April 12, 2026, 06:34:27 06:34
Author Topic: REQ: Ethernet board  (Read 7745 times)
gonzogonzo
-Given: 79
-Receive: 49
« on: February 15, 2008, 02:09:38 14:09 »
Someone have schematic of ethernet development  board from CCS or a schematic of ethernet board with example with  CCS code that work?
Thanks in advance
mabd
-Receive: 16
« Reply #1 on: February 15, 2008, 05:05:03 17:05 »
if you have ENC28J60  then it is easy
check
http://www.mikroe.com/en/tools/serialeth/
and
http://www.mikroe.com/pdf/serial_ethernet_schematic.pdf
wnmaximino
-Given: 47
-Receive: 202
Homer
« Reply #2 on: February 15, 2008, 05:07:02 17:07 »
Try this: http://www.modtronix.com/index.php?cPath=105_112
with:
http://mihd.net/ovmy1d
Book and source
« Last Edit: February 15, 2008, 05:13:19 17:13 by wnmaximino » Logged
fagari
-Receive: 41
« Reply #3 on: February 16, 2008, 06:30:00 18:30 »
This project is very useful.
http://www.ljcv.net/projects/mchptcp3.75/index.html
gonzogonzo
-Given: 79
-Receive: 49
« Reply #4 on: February 17, 2008, 02:58:30 14:58 »
  Smiley I try all that we have suggest ......
fastlink30
-Given: 15
« Reply #5 on: February 23, 2008, 09:55:25 09:55 »
here schematic & software:
http://www.olimex.com/dev/pic-micro-web.html
fabric77
-Receive: 31
« Reply #6 on: February 23, 2008, 10:09:19 10:09 »
Take a look at under "Proteus 7 Professional\SAMPLES\Interactive Simulation\Ethernet Samples" folder...
You can use PICDEMNET Virtual Evaluation Board.
nvicchi
« Reply #7 on: March 30, 2008, 09:20:51 09:20 »
Search for "stack TCP/IP" at Microchip webpage. The include schematics in their pdfs. Or you can also look for the Explorer 16, they provide the schematic for free to... The only thing is that they use the C18 compiler...
For CCS, TCPIP Lean (which was recomendded in an upper post) is your best choice...
Beto
gonzogonzo
-Given: 79
-Receive: 49
« Reply #8 on: March 30, 2008, 05:07:49 17:07 »
Thanks to all for Your help;
now i have switched to Mikroelektronica board and software that
are very good and clear.....
cxandros
« Reply #9 on: May 18, 2008, 05:58:37 17:58 »
take a look in http://sourceforge.net/projects/picix/
in an OS for the Microcontroller PIC 18fXXX. Full preemptive Kernel. Unix interface. TCP/IP stack whit a CS8900 ETHERNET CONTROLLER HEADER BOARD
arash_tah
« Reply #10 on: July 13, 2008, 04:37:58 04:37 »
Hi gonzogonzo
Did u switch to Mikroelectronica?
What did u do?
could u impeliment your idea?
if so  how did u do that?
mabd
-Receive: 16
« Reply #11 on: July 14, 2008, 09:04:18 09:04 »
Mikroelectronica Ethernet board is great.
Working  fine.
and
Now, I am trying to implement  Microchip's
stack on Mikroe boards.
