April 28, 2026, 05:07:02 05:07
Author Topic: AVR XMEGA  (Read 12894 times)
mculove
« on: March 27, 2008, 02:39:24 14:39 »
# AVR XMEGA devices include:  2nd generation of picoPower technology
# Innovative Event System for fast, CPU independent inter-peripheral communication
# 4-channel DMA Controller boosts MCU performance
# 100% predictable timing
# Fast 12-bit ADC and DAC
# Fast Cryptography support for AES and DES
AVR XMEGA microcontrollers have the same acclaimed characteristics as the established AVR devices, and operates from just 1.6 volt with up to 32 MIPS at 32 MHz. Memory size range from 16 to 384 KB of Flash and they come in 44- to 100-pin packages. The XMEGA devices are general purpose microcontrollers well suited for a variety of applications including audio systems, ZigBee®, power tools, medical , board controllers, networking, metering, optical transceivers, motor control, white goods and any battery powered product.
  Is there any C or Basic compiler that support the new AVR XMEGA family ?
jestanoff
« Reply #1 on: March 29, 2008, 07:01:36 19:01 »
They aren't in a market yet. Look here:
http://www.sonsivri.com/forum/index.php?topic=11127.0
chrometsuba
-Given: 71
« Reply #2 on: March 29, 2008, 09:31:55 21:31 »
Beta version of avr studio has support for the xmega1280 chips
http://www.atmel.no/beta_ware/
paiboon
« Reply #3 on: April 02, 2008, 03:07:54 15:07 »
Winavr
WinAVR User Manual - 20080402rc1
Eric B. Weddington
<[email protected]>
WinAVR is a suite of executable, open source software development tools for the Atmel AVR series of RISC microprocessors hosted on the Windows platform. It includes the GNU GCC compiler for C and C++.
1.0 What's New
Below is just a sample of what's new.
Added support for these devices:
ATxmega128A1
ATxmega64A1
ATmega32M1
ATmega32C1
ATmega32U4
ATtiny167
GCC 4.3.0
New version.There are two new Makefile Templates added. One template will generate a library instead of an application (Makefile.lib) and the other template will enable whole program optimization (Makefile.wpo).
SRecord 1.38
New version.SimulAVR 0.1.2.5
New version.AVR-Ada is temporarily removed from this installation.
jestanoff
« Reply #4 on: April 02, 2008, 06:15:05 18:15 »
Support for Atmel AVR XMEGA
IAR Embedded Workbench V5.1 for AVR now supports the new AVR XMEGA device family from Atmel.
tom12sg
-Given: 36
-Receive: 12
« Reply #5 on: April 05, 2008, 03:44:04 15:44 »
  Xmega64A1, Xmega128A1, Xmega256A1
are supported in ICCV7.16 from ImageCraft.
an007
-Given: 53
-Receive: 51
« Reply #6 on: April 06, 2008, 09:23:25 21:23 »
Can some1 upload IAR Embedded Workbench V5.1 (EW-AVR V5.10 full kit)?
thanks,
//a
alberto110
-Given: 50
« Reply #7 on: December 24, 2010, 08:53:50 08:53 »
how can i find which xmega is 8 bit or 16 bit
Mega32
-Given: 273
-Receive: 37
« Reply #8 on: December 24, 2010, 11:33:26 11:33 »
How about reading the datasheet , for the desired Xmega MCU ?
But afaik all Xmegas are 8bit , like the "normal" megas.
Mega32
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #9 on: December 24, 2010, 01:26:24 13:26 »
Which programmer do I need to program XMEGA and UC3 AVR's ?
I didn't find any information on the homepage of ATMEL. If a JTAG ICE-mkII can
handle any of them, that would be very good.
However, the programmer should be cheap, not like the ATMEL products.
Many thanks in advance!
Greets DarkClover
alberto110
-Given: 50
« Reply #10 on: December 24, 2010, 01:53:26 13:53 »
Mega32
in datasheet wrote "High-performance, Low-power 8/16-bit Atmel
® AVR® XMEGA™ Microcontroller "
is there any idea ?
xaralampis
-Given: 20
« Reply #11 on: December 25, 2010, 12:17:30 12:17 »
@DarkClover
i use AVRISP mkII to flash XMEGA128A1
@alberto110
"Low-power 8/16-bit AVR"
this is just marketing
like all AVRs (90S, MEGA):
XMEGA has 16bit program bus
XMEGA has 8bit data bus
XMEGA has the same 32 8bit registers
also note - unlike other AVRs :
Instructions in the program memory are executed with a single level pipeline
Write to SRAM takes one cycle and read from SRAM takes two cycles.
XMEGA has powerfull peripherals DMA, EventSystem, QudratureDecoder, InterruptController
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #12 on: December 29, 2010, 02:58:45 14:58 »
@xaralampis
OK therefore I can use XMEGA controllers so far. That's very good.
But do you know whether the UC3 controller family can be pogrammed through
the AVRJTAG mkII too?
I found some programmer on the internet but they seem very uncomfortable or
don't have JTAG on board. Do you know some good programmers for the UC3, if
the AVRJTAG mkII doesn't work ?
Thanks...
Greets DarkClover
