April 29, 2026, 10:37:41 10:37
Author Topic: Help for load cell  (Read 5683 times)
Ario
« on: May 11, 2006, 08:01:53 08:01 »
Dear Masters
I have bought a load cell(made in china) without any datasheet and this is the
only data that i could get from seller in a very small piece of paper!
1-capacity(kg): 60
2-Thread Type : M
3-Calibration Mode :Compression
4-Sensitivity: 2+-0.2mv/v
5-Input Impedance : 415+-15 ohms
6-Output Impedance : 350+-3 ohms
7-Insulation Resistance >2 G Ohms
8-Test excitation : 10v DC
9-Zero Balance <+-3% of cn/k
10-Total Error : 0.020% of cn/k
11-Non Repeatibility : 0.010% of cn/k
12-Zero Return : 0.023% of cn/k
13-Temperature effect on zero : 0.0035% /C
14-Temperature effect on Sensitivity : 0.0014% /C
15-Compensated Temperature : -10~+40 C
16-Safe Temperature : -25~70 C
Cable Color Code
Red=+Excitation
Green=+signal
White=-Excitition
Blue=-signal
Can anybody help me to find out this specifications?Is there any complete project for load cell interfacing with a micro controller such as avr or pic or ...? Sad
sfiga69
-Given: 211
-Receive: 163
« Reply #1 on: May 11, 2006, 02:42:45 14:42 »
look this:
http://www.cirrus.com/en/pubs/appNote/an36.pdf
http://www.aeroconsystems.com/electronics/load_cell_primer.pdf
http://www.linear.com/pc/downloadDocument.do?navId=H0,C1,C1155,D6637
http://www.cirrus.com/en/pubs/appNote/an31.pdfSmiley
Bye
« Last Edit: May 11, 2006, 02:45:14 14:45 by sfiga69 » Logged
vayupak_01
« Reply #2 on: January 02, 2008, 07:20:57 19:20 »
Hi sfiga, Are you have any schmatic for some digital scale?
dekor
« Reply #3 on: January 14, 2008, 11:56:04 11:56 »
do you have any schematic for a device to check load cell?
Please share with us .
Thanks,
dekor
FriskyFerret
-Given: 513
-Receive: 360
Put it in, take it out.
« Reply #4 on: January 14, 2008, 12:31:40 12:31 »
You already have all the specifications. You just have no idea what to do with them. You need to understand load cells, how to excite and signal condition them, and how to apply them mechanically. Time to learn.
kareemsa
« Reply #5 on: January 14, 2008, 02:00:32 14:00 »
Hello Ario,
What you are having is the exact specification of the loadcell,
what i understand is that you don't how to check.
I shall help you check the loadcell.
Do exactly as mentioned.
Apply 5 Volts DC between, red & white wire of the loadcell cable
                         Red=+Excitation & White=-Excitition
Connect a multimeter in the millivolts range between, Green & Blue wire of the loadcell cable
                          Green=+signal & Blue=-signal
Now apply the load on to the loadcell approximately 10Kgs, the multimeter should read approximately 1.66millivolts.
Then place 20Kgs load the multimeter should read approximately 3.33millivolts.
And now place 30Kgs load the multimeter should read approximately 5.00millivolts.
The readings on the multimeter should be linear as you are increasing the load linearly.
Remember the output is always in millivolts.
Since you are exciting the loadcell with 5VDC and applying only 10Kgs load on to the loadcell you will get only 1.66millivolts the output .
The calculation is as under
Sensitivity is 2mV/V, Capacity is 60Kgs, & the Excitation is 10VDC
    Sensitivity X Excitation /Capacity X applied load = millivolts output.
    i.e.  Ex1 :  2x10/60X10Kgs = millivolts output
    i.e.  Ex2 :  2x 5/60X10Kgs =  1.66millivolts
Hope this is clear to you in case of further ambiguity post your request on the forum shall try to address the same.
Alienbeing
-Given: 68
-Receive: 45
« Reply #6 on: January 15, 2008, 03:56:13 03:56 »
Hi, kareemsa is correct as I use Loadcells everyday at work along with a National Instruments data acquisition system. I just wanted to note here that doing a calibration of the loadcell with known identical value weights is how I calibrate my 40 lb. loadcells. After taking 10 measurements and record the voltages as I add weights I then run a linear regression analysis on the measured values to get my final sensitivity.
This is the way I was instructed to get a more accurate sensitivity for the loadcell. Also using calibrated weights is ideal.
Alienbeing
