April 26, 2026, 12:06:44 00:06
Author Topic: using arrays in both main.c file and other.c files for same project  (Read 5164 times)
bugmike25
-Given: 15
« on: May 16, 2008, 01:54:42 13:54 »
Hi all. I'm having a problem with compiling my program because i want to use the same array inboth my main c file and my other c file.
Example: main.c
#include <absacc.h>
#include <stdio.h>
#include <SPI.h>
#include <DS1305.h>
#include <SDcard.h>
unsigned char rdat[12]; //To be used in main.c and SDcard.c
However if i declare it in both i get an error: Multiple public definitions
and if i declare it in only 1 of the two the compiler thinks that the array is undefined in one of them.
Please help me out. Can i solve this problem by defining the array in the SDcard.h file instead or any other solutions??/
zorx
-Given: 48
-Receive: 163
« Reply #1 on: May 16, 2008, 02:58:17 14:58 »
You have to use extern , like this:
main.c
#include <absacc.h>
#include <stdio.h>
#include <SPI.h>
#include <DS1305.h>
#include <SDcard.h>
SDcard.c
extern unsigned char rdat[12]
In SDcard.c this means that rdat[12] is externaly defined (in this case in main.c) and can be used across files.
Hope that this works.
bugmike25
-Given: 15
« Reply #2 on: May 16, 2008, 06:11:18 18:11 »
Thanks it worked. Didn't know it was that simple.
YellowTiger
« Reply #3 on: May 19, 2008, 05:58:37 17:58 »
There's the way to declare all the related vars just once:
"MySDLib.h"
// here follows block of SD-related variables declarations:
#ifndef  _SD_Card_Lib_
  #define  _SD_DefArea_ extern
#endif
_SD_DefArea_   int   iVar1;      // all SD-related variables are declared just once, all in one place - this will ease the control over the code and variables
_SD_DefArea_   char   cVar2;      // ...
_SD_DefArea_   unsigned char rdat[12];   //
#undef  _SD_DefArea_
"SDLib.c"
#define  _SD_Card_Lib_   // this will turn extern OFF
#include <MySDLib.h>   // all SD-vars will be declared as usual
// SDLib functions follows...
"main.c"
// #define  _SD_Card_Lib_   // omitting this #define will turn extern ON
#include <MySDLib.h>   // all SD-vars will be declared as external
LabBoy
« Reply #4 on: May 23, 2008, 12:43:28 12:43 »
yor can share global variable(s) in other files by using "extern"
for example
//-------[file A.C]--------
char arr[10];
//-------[file B.C]--------
// if you want to access arr in file A.C, you can  declar in the top of file B.C
extern char arr[10];
