April 26, 2026, 05:50:09 05:50
Author Topic: interupt problems  (Read 5085 times)
manoj
-Given: 8
« on: March 12, 2008, 12:05:36 12:05 »
hi
pls see my program to count the period between two  pulses.I didn,t get anything and I think the interrupt is not working. pls helplong int x=0,y=0,tmpl=0,tmph=0,oldstate=0;
 long int j;
 char count[10];
 void main (){
 Lcd_Init(&PORTB);
 TRISA=255;
 TRISB=0;
 INTCON.GIE=1;
 INTCON.PEIE=1;
 PIR1.TMR1IF=0;
 PIE1.TMR1IE=0;
if(Button(&PORTA,0,1,0)) oldstate=0;
 if (oldstate&& Button(&PORTA ,0,1,1)){
 PIE1.TMR1IE=1;
 T1CON.TMR1ON=1;}
 while(PIR1.TMR1IF==0){
 T1CON.TMR1ON=0;
 INTCON.GIE=0;
 INTCON.PEIE=0;
 PIR1.TMR1IF=0;
 PIE1.TMR1IE=0;}
  tmpl=TMR1L;
  tmph=TMR1H;
  y=1000000*x;
  j=(tmpl+tmph+y);
  IntToStr(tmpl,count);
  Lcd_Cmd(LCD_CLEAR);
  Lcd_Cmd(LCD_CURSOR_OFF);
  Lcd_Out(1,2,"HEART RATE:");
  Lcd_Out(2,3,count);
   void interrupt(){
   while(PIR1.TMR1IF){
   x++;
   PIR1.TMR1IF=0;}
vovchik02
-Given: 43
« Reply #1 on: March 13, 2008, 06:51:20 06:51 »
You don't show type of compiller.
In firtht part of code you activated interrupt,in second half turn off timer?   and wait int TMR1IF(if T1CON.TMR1ON=0 then  TMR1IF never set 1).
 Interrupt rotine isn't correct. See appNote  for You compiller and MCU.
Use simulator for test code.
GOOD luck!
veiledcavalier
-Given: 8
« Reply #2 on: March 14, 2008, 10:39:52 22:39 »
1-if u r using ccs try to use wizard, i know it seems bad, but just try something simple as a start
2- try not to put all ur code as a one block, divide it into subblocks which make it easier for debugging
Bugman
« Reply #3 on: March 24, 2008, 10:10:16 22:10 »
hi. make your code more readable by commenting it and using miningfull aliasis. when programming   a ucontroler in C try to hide the specifities of your controler by using some #defines. this will be very helpfull for some one else ho want to your code. try to comment your code and send it back please.
Posted on: March 24, 2008, 06:54:07 18:54 - Automerged
taking my time looking this code, i have many remarks:
    - the first part are initialisations (no poblemo);
    - in the second part, you rwite "if(Button(&PORTA,0,1,0)) oldstate=0;
                                                   PIE1.TMR1IE=1;
                                                   T1CON.TMR1ON=1;}"
         there you assign a value 0 to oldstate, i think, when there is no action on the input.
         that means "oldstate" always have the value 0 when executing the next "if". that make        the stement "oldstate&& Button(&PORTA ,0,1,1)" allways false.
        - look at the begining of the thid part. you start it by "while(PIR1.TMR1IF==0)". this is always true because you disable your timer in the next line, the count is blocked.
        - desabling interupts is not at the right place, i think.
do you see those errors or wrong i am?
robban
-Given: 34
-Receive: 38
Warrior
« Reply #4 on: March 25, 2008, 05:33:44 17:33 »
You don't call Yr. interrupt routine from main... Have a look at Yr. compiler manual for details abt. interrupt handling
Code Warrior
jasonix
-Given: 48
« Reply #5 on: March 27, 2008, 06:30:54 18:30 »
HI, manoj its very important read carefully datasheets about micro you are using, e.g. if is the 16f84 or 16f628 or 16f87x. For f84 or f628 you can use the RA4 with internal counter TMR0 or RB0 to work directly with external interruption configurable in INTCON. I think the main problem is in Hardware and not in the source code (program).
