October 20, 2025, 09:17:36 09:17
Author Topic: sms send sht11 pic16f876 nokia 6210  (Read 8997 times)
websezgin
« on: April 23, 2008, 11:35:46 11:35 »
Hello friends.Please could you help me.
How can I send sms with sht11 and pic16f876.I want send sms alarm of
temperature and humidity with nokia 6210.If under or on regulated alarm of the temperature or humidity ,nokia 6210 send sms me.
How can I make this circuit and pic software.
The sample with regulated alarm thermometer and humidity circuit is this on
address.http://img.fotoambar.com/img/5/ee15d...149fe6a2e5.jpg
Circuit explanation :
The alarm is open,ISI(temperature) ALT(under) and ISI(temperature) UST(on)
with NEM(humidity) ALT(under) and NEM(humidity) UST(on)
between outside.Two between alarm is closed.
Sample : If alarm 23 - 20 between,alarm is closed.If humidity and temperature 19 or 24 alarm open.
http://img.fotoambar.com/img/5/ee15decb5a78ee50f995fe149fe6a2e5.jpg
http://dosyayukle.info/index.php?p=download&link=1242889961&name=pic16f876.asm
alspa
« Reply #1 on: May 14, 2008, 05:51:58 05:51 »
websezgin,
6210 uses fbus protocol on the connector at bottom of phone. You can program the pic uart to talk directly with the phone without needing any max232 or similar conversion chips. The protocol is not public from Nokia but is pretty well documented by gnokii etc. Here is a link to a project website
http://www.embedtronics.com/nokia/fbus.html
Cheers,
Alspa
major_pain
« Reply #2 on: May 14, 2008, 08:46:15 08:46 »
You could use AT commands to send sms using 6210, downside is you have to use a dlr3p cable.  You can make your own cable by following the schematics from http://www.atrox.at/datacable/dlr3/index.html
reference on talking with the sht11
http://www.sensirion.com/en/pdf/product_information/Data_Sheet_humidity_sensor_SHT1x_SHT7x_E.pdf
sakibnaz
« Reply #3 on: August 07, 2008, 11:55:56 23:55 »
Hello Everyone.
I am a STD of EEE & I am in trouble with my final year project.
I am doing a project using AT command in 6680 phone.I can simulate my project using Proteus_7.1 interfacing my 6680 with a microcontroller virtually.
Here I am using the RX,TX & GND pin of Nokia POP Port connected via USB including Nokia connectivity cable driver.
But the problem is, I cant communicate with my 6680 by microcontroller in real time.Here I need to active the POP Ports RX TX pin (FBus) without Nokia cable Driver.Is there any command to enabe the FBUS???
I know that for Nokia 3310 I need to send 128 times 'U' char that is 0x55 in HEX to initialize FBUS.But I dont know the FBUS activation command for my Nokia 6680.
PLZ help me out on this problem.Thanx.
Note:
1.Whenever I connect my 6680 to PC via USB then i see a sign of USB connection in my 6680 screen due to cable driver.
2. But this sign does not appear when I connect the phone with microcontroller.
Very sorry for my bad English.
.::sakibnaz::
