April 29, 2026, 02:39:22 02:39
Author Topic: PDS 3.x + 18F2525 + CCP1CON = error  (Read 4711 times)
maddoc
-Given: 49
-Receive: 14
« on: January 26, 2008, 10:10:51 10:10 »
In the Results windows it states:
ASM Error [...] Symbol not previously defined (CCP1CON)
After a few day trying hard to make PDS to compile my program for 18F2525, I have found the solution!
Problem: If you are trying to alter CCP1CON in a 18F2525 you will always get errors and no hex file.
Crownhill thought that 18F2525 has the name for this register ECCP1CON (as in ECCP for 18F4525), which is not true, in the datasheet it is specified as CCP1CON for both devices.
Solution: either write it as ECCP1CON or change the definition in the Inc folder in filename P18F2525.lpb from ECCP1CON to CCP1CON.
I bet there are more problems like this regarding registers and their names. This could be helpful to solve such problems.
