April 11, 2026, 09:14:17 21:14
Author Topic: Req :1 Hz square wave generator  (Read 6555 times)
samir
-Given: 27
-Receive: 21
« on: June 05, 2008, 07:01:06 07:01 »
Hi friends
Any one know how to generate 1Hz Square wane,has to be stable, accurate against time and temperature Drift using crystal.
Thanx in Advance
wessoms
-Receive: 44
« Reply #1 on: June 05, 2008, 08:40:25 08:40 »
Need a little more information.
What do you mean by stable?  Accurate to .00000000001hz / year etc.
Do you care what the base crystal is? Generally you start with a hi freq / low ppm < 20 then divide down.
Drive strength of the output?
Edge slew rate ?
What temp range ? -45C to 105C , etc....
Fill in as much information and you will get some great hepl. This board is viewed by a lot of smart people but we need more information to help.
zuisti
-Given: 242
-Receive: 780
« Reply #2 on: June 05, 2008, 08:53:34 08:53 »
...how to generate 1Hz Square wane,has to be stable, accurate against time and temperature Drift using crystal
Use a simple and cheap analog quartz clock. Its 'power' outputs (for the coil) are usable as a high accurate 2 hz pulse generator. After a level interfacing (if needed), use a simple divide by two circuit (a flip-flop) to get a simmetrical 1 hz pulse.
If you needed a much more accurate signal, use a little 'thermostat' for the clock's PCB to eliminate the temperature drift.
The long time drift is an other problem, my idea: use an old (long-used) clock device.
An idea only...
flash65
« Reply #3 on: June 05, 2008, 09:09:21 09:09 »
if you want high accuracy and precison. you need a gps disciplined clock. this is some link:
http://www.g7ltt.com/10mhz/
http://www.qsl.net/zl1bpu/MICRO/GPSCLOCK/
Sun_rise_pt
-Given: 87
« Reply #4 on: June 05, 2008, 09:37:41 09:37 »
Try with  a  electronic circuit of cheap chinese clock. I think if you make stable the quartz temperature the precision are aceptable. You get the square wave on  output for motor coil.
jzaghal
-Given: 508
-Receive: 55
« Reply #5 on: June 05, 2008, 12:58:01 12:58 »
You can use a CD4060 with a 32Khz crystal to get a ccurate 2HZ, then just use a FF to divide by 2.
Final result depends  on Xtal.
Bye.
