April 29, 2026, 10:37:37 10:37
Author Topic: L297+ L298 or UCN5804 Stepper motor driver  (Read 5663 times)
TirthankarMukherjee
« on: January 24, 2008, 01:55:19 13:55 »
I need to know when driving a stepper motor with UCN5804 or l297+l298 .. we need to give a pule .. let 40 khz  a direction value .. and enable pin .. then how will I know I many ratations the motor rotated ... I couldnt clarify it from the data sheet ... plz explain ... thanks in advance...
Trishool
« Reply #1 on: January 25, 2008, 10:13:08 10:13 »
In CNC machines the table bed and gears are pre calculated . There is a staring point where you can refer the tool or what ever as the 0 coordinates. Since you ask for stepper motors its this way . Other high speed servos have an encoder at the back which gives ttl values for rotation.
Ts
