April 21, 2026, 08:50:18 20:50
Author Topic: Can you figure out the fuss here? (CCS compiler)  (Read 5012 times)
OleRuffo
-Given: 36
« on: April 03, 2008, 12:39:24 00:39 »
Hi crew:
I was working with some more interesting computing and a PIC16F716 ( mid range device)
so i enter this dummy code to create a sensor value fair easy but..lets see:
int msb,lsb; //obvious use
signed int16 word16; //you can bet what will happen here
float fword; //complicating the things
char result[5]; //yup thats the goal
void main()
 //since i have no attached sensor here lets put some dummy data
msb=0xff;  //in theory captured from the sensing device
lsb=0x1a; //same
word16=make16(msb,lsb); //now i have the whole thing joined
if (msb> 128)      // if the MSBit of the MSByte is 1 then we have a negative number
     word16=~word16 +1 ;  // I make a two's complement of the number to get the number i need same as word16=word16-0x10000
 //now the part that dont work
   fword=word16 * 0.0625;  //this simple operation would get rid of the entire problem...but something fails here
 //now put this into the string
  sprintf(result,"\f%5.1f",fword);
This lil code sounds easy, i get the -230 that should have in word16
but the time i do that simple multiply than i get a real weird value (-4.91112136e-032)
so the whole nice code goes ruined...the espected result is -14.375 (but i need to be displayed just -14.3 or -14.4, hence the 5.1 format)
surely I'm doing something real bad, but i can't catch the issue here.  Roll Eyes
Some input will be more than appreciated, for the interest and knowledge of all   Grin
Cheers
TigerX
« Reply #1 on: April 03, 2008, 08:12:07 08:12 »
Merhaba... (Hello...)
Your code has the wrong statement as you said as follows:
The wrong part is "word16" because
So, "world16" is an unsigned integer. Then if you multiply an integer by a float constant, the result is an integer not float. You must change the types or you must make type conversion like these:
Solution 1:
float fword,world16; //complicating the things
then your code will run truely.
Solution 2:
Your all code will be used only  one statement will be changed like these:
fword=(float)word16 * 0.0625;
Then your code also run truely again.
These are the tricky point of program writing in C...
Have a nice codes... Cheesy
Selamlar...
Eyüp
OleRuffo
-Given: 36
« Reply #2 on: April 03, 2008, 11:41:44 23:41 »
Great!
Both solutions gives the right answer! seems that the solution 2 is more compact in memory usage.
Seems that i miss understood the ANSI C data book that i have, where
 FLOAT=INT *FLOAT instead than INT=INT*FLOAT    Shocked
here my confusion, and thanks to you, real solved.  Cheesy
I think that is great to post this kinda doubts and clever answer like yours  so averybody can learn something about C or PICS or whatever! by now i will remember this forever  Wink
Have a great day!
Cheers
