April 25, 2026, 02:23:28 14:23
Author Topic: Need help  (Read 5998 times)
Jeckson
-Given: 54
« on: February 27, 2008, 08:46:24 08:46 »
Hallo
Is there the different between MC43064 and MC33064...?
Thank's a lot
Jeckson
karpen
« Reply #1 on: February 27, 2008, 01:12:27 13:12 »
Do you mean MC34064? (guess the 3 and 4 switched places)
I think the only difference is the temperature range, the MC34064 operates at 0 - 70 C, while the MC33064 operates at -40 - +85 C
Cheers
Jeckson
-Given: 54
« Reply #2 on: February 29, 2008, 02:52:02 02:52 »
Thank you
Do you mean MC34064? (guess the 3 and 4 switched places),yes.
how's about the pins,are there similiar...?
Jeckson
caveman508
-Given: 12
READ, REAd, REad, Read
« Reply #3 on: March 01, 2008, 12:21:33 12:21 »
The MC34064 is not a temperature sensor, it is an under voltage supervisor.  I use Digi-Key to get datasheets quickly http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=MC34064DM-ND
I have used the LM20 or LM35.  Just put "temperature sensor" into the search on digikey.
Caveman
Jeckson
-Given: 54
« Reply #4 on: March 03, 2008, 03:28:59 03:28 »
How's about the DS1810 or DS1812,can I change the MC34064 or MC33064..?
caveman508
-Given: 12
« Reply #5 on: March 03, 2008, 03:20:55 15:20 »
Jackson,
In short, you can do anything you desire.
Now, from a technical point of view, what is it you are working on?  Please describe some details on the type of project you are working on.
These chips are also voltage monitors, is that what you need?  Or are you after temperature?
As I indicated, Digi-Key is a great resource to finding datasheets
Caveman
karpen
« Reply #6 on: March 03, 2008, 04:55:32 16:55 »
Maybe I was unclear. What I meant with operational temperature, is the temperatures the circuit is guaranteed to function.
But the pins should be the same.
So, if your design isn't going to be in extreme temperatures, I think the circuit can be changed without a problem.
Cheers
Jeckson
-Given: 54
« Reply #7 on: March 05, 2008, 07:21:32 07:21 »
Thank you
>Now, from a technical point of view, what is it you are working on?  Please describe some details >on the type of project you are working on.
for the voltage monitor(reset MCU)
>What I meant with operational temperature, is the temperatures the circuit is guaranteed to >function.
How about the DS1810 or Ds1820..can I sued for MCU without any modification at the circuit and board..?
Thank's
Jeckson
karpen
« Reply #8 on: March 05, 2008, 08:39:05 08:39 »
DS1810 resets the MCU after power failure
DS1820 is a digital thermometer
So, no you can't. But there is probably some other IC you can use.
Posted on: March 05, 2008, 09:30:13 09:30 - Automerged
Sorry, I read through the posts again, and saw that you mentioned DS1812 earlier. So I guess the thermometer was just a type-o.
Yes, I think the DS1812 can replace the DS1810. And the pin assignment is the same, so no need to change the board.
Cheers
Jeckson
-Given: 54
« Reply #9 on: March 12, 2008, 08:41:02 08:41 »
Thank you
>Yes, I think the DS1812 can replace the DS1810. And the pin assignment is the same, so no >need to change the board.
I mention before The MC43064P/33064P..Can I repelce with DS1812 or DS1810?
I notice that 1810 active high and 1812 active low.
Which one..? or DS1811..?
Cheers
Jeck
