April 20, 2026, 08:47:49 20:47
Author Topic: Required Radan 3D  (Read 7173 times)
okk
-Given: 369
-Receive: 39
« on: May 08, 2008, 01:05:22 13:05 »
Doe's anyone know of a link for Radan 2D sheet metalwork software?
Radan 3D allows you to draw a sheet metalwork design in 3D and then flatten it for transfering to a CNC machine for manufacture, it does this whilst taking into account bending radiuses etc.
Maybe there is other software that can do the same?
drthilina
-Given: 19
« Reply #1 on: June 24, 2010, 04:09:57 16:09 »
You can try Solidworks too.. but it lacks CNC support. Or you can try Pro-E.. it is said it has everything inbuilt. but the downside is that it is soo damn hard to learn
Pegasus22
« Reply #2 on: June 24, 2010, 11:27:07 23:27 »
SolidWorks can be extended by 3rd party software to support CNC interface.
SolidCAM for example.
So you could unfold your model with SolidWorks and generate CNC data with SolidCAM.
Radan 3D looks very specialized to sheet metalwork. SolidCAM is more general, supporting custom post processing.
« Reply #3 on: June 25, 2010, 08:38:33 08:38 »
I saw this prog for sheet metal a while back, though I can't find a set of D/L links to post here -I  should have D/L'd it when I saw it :-(
Metalix cncKad:
cncKad is integrated with solid modelers such as SolidWorks®, Solid Edge®, Autodesk® Inventor®, Pro/ENGINEER® and Vertex G4®, therefore there is no need for any intermediate files such as DXF in order to transfer your projects to cncKad.
cncKad can read also DWG files directly from AutoCAD®, in addition to IGES, CADL, DXF and a few others formats.
Sheet Metal oriented commands make creating geometry in cncKad extremely easy.
You can easily validate your geometry with features simple in use, like Correction, Analysis and Modification.
cncKad offers a wide range of processing features – from manual tools giving you full control over the production, to efficient automated tools that save time and effort.
You can select the most accurate tool – from Auto Punch,
Auto Cut, Common Cuts for Punch and from Laser Common Cuts to Automatic Reposition and Automatic Clamp Avoidance, just to name a few.
After processing the part you will be able to create a Multi-Part Sheet with ease - simply by resizing the sheet and generating NC.
Macros are created automatically, unless you want a longer, but better optimized NC code.
In order to generate a nested sheet with assorted parts you can choose between Manual Nesting and an automated AutoNest Module, capable of creating Group Arrays with Macros.
As a last stage before machining, you can generate Job Reports in Word® DOC format, fully customizable to suit your needs."
