April 18, 2026, 01:43:22 13:43
Author Topic: help on wireless plz  (Read 7667 times)
adinand1024
« on: January 26, 2008, 03:30:27 15:30 »
i need to build a combat robot for a competition and it should be wirelessly controlled ... . I will be using the 8051 uc for controlling all the actuators , but i don't know how to use the wireless kit .. also , how how should i judge whether to use RC or IR ??
so can u sujjest me some weblinks from where i can get info on this....
edi14_10
« Reply #1 on: January 28, 2008, 06:59:29 18:59 »
What kind of wireless kit that you use? you can use RC transmitter-receiver to control your robot. not much modification needed. just take the digital value from the receiver IC. Wink
sphinx
-Given: 683
-Receive: 389
« Reply #2 on: January 28, 2008, 10:26:27 22:26 »
put your mind on building ur robot and get some kind of radiocontrol made for models, u might find good ones pretty cheap 2 channels and up FM or AM, i asked some time ago about schematics for such some time ago but noone seemed to have any info  so i could build one myself. so u better get some already made.
witsanukai
« Reply #3 on: January 29, 2008, 06:37:43 06:37 »
If you need to use wireless and you can communicate by rs232 you can send by this module (from laipac), i ever used with AVR control range more than 70meter
http://www.e-dsp.com/how-to-build-your-own-wireless-receiver-and-transmitter-device-create-rf-in-your-embedded-application/
johanb_85
« Reply #4 on: February 18, 2008, 02:40:08 14:40 »
We did a similar project at university, but the task of the robot was to make a map of an unknown room. We used a bluetooth module. It had RS-232 in TTL levels connected to the AVR microcontroller. And on the PC side we used a standard USB dongle. The bluetooth module worked as a simple "usb serial cable". That solution was very stable and worked in rather long distance.
bogdantk
-Given: 40
« Reply #5 on: February 18, 2008, 02:56:46 14:56 »
Hello
I used in a project Sena Parani SD100 modules
http://www.sena.com/products/industrial_bluetooth/bluetooth_serial_adapter/parani_sd/
They work as an RS232 cable and after pairing devices no one can tamper with you line.
The power is also easy to provide through the RS232 connector. Very fast too we were able
to use 56 Kbps at more than 75 m in open air with 0 errors (I checked the link with a dedicated software for
more than 12 hours).
I think a good choice.
tension885
« Reply #6 on: February 20, 2008, 05:21:49 05:21 »
yes u can use rf controlled robot.u can get transmitter ,receiver from toy cars
jim_17
« Reply #7 on: February 29, 2008, 03:40:59 15:40 »
I think that Rf controller can be a good idea but ir may be also a good idea because IR isn't used so much, then you won't have interference problems Smiley
Tricky Nekro
« Reply #8 on: April 01, 2008, 09:25:55 21:25 »
Why to make things complicated... They are simple...
First of all... IR - no way man... Forget it, you need both reliability and range... IR are very cheap but lack this essential in a robot fight
Secondly, Why not to buy a RC remote and receiver, as for RC helicopters, cars, boats, etc...
Having a microcontroller in your end project means that you can read pulses...
Thirdly, remember to KISS (keep it simple stupid) this enforces to everyone...
RF can be a hell if you are dealing with el chipo RF modules... For me LINX is trust able... ( I do NOT advertise, never)
Forth, here comes the big guns... Battle bots actuators, weapon actuators and so on, generate sparks, lot's of sparks...
Can you microcontroller keep up? Depends on you --->
Cheers,
Lefteris
mikisoft
« Reply #9 on: May 17, 2008, 05:28:40 17:28 »
I think BLUETOOTH is the best choose for you.
