March 07, 2026, 03:42:26 03:42
Author Topic: is it possible to make a pic32 starter kit ?  (Read 14747 times)
omidsht
-Given: 60
-Receive: 16
« on: April 25, 2008, 05:18:21 17:18 »
hi ,
is it possible to make a pic32 starter kit by own ?
i bought one and in the pdf files there is the schematic of it , but i need the hex file of the pic which is on the board!
omid
-Given: 858
-Receive: 4451
« Reply #1 on: April 25, 2008, 09:12:01 21:12 »
Quick answer yes
only problem the front end drivers ie. the exe files to program the piv32 & debug, The sample files are not down loadable from Microchip site, only manuals & data sheets(pdf) no soruce zip files
1. U1. a 4550 is a ICSP like a pickit2 you could read the chip via J3. (can't see Microchip protecting code)Front end will allow update and replacement of a corrupt bootloader.
2. to program the pic32 RC0 puts it in program mode.
3. RB0 & RB1 supply Data & Clock
you would need the data sheet for the pic32 to see how a bootloader is used.
I think most people would just use a sample board.
omidsht
-Given: 60
-Receive: 16
« Reply #2 on: April 26, 2008, 12:05:31 12:05 »
Quick answer yes
i have got a sample board but the reason that i want to build my own is :
i have no connector or board for expansion connector , and i cant use rs232 , adc , dac , .... . i can just load the game and see the leds blink!
omid
Anunakin
« Reply #3 on: February 01, 2011, 05:06:00 17:06 »
Any here have success on build a PIC32 board? My PicKit2 cant detect my board, I using a PIC32MX795...
-Given: 238
-Receive: 1050
« Reply #4 on: February 01, 2011, 06:34:15 18:34 »
Take a look here http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en027813
As you can see your Pickit 2 do not support your device. You have to get a PICKIT 3 in order to program your chip (I think).
Anunakin
« Reply #5 on: February 01, 2011, 08:20:17 20:20 »
Thanks!
I found there is a PK2DeviceFile.dat (pk2cmd) editor here:
http://www.microchip.com/forums/m473925-print.aspx
And need add it to .dat file:
First duplicate item PIC32MX460F512L from the parts list then change to these
settings:
PartName: PIC32MX795F512H
DeviceID: 0x0000E000
ProgramMem: 0x00020BFC
For PIC32MX795F512L
PartName: PIC32MX795F512L
DeviceID: 0x00007000
This works now...  Grin
« Last Edit: February 02, 2011, 02:05:00 14:05 by Anunakin » Logged
Anunakin
« Reply #6 on: February 24, 2011, 12:47:51 12:47 »
I made my own PIC32 kit! with a PIC32MX795 sample and a TQFP 100 adapter, spent about U$ 1.50 !  Grin
I using USB HID Bootloader from UBW32 and Pinguino32X (svn restrict version), compiler is C32 all Linux env.  Tongue
more here:
http://www.vivaphp.net/2011/02/pinguino32x-minimum.html
Old_but_Alive
-Given: 832
-Receive: 122
« Reply #7 on: February 24, 2011, 02:53:29 14:53 »
wow !!
where did you get a TQFP 100 adapter for $1.50.
they seem to be $15.0 here in the UK
Mike
gan_canny
-Given: 101
-Receive: 26
« Reply #8 on: February 24, 2011, 03:53:32 15:53 »
The link in the post referencing the $1.50 price links in turn to www.futurlec.com which is where to order them
Old_but_Alive
-Given: 832
-Receive: 122
« Reply #9 on: February 24, 2011, 04:50:46 16:50 »
@gan_canny
@ Anunakin
many thanks, I had assumed that the link was just for the software.
I just ordered a selection of adapter pcb's, $39.
Mike
