March 11, 2026, 01:45:51 01:45
Author Topic: 16f628A Simulation Problem  (Read 8112 times)
Shinta
-Given: 20
« on: February 02, 2008, 03:47:42 03:47 »
Hi, I design a little MikroBasic program for Pic 16F628A but in Isis Simulation PORTB.4 Doesn't work in output mode. The proteus Version is 7.1 SP2.
Is there a problem with Isis simulation software or what?
caveman508
-Given: 12
READ, REAd, REad, Read
« Reply #1 on: February 06, 2008, 01:50:52 01:50 »
Shinta
Make sure that you have set the direction control register (TRISB) to be a 0 (zero) for bit 4.  A 1 makes it an Input, a 0 makes it an Output.  There is a TRISx register for each port on the PIC, and is a bit-by-bit control.  I am not a MikroBasic user, but I do know about PICs
Hope this helps
Shinta
-Given: 20
« Reply #2 on: February 06, 2008, 07:41:02 19:41 »
The TRISB value is 0 (all portb in output).
Maybe this pin is associated with some peripheric?
twonuts
-Given: 55
-Receive: 42
« Reply #3 on: February 07, 2008, 12:42:51 00:42 »
PortB.4 is also low voltage programming pin. Make sure you have disabled this function. See page 92 of datasheet.
gedonet
-Given: 20
« Reply #4 on: March 11, 2008, 03:25:54 03:25 »
For using RB4 like other I/O, erase the bit 7 (LVP) of the config register at 0x2007 whith your programmer.
Gilles
trace
« Reply #5 on: April 24, 2008, 11:18:43 23:18 »
You can also add this asm line to your code:
__CONFIG _LVP_OFF
eleckits
-Given: 36
« Reply #6 on: April 25, 2008, 08:51:28 20:51 »
RB4 is an open collector pin if you want to use it as output you have to pullup it by using resistor 10K to +5V
Hope this help
-Receive: 4451
« Reply #7 on: April 25, 2008, 11:54:41 23:54 »
Hope this help
RB4 Bidirectional I/O port. It has a schmitt trigger input, as well as being the low voltage programming input pin.  not open collector output.
If in low voltage programming mode then it a input.
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #8 on: April 26, 2008, 10:33:23 22:33 »
Hope this help
pickit2 is right, the only pin that is open collector is RA4 and only on some device like the 16F84A.
