April 29, 2026, 10:30:55 10:30
Author Topic: 33V from 12V Converter  (Read 8878 times)
aslan_korhan
-Receive: 60
« on: May 17, 2006, 06:14:34 06:14 »
telfo2007
-Given: 8
« Reply #1 on: November 21, 2007, 10:00:53 22:00 »
Hi friend
What you need is a DC-DC upconverter. Try with some examples from Maxim IC's portfolio. They have a huge amount and perhaps you can get some sample from them.
I hope this help you.
Bye.
-Given: 499
« Reply #2 on: November 21, 2007, 10:19:56 22:19 »
Great, so what is the question or the informations that you want to post?
you want to make one?
you have make one and wnat to share the technique?
you want to start a discussion about one?
hmm..
mris99
-Given: 8
-Receive: 16
« Reply #3 on: November 23, 2007, 10:31:51 22:31 »
You should also check National ICs.
Here you find a selector guide:
http://www.national.com/appinfo/power/webench.html
You enter your requiroments and the tool recommend you some of
the IC palette.
akutisarizar
« Reply #4 on: December 02, 2007, 08:45:59 20:45 »
Hi friend,
I dont know how much current are you require but if you need less current you need tv schematics to find how can u convert 33V from 12V . All tuner needs supplied by 33V most tv designer use circuit for as u need . If you can not find any tv schematic please feel free to contact with me .
Best Regards,
AnyAlex
-Given: 291
-Receive: 860
« Reply #5 on: December 03, 2007, 09:26:19 09:26 »
U out is > U in. Out max 35 V. C4=100nf. C5 & C6 is 470 mkf, U out is with Stab D2. I out max 15 A.
When R5=0.12 om then Out max=5 A. U in 7 V min and 15 V max. D1 Shottki-Diod.
PS. Shematic from Elektor.
Sample with out 15 V:
« Last Edit: December 04, 2007, 07:20:56 19:20 by AnyAlex » Logged
visn
-Given: 664
-Receive: 97
« Reply #6 on: December 04, 2007, 05:09:54 05:09 »
The usual use for 33V is for feeding a varactor for a VCO. When the voltage has spikes like this ( not a smooth dc signal) , how does it affects vco frequency? I have seen two other designs that use dc-dc to boost the voltage, and the philips 1216 tv tuner app note says that it has an integral 5v-to-33v convertor.
It may be millivolts ( the ripple) , but what does it do to the system in a pll synthesizer? Is this totally OT?
chithanh04dt2
-Given: 97
« Reply #7 on: December 05, 2007, 04:18:29 16:18 »
can you give for me your *.DNS (simulation with Proteus)
Sorry for my English.
Regard !
AnyAlex
-Given: 291
-Receive: 860
« Reply #8 on: December 07, 2007, 06:06:39 06:06 »
Removed. Lib for NE555-SA:
PS. When U out >20 V then R1=12 k.
neelandan
« Reply #9 on: December 10, 2007, 11:20:40 11:20 »
Here is a simple design using discrete components (would require tweaking the component values for the required 33 volt output).
http://www.romanblack.com/smps/conv.htm
Deep inside the carcass of a dead (short) circuit.
chen
« Reply #10 on: December 30, 2007, 06:49:31 18:49 »
if your 12V supply is of high current capacity and ur 33V application requires less current (approx 1/3 of 12V current) then u may try voltage tripler. its simple to contruct. it will give u around 36V. you will have to drop 3V using a zener or series res. depending on your current.
chen......
vayupak_01
« Reply #11 on: January 02, 2008, 06:21:06 18:21 »
step up converter
Boost topology dc-dc power supply that you choose
phophollety
« Reply #12 on: January 06, 2008, 11:07:58 23:07 »
You can try the MC34063 on the Datasheet there is from done circuits (current inverter, buck and boost) and also the equations to design your on easily..
mhtplsh
-Given: 46
-Receive: 61
« Reply #13 on: January 07, 2008, 06:38:11 06:38 »
http://sound.westhost.com/project89.htm
This is a project for car audio.
But u can modify it as required.
There is full details about circuit, Hence easy to customise it.
chithanh04dt2
-Given: 97
« Reply #14 on: January 11, 2008, 01:57:33 13:57 »
Thanks and you can give me file you simulation
Regard !
AnyAlex
-Given: 291
-Receive: 860
« Reply #15 on: January 15, 2008, 08:53:04 20:53 »
...you can give me file you simulation
Dear chithanh04dt2!
A new korrected Simulation 12 V to 33 V with DSN and Libs is belov.
I can't Symulate more than 1.25 A (use real FET Transistor). R4 ist 0.12 ohm (max 5 A).
Symulation with Proteus 7.2 SP2, Double Core CPU 2x2.4 ggc, 2 gg RAM (8 month old),
Animated Circuit Configuration/ Spice Option/ Interactive Symulation Options/ Transient
Number of Steps = 10, Frame per second 16.
AnyAlex.
PS. Ne555-SA is a Standart 555 with korrected Shematic.
« Last Edit: January 15, 2008, 09:02:48 21:02 by AnyAlex » Logged
irvinos
-Given: 31
-Receive: 28
« Reply #16 on: January 27, 2008, 09:44:19 21:44 »
Try MC34063A.
This is a usefull page for designers.
http://www.nomad.ee/micros/mc34063a/index.shtml
Posted on: January 27, 2008, 10:42:57 22:42 - Automerged
Try MC34063A.
