March 02, 2026, 08:52:42 20:52
Author Topic: Negative voltage and Level converter  (Read 4101 times)
inkognitous
« on: May 07, 2008, 08:35:37 08:35 »
Hi i need simple scheme of voltage inverter and step up convertor....I need from 5V transform 12-15V for led backlight of lcd.... Any idea?
vovchik02
-Given: 43
« Reply #1 on: May 08, 2008, 05:28:50 05:28 »
DC-DC convertor RH-0512 , AM1D-0512S (1W) or analog 1case 4 pin (more simpl? Grin) or GOOGLE.
pl4tonas
-Given: 330
-Receive: 196
« Reply #2 on: May 08, 2008, 06:37:43 06:37 »
Try a search in the national semiconductors' site.  Other manufacturers like Maxim and Linear Techn. have a good range of ics.
Some IC numbers are LM3410, MAX668, LT1070, LT1071...
I use the LM3410 and it is very nice, it can deliver 350 mA without any problem (even more mA).  Find the circuit diagram from the datasheets.
Also the LT107X series is very simple to use.
Here you can find the diagram of my design.
4-6V input and 9 to 17V output, constant current, (with R3 0.5Ohms it gives 380mA).
Output current is I=190mV/R3.
http://rapidshare.com/files/113360888/5V_to_9-17V_constant_current_converter_for_LED.jpg
P.
« Last Edit: May 08, 2008, 06:45:04 06:45 by pl4tonas » Logged
