12:15:22 12:15 »
I installed it on my first PC, it didn't work. Then I install it on another PC
it worked. Could not figure out why it is so Huh Followed the same instruction
for both PCs.
jesse
-Receive: 101
« Reply #4 on: September 22, 2008, 10:40:37 22:40 »
                     HSM Performance Pack 3 for Mastercam
HSM Performance Pack 3 for Mastercam represents the next major release of a product that brings outstanding performance to Mastercam users who demand high speed machining capabilities. HSM Performance Pack 3 extends the capabilities of your exsting Mastercam system with a wide range of new features as well as reducing both the calculation and machining time.
    HSM Performance Pack features
    * Improved toolpath generation algorithms
      The toolpath generation algorithms have been completely reimplemented to offer very fast toolpath calculation.
    * Support for multi-CPU and multi-core systems
      Support for multi-CPU and multi-core systems when calculating a single operation. This means that the calculation time is significantly reduced when run on multi-core and multi-CPU systems. Multi-core PCs are now mainstream so all users with up to date hardware will benefit from this.
    * Support for Windows x64
      When run under Windows x64 HSM Performance Pack can utilize all installed memory (exceeding 2Gb) in the PC for individual toolpath operations. This means that even larger jobs can be run without the need for splitting them in multiple operations.
    * Improved toolpath quality
      The toolpath quality has been improved to allow higher feedrates and better part surface quality.
    * Includes the Adaptive Clearing strategy
      Roughing strategy for constant cutting conditions to reduce machining time and increase tool life significantly.
    * Support for tight tolerances
      Support for very tight tolerances to avoid facets on machined parts with very small curvatures. Tolerances below 1um are supported.
    * Improved rest machining from previous tool
      Rest machining from previous tool has been improved to avoid unnecessary machining.
    * Improved rest machining from previous operations
      Rest material from previous operations is now calculated significantly faster.
    * Improved linking toolpath
      New linking styles have been added and linking motion is now even more smooth.
    * Improved handling of vertical walls
      Verticals walls are handled much better to avoid toolpath spikes at walls.
    * Improved feedback during toolpath calculation
      Steady update of progress and current toolpath generation task. Furthermore, instant abort is supported.
        Download the program from here:
          _http://www.cimco-hsm.com/index.php?page=releases
        Here is the crack:
          http://rapidshare.com/files/147532819/hsm_for_mc_v3.rar
                 Saludos
                  Jesus
« Last Edit: September 23, 2008, 12:14:44 00:14 by jesse » Logged
hacbit
-Given: 21
-Receive: 35
« Reply #5 on: October 02, 2008, 05:43:20 17:43 »
after install use this fixed to fix invalid file for mastercam x3
http://rapidshare.com/files/150301420/MastercamX3_crk_fixed.rar.html
jesse
-Receive: 101
« Reply #6 on: December 05, 2008, 05:41:51 05:41 »
    Here's the first update for Mastercam X3:
      _http://updates.mastercam.com/x3/mu1/mastercamx3-mu1-web.exe
    Uses the same USB Emulator as X3.
   Here's the Crack:
     Saludos
pjve64
« Reply #7 on: December 12, 2008, 09:26:21 09:26 »
To which USB emulator are you referring, can you post this can you post it because I can't find it.
