March 12, 2026, 10:20:20 10:20
Author Topic: programmer for 89c52  (Read 13661 times)
britto3769
« on: April 20, 2008, 10:05:16 22:05 »
i am needing a usb programmer schematic for 89c52 from atmel, someone can help me?
trace
« Reply #1 on: April 24, 2008, 11:53:15 23:53 »
http://www.kmitl.ac.th/~kswichit/89prog/index.html
PS: You will need a working programmer to load firmware
And these are the other circuits that i have found:
http://www.rob-vassar.com/electronics/AT89S52/Atmel_AT89S52_FLIP_Interface.html
http://www.batronix.com/electronic/circuits/mc-programmer-2.shtml
pphongvee2
-Given: 22
« Reply #2 on: April 26, 2008, 04:42:08 16:42 »
go to www.8052.com ,it have serveral of 8051 MCU famiry
spicysurya
« Reply #3 on: August 04, 2008, 08:36:12 20:36 »
yes here u can get the programmer
http://www.electronics-lab.com/
ROC
« Reply #4 on: August 07, 2008, 05:29:58 17:29 »
Needed C52 only? Can use AT89S52? It's  some as AT89C52, but can ISP programming with many programmers - STK500, Chameleon http://www.atprog.boom.ru/Sindex.html (russian)
abd elwahab
« Reply #5 on: August 12, 2008, 01:51:24 13:51 »
hi ,everyone I think you can use FT232/FT245 with any simple serial programmer
it only requires small componnent to convert USB into rs232/parallel fifo
refering to the datasheet of ft232
phucthinhel
« Reply #6 on: March 21, 2009, 08:09:26 20:09 »
If you live in VietNam you can visit http://phucthinhel.googlepages.com
zawmintun1
-Given: 2315
-Receive: 26
« Reply #7 on: May 01, 2009, 02:46:40 14:46 »
Hi All
I needs SCH of Programmer & Software for SyncMOS's <SM8952> microcontroller
Please tell me Links or Other ideas
Thank to All
ficho
« Reply #8 on: May 01, 2009, 08:47:56 20:47 »
S series can be easyly programmed but not C series
but 89S52 compared to 89C52 are almost the same... code for C52 can be programmed to S52 with no problem
regards ficho
