April 29, 2026, 08:20:07 08:20
Author Topic: Dual power supply  (Read 4901 times)
MAXPAYNE
-Given: 517
-Receive: 376
It's a little funny......
« on: January 30, 2008, 07:51:21 19:51 »
Has sombody build the power supply on figure 2 (vsn 2) Huh is it working properly ?
http://sound.westhost.com/project44.htm
Trishool
« Reply #1 on: February 02, 2008, 12:23:09 12:23 »
The schematic looks convencing for a lab powersupply but not for anyhing beyond that , what application you require powersupply for?.
Ts
smartcat004
-Receive: 27
« Reply #2 on: February 02, 2008, 03:40:09 15:40 »
I have confidence the circuit should work, you can't go wrong with these conventional regulators
except do remember to use a minimal heat sink if you are running  > 300 mA..
And anything above 1A means you need to make sure the heat sink is really a solid one with fins and the regulator body is thermally connected to heat sink(use the heat transfer paste materials...).
MAXPAYNE
-Given: 517
-Receive: 376
« Reply #3 on: February 02, 2008, 08:09:33 20:09 »
Ts
I will use as lab supply
Trishool
« Reply #4 on: February 03, 2008, 08:34:32 08:34 »
Figure 2 , has better trimming and Adjustments , but temperature compensation isnt there . If you need that fine supply I can post here schematic how to temperature compensate it and rest of the issue I hope you can integrate on your own .
BTW: what Load/Line regulation you need?
Ts
MAXPAYNE
-Given: 517
-Receive: 376
« Reply #5 on: February 03, 2008, 07:10:19 19:10 »
Ts
Thanks for uor reply. please post the schematic. line regulation may be 1%-4%
Trishool
« Reply #6 on: February 04, 2008, 07:00:15 07:00 »
Ahhh for that you dont need Temperature compensation . Your schematic is cool what is the confusion explain openly , such that we may find some remedy for it.
Ts
MAXPAYNE
-Given: 517
-Receive: 376
« Reply #7 on: February 05, 2008, 01:16:37 01:16 »
Posted on: February 05, 2008, 07:14:54 07:14 - Automerged
Please suggest how can i chose R1, R2, R3 and R4 if i wanna 1A through each regulator and 3A through bypass transistor  for both positive and negative side.
Trishool
« Reply #8 on: February 05, 2008, 06:41:57 06:41 »
MAXPAYNE , There is no bypass transistor in the schematic you show. The transistors Q1 , Q2 are meant for fine regulation on the adjust pin , its a feed back loop topology.
Ts
Posted on: February 05, 2008, 07:36:17 07:36 - Automerged
MAXPAYNE , BTW 3A at max 24V is 72 Watts ? . Very big heatsinks , instead go for SMPS or I have a link below :
http://www.instructables.com/id/Converting-a-computer-ATX-power-supply-to-a-really/
MAXPAYNE
-Given: 517
-Receive: 376
« Reply #9 on: February 05, 2008, 07:17:35 19:17 »
do u hae any adjustable swiching dc supply ? (0-30V)
