April 11, 2026, 10:46:03 22:46
Author Topic: RC5 code  (Read 11655 times)
nileshhande
-Given: 23
« on: May 06, 2008, 11:22:57 11:22 »
hi all,
want to control few relays via infrared remote control: some latch,some momentry and some timer based..and 1 port PWM if possible
thanks...
mississippi1
« Reply #1 on: May 06, 2008, 04:22:40 16:22 »
That should be no problem with a PIC16F628a.
PBP is than also the right language for this problem.
nileshhande
-Given: 23
« Reply #2 on: May 07, 2008, 07:38:44 07:38 »
Thanks..can i have the project detals.(schematic and code)
thanks a lot.
maddoc
-Given: 49
-Receive: 14
« Reply #3 on: May 07, 2008, 08:39:59 08:39 »
Here is an extract from Proton IDE, basic compiler, found on this forum.
You just have to put next to the PIC an IR receiver like rpm71xx or tsop48xx (xx stands for IR frequency, go for 40 with RC5 codes).
RC5IN 12 14 16
Syntax
Variable = RC5IN
Overview
Receive Philips RC5 infrared data from a predetermined pin. The pin is automatically made an input.
Operators
Variable - a bit, byte, word, dword, or float variable, that will be loaded by RC5In. The return data from the RC5In command consists of two bytes, the SYSTEM byte containing the type of remote used. i.e. TV, Video etc, and the COMMAND byte containing the actual button value. The order of the bytes is COMMAND (low byte) then SYSTEM (high byte). If a byte variable is used to receive data from the infrared sensor then only the COMMAND byte will be received.
Example
  Device = 16F628A
 RC5IN_PIN = PORTC.0                         ' Choose the port and pin for the infrared sensor
 DIM RC5_WORD as WORD                        ' Create a WORD variable to receive the data
 DIM RC5_COMMAND as RC5_WORD.Lowbyte         ' Alias the COMMAND byte to RC5_WORD low byte
 DIM RC5_SYSTEM as RC5_WORD.Highbyte         ' Alias the SYSTEM byte to RC5_WORD high byte
 ALL_DIGITAL = ON                            ' Make all pins digital mode
 Cls                                         ' Clear the LCD
 While 1 = 1                                 ' Create an infinite loop
  Repeat
    RC5_WORD = RC5In                         ' Receive a signal from the infrared sensor
  Until RC5_COMMAND<> 255                    ' Keep looking until a valid header found
  Print at 1,1,"SYSTEM  ",Dec RC5_SYSTEM," "  ' Display the SYSTEM value
  Print at 2,1,"COMMAND ",Dec RC5_COMMAND," " ' Display the COMMAND value
 Wend
Declares
There is a single Declare for use with RC5In: -
DECLARE RC5IN_PIN PORT . PIN
Assigns the Port and Pin that will be used to input infrared data by the RC5In command. This may be any valid port on the PICmicro.
If the Declare is not used in the program, then the default Port and Pin is PORTB.0.
Notes
The RC5In command will return with both COMMAND and SYSTEM bytes containing 255 if a valid header was not received. The CARRY (STATUS.0) flag will also be set if an invalid header was received. This is an ideal method of determining if the signal received is of the correct type.
RC5In is oscillator independent as long as the crystal frequency is declared at the top of the program. If no XTAL Declare is used, then RC5In defaults to a 4MHz crystal frequency for its timing.
DINESHjp
« Reply #4 on: August 23, 2008, 02:14:46 02:14 »
i think  rc5in is not a valid command in proton ide
-Receive: 4459
« Reply #5 on: August 23, 2008, 07:49:24 19:49 »
Yes it is
----------------------------from the Help file------------
RC5IN
Syntax
Variable = RC5IN
Overview
Operators
Example
 Device = 16F877
 DIM RC5_SYSTEM as RC5_WORD.Highbyte         ' Alias the COMMAND byte to RC5_WORD high byte
 Cls                                         ' Clear the LCD
  Repeat
 Wend
Declares
Notes
See Also
SONYIN
DINESHjp
« Reply #6 on: August 24, 2008, 01:05:41 01:05 »
i once again search the command rc5in in help also but it is not available
i am using proton+basic compiler downloaded from this forum. ide version 1.0.0.1
and compiler version 2.2.0.20
-Receive: 4459
« Reply #7 on: August 24, 2008, 11:12:00 11:12 »
Your way out of date with Proton IDE
ide current ver 1.0.4.6
compiler current version is 3.2.5.5
DINESHjp
« Reply #8 on: August 25, 2008, 12:55:15 00:55 »
where can i download this version , there are so many version that i am confused, so plz help me
Ahmad_k
SCG Moderator
-Given: 179
-Receive: 1299
« Reply #9 on: August 25, 2008, 04:22:45 16:22 »
Take this :
Proton IDE 1.0.4.6 and Compiler 3.2.5.5
http://www.sonsivri.com/forum/index.php?topic=4267.msg21417#msg21417
ABBOSE
-Receive: 21
« Reply #10 on: October 15, 2008, 03:12:27 15:12 »
Hi nileshhande
for infrared remote control see http://amateurworld.in/sd_4/3%20channel%20IR%20remote%20control.html
nileshhande
-Given: 23
« Reply #11 on: October 16, 2008, 04:45:55 16:45 »
HI, Thanks..Good explanation, Source code is in Assly, Basic code would have helped a lot..Thanks lot..
