You think I am funny guy huh?
April 29, 2026, 08:21:48 08:21
Author Topic: Transmitter of Pressure with PIC?????  (Read 3938 times)
Josivan
« on: February 17, 2008, 06:33:14 18:33 »
 Wink Good afternoon the toos..., I am wanting to develop a project of a Transmitter of Pressure with PIC and am with some difficulties, by chance alguem knows some sensor of pressure with tension exit? Huh Huh
I thank the Ok aid.
Francisco Josivan
« Last Edit: February 17, 2008, 06:36:22 18:36 by Josivan » Logged
zokij
-Given: 272
-Receive: 700
Nice time :)
« Reply #1 on: February 17, 2008, 11:12:34 23:12 »
Try this  Undecided
The Shift Rod Pressure/Tension Sensor is
The “Shift Rod Pressure/Tension Sensor” is the Quick Shifter’s universal sensor, mounting right in the shift rod. You’ll have to swap-in the appropriate length and thread shift rod, but for most applications Dynojet offers a Shift Rod Kit to facilitate an easy installation. The sensor is available in both “push” and “pull” styles, too, depending on the direction the shift rod moves during an up-shift.
link:  http://www.partsmag.com/0402/dynojet-0402/dynojet-0402.html   Shocked
if you found that is sensor for you or when you know which one is good for you then we can try to help you with PIC  Wink
Nice time   Roll Eyes
Josivan
« Reply #2 on: February 18, 2008, 12:59:43 00:59 »
Ok friend, I thank its attention, only that I am needing a sensor for industrial application understands,
 Francisco Josivan
