April 16, 2026, 05:28:47 05:28
Author Topic: Recommend a good ATMEL ISP programmer  (Read 6351 times)
covert
« on: July 15, 2008, 03:02:30 15:02 »
Can someone recommend a well supported ATMEL programmer. Well supported in different chips it can program and also compatible with some of the great programs in this forum Smiley
cluoiset
« Reply #1 on: July 15, 2008, 06:51:18 18:51 »
Hi!
I recommend Ponyprog. It is very easy to build.You can install all the components in the connectors casing.
The only bad thing with is, that is a bit slow.
www.lancos.com
Good luck.
Cluoiset
raviraj
-Given: 82
« Reply #2 on: July 16, 2008, 04:30:50 04:30 »
HI all,  Smiley
i done lot many programmer for AVr, but finally i was happy using AvrOspII programmer . goto avrfreaks website for further details.
samir
-Given: 27
-Receive: 21
« Reply #3 on: July 16, 2008, 01:02:38 13:02 »
Use Jtag ice clone both free and commercial version are available on net
covert
« Reply #4 on: July 16, 2008, 01:11:38 13:11 »
The ponyprog gives me compatibility over a lot of devices
vs
The jtag ice gives me features like jtag debugging ?
If so I might get both Smiley
firewalker
-Given: 19
-Receive: 88
« Reply #5 on: July 17, 2008, 12:15:49 12:15 »
I am using the one bellow. I am very satisfied with it.
http://www.tuxgraphics.org/electronics/200705/article07052.shtml
edi14_10
« Reply #6 on: July 19, 2008, 05:54:20 05:54 »
You can try avr-doper. here is the link: http://www.obdev.at/products/avrusb/avrdoper-de.html
eoasap
-Given: 39
-Receive: 43
« Reply #7 on: July 28, 2008, 07:20:20 19:20 »
The problem with JTAG is that not all AVR microcontrollers support it. I would recommend staying with something STK500/AVR-ISP compatible for maximum device compatibility.
I have modified a version of the AVRUSB for my programmer.
http://www.tuxgraphics.org/common/src2/article05101/avrusb500_circuit_v2.pdf
I actually have both a JTAG and AVR-ISP on the same programming board, with three headers for each.
1) traditional 10-pin header (stk500 compatible)
2) 6-pin header (stk500 compatible)
3) 6-pin single inline to program DIP packages on breadboards easier
anatom
« Reply #8 on: July 29, 2008, 08:10:20 08:10 »
Why not using AVR Dragon? Cheap and efficient... Wink
