April 28, 2026, 12:33:11 00:33
Author Topic: Proteus Pdf Layout ????  (Read 15955 times)
Rego
-Receive: 320
The power is back
« on: May 11, 2006, 06:57:00 18:57 »
ANY ONE GOT A GOOD (VERY ACCURATE) METHOD FOR EXPORTING PROTEUS
LAYOUT INTO " PDF "  HuhHuh :confused:
Smiley ....THE POWER IS BACK.... Smiley
....REGO....
fmssp
-Given: 42
-Receive: 109
« Reply #1 on: May 11, 2006, 08:11:36 20:11 »
Hi rego!
I use "pdfFactoryPro" for export from Proteus ISIS to *.pdf
http://fmssp.nm.ru/Photo/RC3.pdf
Sorry for bad english
From Russia with love... ;-)))
Rego
-Receive: 320
The power is back
« Reply #2 on: May 11, 2006, 08:18:35 20:18 »
Is It Accurate  For Layout Printing Huh?
....REGO....
fmssp
-Given: 42
-Receive: 109
« Reply #3 on: May 11, 2006, 08:28:48 20:28 »
Yes. 0,3 mm clearance board - Ok!
Rego
-Receive: 320
The power is back
« Reply #4 on: May 11, 2006, 08:37:56 20:37 »
And Should I Just Use (print) From Output Menu Directly .. Or There Are Any
Certain Other Settings To Configure Huh
....REGO....
fmssp
-Given: 42
-Receive: 109
« Reply #5 on: May 11, 2006, 08:54:48 20:54 »
No other settings . Only Proteus menu.
Output\Set Output Area
Output\Set Output Origin
Output\Print ->printer select  "pdfFactory", select layers, Scale 100%, Normal\mirror and Press "Ok" ->  Preview pdf -> press "Save"
Rego
-Receive: 320
The power is back
« Reply #6 on: May 11, 2006, 09:03:43 21:03 »
Thanks Man.....
I 'm Gonna Test The Results Now......
Hope It Works For Me.......
....REGO....
fmssp
-Given: 42
-Receive: 109
« Reply #7 on: May 11, 2006, 09:11:44 21:11 »
Success!
stevetwc
« Reply #8 on: May 11, 2006, 09:32:40 21:32 »
Hi Rego, just print to any soft PDF printer and it should works. When you print out from the PDF file, make sure you select Page Scaling to "None". I been using Adobe Acrobat PDF printer and it is definitely accurate.
Rego
-Receive: 320
The power is back
« Reply #9 on: May 11, 2006, 09:46:54 21:46 »
Quote from: SteveChong
USING ACROBAT PDF PRINTER NOT WORKING FOR ME.....
I USE ACROBAT READER PRO (NOT ACCURATE)
....REGO....
rmmrmm
-Receive: 24
« Reply #10 on: May 11, 2006, 09:56:31 21:56 »
I“m using Pdf Creator ( http://sector7g.wurzel6.de/pdfcreator/ ) , is a free software to generate a virtual printer .
It converts any printing in a PDF file , and then you can printing anywhere.
I don“t have a laser printer , so I have to print my boards in other place.
I hope It  works for you too.
Rego
-Receive: 320
The power is back
« Reply #11 on: May 11, 2006, 10:06:53 22:06 »
Sorry Friends......
But Both Methods Didnot Work For Me....
....REGO....
goktug
-Receive: 23
« Reply #12 on: May 11, 2006, 11:20:35 23:20 »
rego you have to use adobe Acrobat 7 pro (full ) .
stevetwc
« Reply #13 on: May 12, 2006, 02:13:00 14:13 »
Hi Rego, when I wrote Adobe Acrobat, I mean the Adobe Acrobat full version, not the Adobe Reader. Note there are no more Adobe Acrobat Reader, the new version is called Adobe Reader.
I been using the latest full professional version of Adobe Acrobat 7 software printer. Try configuring the software printer settings prior to printing (Control Panel-->Printers and Faxes-->Adobe PDF) and make sure you print with "Page Scaling = None".
Hope it works for you. Cheers.
morpheous
« Reply #14 on: May 12, 2006, 06:44:56 18:44 »
check this out
http://www.primopdf.com/
tavioman
« Reply #15 on: May 13, 2006, 04:46:01 16:46 »
Don't use Acrobat Reader Pro just Adobe Acrobat PRO.
I'm making all my desings with this. And it's just perfect.
Good luck!
- Brain juice -
tavioman
« Reply #16 on: May 13, 2006, 04:48:24 16:48 »
Another goot method is to use the Gerber outputs.
Load them in GerbView or GerbTool(the best) and then use an usual laser printer.
This is the most recommendet method since you are working directcly with Gerber files.
- Brain juice -
Rego
-Receive: 320
The power is back
« Reply #17 on: May 14, 2006, 08:54:07 08:54 »
will freinds,i already used acrobat pro,but when i print the layout i got about 1 mm shift error,
before i open this all thread i tried acrobat pro and primo pdf and and..... soi tried them all....
but istill got that stupid 1 mm shift ,it make me crazy......
for tavioman
yes ,i agree with u the cad cam tool and gerber tools are the best and accurate things ever and i always been working with them ,and they give me a great resault always.....
but the point from all this i want to know why this stupid acrobat pro give me that 1 mm error Huh??
....REGO....
stevetwc
« Reply #18 on: May 14, 2006, 03:31:27 15:31 »
Did you make sure you use the correct paper size for printing to the soft printer and print out from the PDF, and that the printout is not scaled up or down? And also the Proteus ARES output is set to 1:1 with no compensation, etc?
jeanninemtv
-Given: 57
-Receive: 25
« Reply #19 on: May 14, 2006, 08:49:53 20:49 »
I used the pdf trick and works fine !!
But i dont have tried with routes very little, like smd routes !!
I use the maximum of resolution on dpi to achieve best results
The PDF gives me por portability to print the layout in any printer just having acrobat !!
thxs rego
