April 21, 2026, 05:09:56 17:09
Author Topic: AVR Programmer  (Read 17459 times)
wellnerson1
-Given: 40
-Receive: 155
« on: February 03, 2008, 01:23:41 13:23 »
Here you can find a lot of Programmers for AVR, PIC etc..
http://www.lancos.com/
ph_cabral
« Reply #1 on: February 05, 2008, 03:18:43 15:18 »
In the very feel of Atmel, you might find the recorders of AVR,
The AVR Dragon, low-cost and well attraction
www.atmel.com
or
www.at91.com
an007
-Given: 53
-Receive: 51
« Reply #2 on: February 07, 2008, 07:55:06 07:55 »
http://www.embedded-projects.net/index.php?page_id=165
genviktr
« Reply #3 on: February 07, 2008, 05:41:10 17:41 »
And it is the reference on usb programmer for Atmel AVR controllers.
 http://www.fischl.de/usbasp/
30f4011
-Given: 778
-Receive: 96
« Reply #4 on: July 06, 2008, 02:21:06 14:21 »
Hi , This may help you:
http://www.ikalogic.com/isp.php
kevin8
« Reply #5 on: July 17, 2008, 02:52:39 14:52 »
USBasp - USB programmer for Atmel AVR controllers
very cool USB programmer,you can visit http://www.fischl.de/usbasp/    for more info
pak
« Reply #6 on: July 17, 2008, 03:37:55 15:37 »
Check this site too. It is a parallel port programmer for both the 8051 and AVR series devices.
http://chaokhun.kmitl.ac.th/~kswichit/SPI_Pgm/SPI-Pgm37.html
And Pony2000 programmer from
http://www.lancos.com/prog.html
And the hardware schematic is
http://www.lancos.com/e2p/betterSTK200.gif
I use both programmers.
pak
Smiley Happy Microcontroller Programming  Smiley
Posted on: July 17, 2008, 04:26:39 16:26 - Automerged
Another AVR programmer is avrdude. avrdude is come with winavr, a free compiler
http://winavr.sourceforge.net/download.html
avrdude can be used as command line and gui as well. For gui, go to C:\WinAVR-20080512\bin and run avrdude-gui.exe. before you use it, you have to install "install_giveio.bat"
Note: I'm not use avrdude very often.
pak
-Given: 8
-Receive: 21
« Reply #7 on: July 17, 2008, 04:22:04 16:22 »
who have this avr mkii sch
eleckits
-Given: 36
« Reply #8 on: July 26, 2008, 09:05:34 09:05 »
I have some questions relating usb programmer for Atmel AVR controllers that you mentioned above :
What's the configuration bits for ATMEGA8?
I hope to reply as soon as possible.
anatom
« Reply #9 on: July 29, 2008, 08:15:57 08:15 »
try this...
http://palmavr.sourceforge.net/cgi-bin/fc.cgi
wellnerson1
-Given: 40
-Receive: 155
« Reply #10 on: October 23, 2009, 10:11:23 10:11 »
Hi Everyone,
I have built a HV AVR Programmer with reference to the following web site:
http://www.der-hammer.info/hvprog/index_en.htm
Some times it works fine Shocked and in some other time it says that it cannot contact the programmer Huh. And even in some times the signature or fuse bits or lock bits it read out are incorrect Roll Eyes. i have done every thing in parallel HV mode. But the same chip is working fine with avr 910 programmer Grin. Can any body tell me any suggestion or any tuning is required? Cry
Thanks in advance Wink
« Last Edit: October 23, 2009, 10:14:32 10:14 by wellnerson1 » Logged
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #11 on: October 30, 2009, 01:08:56 01:08 »
Is it the same problem if you try on another computer ?
My problem was another driver which interrupted the programmer.
wellnerson1
-Given: 40
-Receive: 155
« Reply #12 on: November 02, 2009, 11:52:53 11:52 »
Hey Friends i found out the problem!!. Its due to the power supply. The HVProg works fine in ISP mode fantastically, dont have any absolute stiff power criteria, but in Parallel mode HVProg the power supply should be stiff to 12V and 5V otherwise lots of ambiguous responses came from the SW.
Thanks for your reply dear DarkClover.
wellnerson1
-Given: 40
-Receive: 155
« Reply #13 on: September 06, 2011, 05:31:55 05:31 »
Dear Friends,
Khazama AVR Programmer v1.7 a new version is released which can support new USBASP firmware version :  2011-05-289 TPI support (supports programmers with ATMega88 and ATMega8).
Link is: http://www.khazama.com/project/programmer/
Comment on Khazama: Works nicely as what it is intended for!!
