Title: lc_meter Post by: egealtay on August 31, 2007, 03:11:02 15:11 http://electronics-diy.com/lc_meter.php (ftp://http://electronics-diy.com/lc_meter.php)
Title: Re: lc_meter Post by: corbo on January 18, 2008, 12:44:14 12:44 LCF meter
C - 1pF to 2500uF L - 0,070uH to 15H HF - 15Hz to 46MHz UHF - 25 MHz to 1,3GHz http://rapidshare.com/files/84742732/LCF_Meter.rar Title: Re: lc_meter Post by: respected on January 18, 2008, 09:33:36 21:33 @ egealtay
link error Title: Re: lc_meter Post by: gianmagna on January 18, 2008, 10:08:48 22:08 this link is correct ;D http://www.electronics-diy.com/lc_meter.php Title: Re: lc_meter Post by: yahoo on January 19, 2008, 12:36:51 00:36 It's a very accurate LC meter. I have it working from years. Highly recommended! I cannot see the link for the firmware but if somebody is interested I can provide it.
Title: Re: lc_meter Post by: omni on January 19, 2008, 04:41:16 04:41 Digital LC Meter Version 2 (PIC 16F628)
http://ironbark.bendigo.latrobe.edu.au/%7Erice/lc/index2.html Title: Re: lc_meter Post by: hodahel on January 20, 2008, 07:00:01 07:00 Hope somebody can revised it to used Nokia LCD like 3310...it's hard to find that kind of lcd..
Title: Re: lc_meter Post by: mayli on January 21, 2008, 12:51:50 00:51 Digital LC Meter Version 2 (PIC 16F628)
http://ironbark.bendigo.latrobe.edu.au/%7Erice/lc/index2.html All the material inside above web page has been removed. Can anyone body post them again? :-[ Thank you Title: Re: lc_meter Post by: hemlig on January 21, 2008, 01:45:34 01:45 @mayli
It is still there when I tested the link after your posting. Maybe you should clear the cache in your browser. Title: Re: lc_meter Post by: TA5CT on January 21, 2008, 03:35:21 15:35 you can visit this web page.
http://www.sprut.de/electronic/pic/projekte/lcmeter/lcmeter.htm (http://www.sprut.de/electronic/pic/projekte/lcmeter/lcmeter.htm) Title: Re: lc_meter Post by: pickit2 on January 22, 2008, 11:53:46 23:53 Hope somebody can revised it to used Nokia LCD like 3310...it's hard to find that kind of lcd.. Did your try local alarm installer, I get faulty control panels from mine. most are 2x16 but also 4x32 upto 4x40 cost a few beers.some I have put on e-bay :) Title: Re: lc_meter Post by: hodahel on January 28, 2011, 08:20:15 08:20 After how many years..I'm back on this thread to update... ;D
I successfully built my LC Meter... (http://i82.photobucket.com/albums/j249/Rhonn_2006/Image329.jpg) (http://i82.photobucket.com/albums/j249/Rhonn_2006/Image325.jpg) (http://i82.photobucket.com/albums/j249/Rhonn_2006/Image330.jpg) (http://i82.photobucket.com/albums/j249/Rhonn_2006/Image332.jpg) Reading on 33pF ceramic caps.. (http://i82.photobucket.com/albums/j249/Rhonn_2006/Image372.jpg) 15pF.. (http://i82.photobucket.com/albums/j249/Rhonn_2006/Image375.jpg) 2.2nF (http://i82.photobucket.com/albums/j249/Rhonn_2006/Image377.jpg) 1000pF 1nF (http://i82.photobucket.com/albums/j249/Rhonn_2006/Image378.jpg) Seems weird on coil.. here is a reading for 100uH coil. (http://i82.photobucket.com/albums/j249/Rhonn_2006/Image379.jpg) another 100uH (http://i82.photobucket.com/albums/j249/Rhonn_2006/Image380.jpg) I wonder if who's telling the truth...the Coil or the meter? :( @MODS Please Delete if I'm reviving OLD THREAD for no reason... TIA Title: Re: lc_meter Post by: pickit2 on January 28, 2011, 12:59:28 12:59 hodahel
Not a problem with post, but why not post it as a full project in projects forum. Title: Re: lc_meter Post by: hate on January 28, 2011, 05:15:48 17:15 Quote I wonder if who's telling the truth...the Coil or the meter? Sad In a similar version of this project the author inserted a calibration code, I didn't check if there is also one in this one but the heating up time of the components greatly affect measurements. The system must be calibrated after some time after it is powered. I had made the similar project I mentioned and when calibrated after a few minutes after it was powered the errors were acceptable.Regards... Title: Re: lc_meter Post by: mris99 on January 28, 2011, 07:28:35 19:28 Hi,
I am thinking of building this one: http://www.hobbielektronika.hu/kapcsolasok/lcm3_alkatresz_mero_muszer_-_kit_lehetoseg.html Sorry, it is hungarian, but you can use google translate: http://translate.google.com/translate?js=n&prev=_t&hl=hu&ie=UTF-8&layout=2&eotf=1&sl=hu&tl=en&u=http%3A%2F%2Fwww.hobbielektronika.hu%2Fkapcsolasok%2Flcm3_alkatresz_mero_muszer_-_kit_lehetoseg.html capacitance 1pF ... 0.1F inductance 10nH ... 20H ESR up to 500mOhm In circuit ESR measurement It measures also the capacitance of inducttors, and correcte the inductance measurement with this. Best regards, mris Title: Re: lc_meter Post by: metal on January 28, 2011, 10:01:00 22:01 are there any links hate for the calibrated version?
Title: Re: lc_meter Post by: cicos on January 29, 2011, 12:15:08 00:15 http://www.marc.org.au/
Poz JaMi Title: Re: lc_meter Post by: hodahel on January 29, 2011, 02:46:51 02:46 hodahel Not a problem with post, but why not post it as a full project in projects forum. just wanted to..but still gathering enough documentation for posting as full project..:D In a similar version of this project the author inserted a calibration code, I didn't check if there is also one in this one but the heating up time of the components greatly affect measurements. The system must be calibrated after some time after it is powered. I had made the similar project I mentioned and when calibrated after a few minutes after it was powered the errors were acceptable. This version includes calibration via software...also has the option to manually calibrate to standard value... The problem I encountered with the INDUCTOR side is the coil itself....it was marked with 100uH but reads 82uH...tried other coils and they all give close to printed values reading... are there any links hate for the calibrated version? This is the version I constructed.... http://sites.google.com/site/vk3bhr/home/index2-html Title: Re: lc_meter Post by: hate on January 29, 2011, 11:30:41 11:30 @hodahel: Sry I couldn't notice a button for calibration in ur pics and considered it didn't have calibration. It might be a tolerance and brand issue for the bad readings.
@metal: It's been a long time since I constructed it and don't remember which one I constructed but the hardware was the same with the ones posted here. Probably just a clone. I have the schematic and code though, I can post them if u like. Regards... Title: Re: lc_meter Post by: bbarney on January 29, 2011, 03:31:36 15:31 Hi, I am thinking of building this one: http://www.hobbielektronika.hu/kapcsolasok/lcm3_alkatresz_mero_muszer_-_kit_lehetoseg.html Sorry, it is hungarian, but you can use google translate: http://translate.google.com/translate?js=n&prev=_t&hl=hu&ie=UTF-8&layout=2&eotf=1&sl=hu&tl=en&u=http%3A%2F%2Fwww.hobbielektronika.hu%2Fkapcsolasok%2Flcm3_alkatresz_mero_muszer_-_kit_lehetoseg.html capacitance 1pF ... 0.1F inductance 10nH ... 20H ESR up to 500mOhm In circuit ESR measurement It measures also the capacitance of inducttors, and correcte the inductance measurement with this. Best regards, mris Nice one , let us know if you build it Title: Re: lc_meter Post by: hodahel on February 01, 2011, 03:39:24 03:39 @hodahel: Sry I couldn't notice a button for calibration in ur pics and considered it didn't have calibration. It might be a tolerance and brand issue for the bad readings. The image image above was taken when was I was just stuffing the board with parts..:D I'll upload the complete image later... EDIT: Here is the picture of complete project....the RESET switch is right beside the LED...:D (http://i82.photobucket.com/albums/j249/Rhonn_2006/Image351.jpg) (http://i82.photobucket.com/albums/j249/Rhonn_2006/Image352.jpg) Nice one , let us know if you build it I'm into building this one too...bit hesitant because of language used on that site.. Title: Re: lc_meter Post by: Tahmeed on September 09, 2011, 04:28:05 16:28 hey is there any version for AVR??? I have an atmega8....
Title: Re: lc_meter Post by: sfiga69 on September 09, 2011, 04:46:22 16:46 @Tahmeed
watch this http://home.ict.nl/~fredkrom/pe0fko/LCMeter/ http://www.avrprojects.info/avr-projects/capacitance-and-inductance-meter-using-atmega8/ |
