Title: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: shobits1 on February 17, 2008, 06:06:09 18:06 Hi, I need nokia 3310 LCD or Nokia 1100 LCD model library for proteus ,
I don't find it anywhere ??? thanks for your help .... Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: eYe on February 20, 2008, 03:04:04 15:04 It is only 7110 LCD on Proteus.
I have never seen the other SPI LCD on proteus yet. Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: Angor on April 10, 2008, 12:19:30 12:19 NOKIA 3310 LCD have SPI interface.
Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: samir on April 11, 2008, 12:17:49 12:17 if any one has clour LCD model for proteus?
thanx in advance Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: Fuji on April 22, 2008, 11:52:54 11:52 Hi, I need nokia 3310 LCD or Nokia 1100 LCD model library for proteus , I don't find it anywhere ??? thanks for your help .... Hi, Try here http://www.tanu-sha.narod.ru/photoalbum.html Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: zerro on April 22, 2008, 09:15:46 21:15 For me dont work 3310 Model (some dll error) .. i use version 7.2 sp0 .... some advices ???
Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: aliveli on April 22, 2008, 10:28:46 22:28 the design example works with v6.9 proteus
Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: zerro on April 23, 2008, 01:33:18 13:33 Ok ... i put proteus 6.9 sp5 and the model for nokia 3310 work very well but .... now my proteus 7.2 sp0 dont work ... how to make to work together with this 2 version of Proteus ???
Thank you! Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: ORIONIX on April 23, 2008, 05:00:36 17:00 it's a problem of autorization. :-[ :-[ :-[ :-[ :-[ :-[ ..maybe, somebody will know how authorize the model for the latest versions of proteus.
Bye. Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: zerro on April 27, 2008, 08:18:31 20:18 use the search button for "proteus 6.9 sp5" .... now i'll give you the tips ...
http://www.sonsivri.com/forum/index.php?topic=2765.0 and the direct link is: http://www.4shared.com/dir/941825/585dc69f/Proteus_69_sp5.html Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: forter on April 28, 2008, 09:18:12 09:18 Hi, zerro!
And what is password for Proteus_69_sp5? Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: zerro on April 28, 2008, 09:27:52 09:27 if you look at first link i give, you find this ....
mirror : http://www.4shared.com/dir/941825/585dc69f/Proteus_69_sp5.html pass : www.eca.ir Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: mylogin on May 09, 2008, 04:50:36 16:50 It works under Proteus version 7.2 sp2
Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: zerro on May 09, 2008, 07:09:32 19:09 ok ... i check under proteus 7.2 sp2 .... it's working ....
Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: shobits1 on May 15, 2008, 05:39:09 17:39 ok ... i check under proteus 7.2 sp2 .... it's working .... how did you make it works,, i am using proteus7.2sp2 but when i start the simulation i get dll error ... Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: zerro on June 15, 2008, 07:47:27 19:47 I download the proteus 7.2 sp2 from this site, i install it and i put the files in models and library and i start the simulation .... and everything was ok ... the model for nokia 3310 lcd work ok.
Best regards! zerro Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: Joe_jj on June 17, 2008, 03:49:23 15:49 proteus 7.2 sp6. Not workzz. :P :P
PCD_8544.DLL failed to authorize Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: o2 on June 19, 2008, 05:51:13 05:51 Hi,All
I try to fix it problem of autorization lib for proteus 72sp6 it's a problem of autorization. :-[ :-[ :-[ :-[ :-[ :-[ ..maybe, somebody will know how authorize the model for the latest versions of proteus. Bye. It works under Proteus version 7.2 sp2 proteus 7.2 sp6. Not workzz. :P :P PCD_8544.DLL failed to authorize and this patch for 72sp6 Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: kokos on June 19, 2008, 05:34:29 17:34 proteus 7.2 sp2 .it is working
Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: picavr on June 20, 2008, 02:25:23 14:25 Hi,All halt virus fount with avg !!!!!!I try to fix it problem of autorization lib for proteus 72sp6 and this patch for 72sp6 Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: bbarney on June 20, 2008, 03:53:54 15:53 Shows up clean with Nod32
Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: mhemara on July 02, 2008, 06:56:41 18:56 Hi,All I try to fix it problem of autorization lib for proteus 72sp6 and this patch for 72sp6 Can you please explain how to use this patch? Is it used beside n0p one or it is stand alone? Also please identify which setup package this path should applied to. I always get the message "patching failed" ThanX Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: o2 on July 03, 2008, 04:43:53 04:43 Can you please explain how to use this patch? 1.Uninstall ProteusIs it used beside n0p one or it is stand alone? Also please identify which setup package this path should applied to. I always get the message "patching failed" ThanX 2.Install Proteus 72 sp6 3.Select Licence.lxk 4.run Patch Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: MCan on July 05, 2008, 04:15:09 04:15 Hi,All I try to fix it problem of autorization lib for proteus 72sp6 and this patch for 72sp6 rar file corrupted. can you upload it again ? (i downloaded 3 times) Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: mhemara on July 06, 2008, 11:27:08 11:27 rar file corrupted. can you upload it again ? (i downloaded 3 times) RAR file ok Try reinstalling a new copy of WinRAR Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: MCan on July 06, 2008, 01:34:56 13:34 ok i did and problem fixed. thanks for help
Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: aamir on October 07, 2008, 06:20:57 06:20 please upload patch for 7.2 sp6 on rapidshare
ASK FOR A PATCH IN THE PROPER THREAD NEXT TIME! Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: o2 on October 07, 2008, 07:13:17 07:13 please upload patch for 7.2 sp6 on rapidshare http://rapidshare.com/files/151641395/pp72sp6.rar.htmlTitle: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: chai98a on October 12, 2008, 02:09:21 02:09 How to download dll file of nokia 3310 on link above ..
I go to the web but did not see link for download Who have pls uplooad to share file web too than you Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: eYe on October 12, 2008, 09:15:30 09:15 Click on the picture and then see on the left hand, you can download Model.zip and design.zip
Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: M.yasser on August 04, 2011, 04:51:56 04:51 hi,
It works under Proteus version 7.7 sp2. regards. Title: Re: REQ: Nokia 3310 or 1100 LCD, Library for proteus Post by: pickit2 on August 07, 2011, 10:14:00 22:14 It works under 7.8sp2 with a slight problem.
That is, it don't delete the *.PWI file due to an exit error in the model or dll file. |
