Title: simple circuit: Component & voltage tester Post by: zokij on May 31, 2008, 01:54:24 01:54 Component & voltage tester (http://us1.webpublications.com.au/static/images/articles/i306/30610_2lo.jpg) This simple circuit tests speakers, microphones, transformers and voltage. It's basically a very low frequency oscillator that produces extremely short 'fruity' pulses. The type of sound produced is very easy to hear and to determine the precise direction it is coming from, thus making it ideal for checking the phasing in multiple speaker installations. It is also very useful for car stereo installations as well as public address systems where it can drive dozens of speakers directly on a 100V or 70V line system. The signal is also easy to hear on a public address system so that you can drive around a large installation with the window down and easily hear each speaker as you drive past. It is easy to check that a speaker is in phase with its neighbours, by listening for the artificial centre created between two identical sound sources. Q1 and Q2 oscillate when connected to loads between zero and about 1000Ω. The frequency increases as the resistance of the load increases - 8Ω loads produce about 8Hz output while 100Ω loads will produce about 100Hz output, although it is only approximate. The unit is also useful for checking dynamic microphones (not condenser types), headphones, transformers (both audio and mains) and resistance loads (only visual checks via the LED). The pulses produced can sound too loud for some delicate circuits such as dynamic microphones and headphones, but the pulse is so short that it is virtually impossible to do any damage; the average current flow is only a few milliamps. The circuit needs no power switch as the oscillator only operates when the negative side of the battery is connected through the load being tested. The LED flashes at each pulse as a visual indication that the load is lower than about 1000Ω. The circuit works from a 3V battery pack. To use a 9V battery change: the 15Ω resistor to 47Ω, the 1.8Ω resistor to 5.6Ω and the .033µF capacitor to .01µF. LED2, diode D1, zener diode ZD1 and the series 220Ω resistor form a voltage indicator which is used to detect and indicate any voltage greater than about 10V. LED2 only illuminates if the voltage rises above the threshold set by ZD1 and D1, which is more than the battery voltage (3V or 9V). These components can be omitted if the device is not going to be used for working on cars. However, it's quite handy having a device that can check power wires, shorts to chassis and speakers in a car. Title: Re: simple circuit: Component & voltage tester Post by: yoda on September 01, 2009, 02:05:31 14:05 Zokij, where has the circuit gone? It's blank overhere.
Title: Re: simple circuit: Component & voltage tester Post by: zokij on September 04, 2009, 10:12:25 22:12 ;)
here is back again... ::) :-\ image was on imagehosting server.... :-X |
