You think I am funny guy huh?
April 26, 2026, 12:06:56 00:06
Author Topic: Question for AVR Lock Bit Fuse  (Read 6662 times)
chyun3
-Given: 43
« on: February 19, 2008, 05:00:10 05:00 »
I read the datasheet of ATMEGA48 and still donot understand the function of the 3 modes of Lock Bit...It use to prevent other from read out the flash & eeprom ? Or it use to prevent other rewrite the flash & eeprom ? ..
Can ATMEGA48 code protect the Flash memory part while allow the eeprom data to be read out ?
telyadi
« Reply #1 on: February 19, 2008, 10:39:50 10:39 »
I usually release my chip with lockbit so no one can't read the flash. But if I need to update or bug fixed, I can erase that chip and write again.  With the lock bit set, my program can read and write value to the EEPROM. But someone can't read it via ISP programmer.
Mega32
-Given: 273
-Receive: 37
« Reply #2 on: February 19, 2008, 07:05:31 19:05 »
@chyun3
The lockbits will not prevent anyone from doing a "Full Chip Erase" , and then reprogram the MCU.
They can prevent anyone from reading out the application in flash , without doing a "full erase"
As for reading out the eeprom , you can implement a readout function in your application.
/Mega32
mpas
« Reply #3 on: February 24, 2008, 12:04:15 12:04 »
LB1,LB2:
 1    1     no restrictions for read/write
 0    1     you can read/verify but write is not allowed; fuses are disabled
 1    0     not allowed bits combination
 0    0     read/verify and write is not allowed; fuses are disabled
erase chip is allowed already
billy48
« Reply #4 on: March 04, 2008, 04:24:59 04:24 »
Be careful about setting bit
otherwise the system will become unstable
