Title: Proton Compiler and USB ... and pc interfacing too
Post by: jeanninemtv on November 23, 2011, 04:12:52 16:12
Hello, i would like to discuss with us about usb link with proton. As a beginner in the matter i want to share and get help from us :) Posted on: November 23, 2011, 04:53:59 16:53 - Automerged
1.-Test Hardware... I did a very simple board with a 18F4455 and two potentiometers, three buttons and three leds , nothing special... but for practical purposes i tested it on isis :) 2.-Code generation... I used easyHID (as i don't know if is there another more simple tool to generate both pc and pic base code) the pc program is to be done in a first step with vb6 and (if possible) migration to a more modern version of visual or recoding using visualC template... '**************************************************************** '* Author : Julio Aguilar Angulo * '* Version : 1.0 * '**************************************************************** Device 18F4455 Xtal 48 USB_Descriptor = "DESC.inc"
All_Digital= true
' Hardware Settings: ' LCD settings: PORTD Declare LCD_RSPin PORTD.2 ' RS pin RD0 Declare LCD_ENPin PORTD.3 ' ENA pin RD1 Declare LCD_DTPin PORTD.4 ' 4 bit bus mode
' adc settings: PORTA Adin_Res 10 ' 10 bit resolution(0-5V = 0 - 1023) Adin_Tad FRC ' Internal RC osc for sampling Adin_Stime 100 ' adc recharging time of 100uS
' USB Buffer... Symbol USBBufferSizeMax = 8 Symbol USBBufferSizeTX = 8 Symbol USBBufferSizeRX = 8 Dim USBBuffer[USBBufferSizeMax] As Byte
' some useful flags... Dim PP0 As Byte System ' USBPOLL status return Symbol CARRY_FLAG = STATUS.0 ' high if microcontroller does not have control over the buffer Symbol ATTACHED_STATE = 6 ' is USB attached '*****************************************************************
' Variable declarations: ' adc variables Dim sample As Word ' rename entire contents of adc results register Dim acc_sample As Word ' temporal register for calculations Dim sample1 As Word ' rename entire contents of adc results register Dim acc_sample1 As Word ' temporal register for calculations
' adc calculations variables ' adc test variables Dim tvolt As Byte ' volts register Dim tmilli As Byte ' milivolts register Dim tvolt1 As Byte ' volts register Dim tmilli1 As Byte ' milivolts register '****************************************************************
' adc hardware settings TRISA = $FF ' RA.0 - RA.1 --> ch0 ch1 TRISD = 0 ADCON1 = %10001010 ' PORTA.0 ES ANALÓGICA ADCON2 = %10000000 ' EL RESULTADO DEL ADC JUSTIFICADO A LA DERECHA TRISB=0 LATB=0 PORTB=0 Clear ' lcd messages layout Print At 1,1,"Ch0: --,-- V" Print At 2,1,"Ch1: --,-- V"
PORTD.0=1 ' ************************************************************ ' * main program loop - remember, you must keep the USB * ' * connection alive with a call to USBPoll, USBIn or USBOut * ' * every couple of milliseconds or so * ' ************************************************************ GoSub AttachToUSB mainloop:
' data acquisition
sample = ADIn 0 sample1 = ADIn 1 ' data conversion to 'Volts' acc_sample = 488 * (acc_sample / 10) ' acc_sample1 = 488 * (acc_sample1 / 10) ' tvolt = acc_sample / 10000 ' VOLTS tmilli = (acc_sample // 10000) / 100 ' MILLIVOLTS tvolt1 = acc_sample1 / 10000 ' VOLTS tmilli1 = (acc_sample1 // 10000) / 100 ' MILLIVOLTS
acc_sample = 0 acc_sample1 = 0
' displaying the measured data: Print At 1,6,Dec2 tvolt,".",Dec2 tmilli USBPoll Print At 2,6,Dec2 tvolt1,".",Dec2 tmilli1
USBBuffer[0] = 0 USBBuffer[1] = tvolt USBBuffer[2] = tmilli USBBuffer[3] = tvolt1 USBBuffer[4] = tmilli1 GoSub DoUSBOut ' transmit data via the usb link DelayMS 1 GoTo mainloop
' ************************************************************ ' * receive data from the USB bus * ' ************************************************************ DoUSBIn: USBIn 1, USBBuffer, USBBufferSizeRX, DoUSBIn Return ' ************************************************************ ' * transmit data * ' ************************************************************ DoUSBOut: USBOut 1, USBBuffer, USBBufferSizeTX, DoUSBOut Return
' ************************************************************ ' * wait for USB interface to attach * ' ************************************************************ AttachToUSB: Repeat USBPoll Until PP0 = ATTACHED_STATE Return
Posted on: November 23, 2011, 05:01:32 17:01 - Automerged
now the vb6 code for the pc Dim Vari As String ' vendor and product IDs Private Const VendorID = 6017 Private Const ProductID = 2000
' read and write buffers Private Const BufferInSize = 8 Private Const BufferOutSize = 8 Dim BufferIn(0 To BufferInSize) As Byte Dim BufferOut(0 To BufferOutSize) As Byte Dim tvolt As Byte Dim tvolt1 As Byte Dim tmilli As Byte Dim tmilli1 As Byte Dim ch0 As Double Dim ch1 As Double
' **************************************************************** ' when the form loads, connect to the HID controller - pass ' the form window handle so that you can receive notification ' events... '***************************************************************** Private Sub Form_Load() ' do not remove! ConnectToHID (Me.hwnd) End Sub
'***************************************************************** ' disconnect from the HID controller... '***************************************************************** Private Sub Form_Unload(Cancel As Integer) DisconnectFromHID End Sub
'***************************************************************** ' a HID device has been plugged in... '***************************************************************** Public Sub OnPlugged(ByVal pHandle As Long) If hidGetVendorID(pHandle) = VendorID And hidGetProductID(pHandle) = ProductID Then Me.Caption = " connected" ' ** YOUR CODE HERE ** End If End Sub
'***************************************************************** ' a HID device has been unplugged... '***************************************************************** Public Sub OnUnplugged(ByVal pHandle As Long) If hidGetVendorID(pHandle) = VendorID And hidGetProductID(pHandle) = ProductID Then Me.Caption = "not connected" ' ** YOUR CODE HERE ** End If End Sub
'***************************************************************** ' controller changed notification - called ' after ALL HID devices are plugged or unplugged '***************************************************************** Public Sub OnChanged() Dim DeviceHandle As Long ' get the handle of the device we are interested in, then set ' its read notify flag to true - this ensures you get a read ' notification message when there is some data to read... DeviceHandle = hidGetHandle(VendorID, ProductID) hidSetReadNotify DeviceHandle, True End Sub
'***************************************************************** ' on read event... '***************************************************************** Public Sub OnRead(ByVal pHandle As Long) ' read the data (don't forget, pass the whole array)... If hidRead(pHandle, BufferIn(0)) Then tvolt = BufferIn(2) tmilli = BufferIn(3) tvolt1 = BufferIn(4) tmilli1 = BufferIn(5) ch0 = tvolt + (tmilli / 100) ch1 = tvolt1 + (tmilli1 / 100) ' Matlab.Execute ("data=[data" + Str(ch0) + "] ") Label1.Caption = Format(ch0, "##,##0.00") Label4.Caption = Format(ch1, "##,##0.00") ' ** YOUR CODE HERE ** ' first byte is the report ID, e.g. BufferIn(0) ' the other bytes are the data from the microcontrolller... End If End Sub
'***************************************************************** ' this is how you write some data... '***************************************************************** Public Sub WriteSomeData() BufferOut(0) = 0 ' first by is always the report ID BufferOut(1) = 10 ' first data item, etc etc
' write the data (don't forget, pass the whole array)... hidWriteEx VendorID, ProductID, BufferOut(0) End Sub '************* Private Sub Timer1_Timer() Matlab.Execute ("data=" + Str(ch0)) Text1.Text = Matlab.Execute("data") Matlab.Execute ("vector= [vector data]") Matlab.Execute ("plot(vector)")
End Sub
And now my questions ... Posted on: November 23, 2011, 05:05:44 17:05 - Automerged
Questions: 1: If i use the usb for acquisition only ( i mean no lcd displaying , just send data directy to the pc to display it after). How fast can i do that in hid mode??? (prior to get a specification of bandwidth and know how fast would be my variable to be measured (in fact i would like to sample sounds as well as slow variables like temperature increasing of a sensor) ) 2: Can i gain speed by increasing the bus size to 64 and packing inside multiple samples at time??? 3: I'm thinking about using matlab or scilab for plotting the signals and the use the data analysis capabilities. i'm on the way to do that... data gathering via vb6 then plot to matlab but it takes important time. So i'm thinking about it as a data capturing mode... so i sample especifically to post analysis and in other mode to do simple data displaying ... 4: Is there any way to reuse the mcHID dll inside matlab to avoid consuming time in linking vb and matlab?
Title: Re: Proton Compiler and USB ... and pc interfacing too
Post by: jeanninemtv on November 24, 2011, 09:27:31 09:27
btw i tested the oscillo dll from http://www.sonsivri.to/forum/index.php?topic=12862.0 (http://www.sonsivri.to/forum/index.php?topic=12862.0) so this is the result of mixing the sample vb6 code of the oscillo with the sample vb6 code of the usb link 'oscilloscope dll connection declarations Private Declare Function ScopeCreate Lib _ "OscDLL_VB.dll" (ByVal Prm As Integer, ByVal P_IniName As String, ByVal P_IniSuffix As String) As Integer
Private Declare Function ScopeShow Lib _ "OscDLL_VB.dll" (ByVal handle As Integer) As Integer Private Declare Function AtOpenLib Lib _ "OscDLL_VB.dll" (ByVal Prm As Integer) As Integer Private Declare Function ScopeHide Lib _ "OscDLL_VB.dll" (ByVal handle As Integer) As Integer Private Declare Function ScopeDestroy Lib _ "OscDLL_VB.dll" (ByVal handle As Integer) As Integer Private Declare Function ScopeCleanBuffers Lib _ "OscDLL_VB.dll" (ByVal handle As Integer) As Integer
Private Declare Function ShowNext Lib _ "OscDLL_VB.dll" (ByVal handle As Integer, ByRef PArrDbl As Double) As Integer Private Declare Function ExternalNext Lib _ "OscDLL_VB.dll" (ByVal handle As Integer, ByRef PArrDbl As Double) As Integer Dim ScopeStarted As Boolean Dim scopehandle As Integer Dim Slowly As Boolean
Private Declare Function GetTickCount Lib "kernel32.dll" () As Long
Private Sub Check1_Click() If Check1.Value = 1 Then Slowly = True Else Slowly = False End If End Sub
Private Sub Command1_Click() If Command1.Caption = "Load Scope" Then Command1.Caption = "Unload Scope" scopehandle = ScopeCreate(2, "Scope_Desk.ini", "") ScopeShow (scopehandle) Else Command1.Caption = "Load Scope" ScopeStarted = False Call ScopeHide(scopehandle) Call ScopeDestroy(scopehandle) End If
End Sub
Private Sub Command2_Click() If Command2.Caption = "Run" Then ConnectToHID (Me.hwnd) Command2.Caption = "Stop" Command1.Enabled = False Dim D1(2) As Double Dim Db As Double Dim i As Integer ScopeStarted = True D1(0) = 0 D1(1) = 0 D1(2) = 0 Do DoEvents ' For i = 0 To 100 Step 1 D1(0) = ch0 'D1(0) - 11: If D1(0) < -280 Then D1(0) = 20 D1(1) = ch1 'D1(1) - 3.1333: If D1(1) < -280 Then D1(1) = 20 D1(2) = 4 'D1(2) - 5.1333: If D1(2) < -280 Then D1(2) = 20 Db = D1(0) + D1(1) + D1(2) Call ExternalNext(scopehandle, Db) Call ShowNext(scopehandle, D1(0)) ' Next i If Slowly Then wait_ms (1) Loop Until (Not ScopeStarted) Else Command2.Caption = "Run" Command1.Enabled = True ScopeStarted = False End If End Sub
Private Sub Form_Load() Slowly = False AtOpenLib (1) End Sub
Private Function wait_ms(delay As Integer) Dim StartOfWait As Long StartOfWait = GetTickCount
Do DoEvents Loop Until (GetTickCount - StartOfWait) > delay
End Function '***************************************************************** ' disconnect from the HID controller... '***************************************************************** Private Sub Form_Unload(Cancel As Integer) DisconnectFromHID End Sub
'***************************************************************** ' a HID device has been plugged in... '***************************************************************** Public Sub OnPlugged(ByVal pHandle As Long) If hidGetVendorID(pHandle) = VendorID And hidGetProductID(pHandle) = ProductID Then Me.Caption = " connected" ' ** YOUR CODE HERE ** End If End Sub '***************************************************************** ' a HID device has been unplugged... '***************************************************************** Public Sub OnUnplugged(ByVal pHandle As Long) If hidGetVendorID(pHandle) = VendorID And hidGetProductID(pHandle) = ProductID Then Me.Caption = "not connected" ' ** YOUR CODE HERE ** End If End Sub '***************************************************************** ' controller changed notification - called ' after ALL HID devices are plugged or unplugged '***************************************************************** Public Sub OnChanged() Dim DeviceHandle As Long ' get the handle of the device we are interested in, then set ' its read notify flag to true - this ensures you get a read ' notification message when there is some data to read... DeviceHandle = hidGetHandle(VendorID, ProductID) hidSetReadNotify DeviceHandle, True End Sub
'***************************************************************** ' on read event... '***************************************************************** Public Sub OnRead(ByVal pHandle As Long) ' read the data (don't forget, pass the whole array)... If hidRead(pHandle, BufferIn(0)) Then tvolt = BufferIn(2) tmilli = BufferIn(3) tvolt1 = BufferIn(4) tmilli1 = BufferIn(5) ch0 = tvolt + (tmilli / 100) ch1 = tvolt1 + (tmilli1 / 100) ' ** YOUR CODE HERE ** ' first byte is the report ID, e.g. BufferIn(0) ' the other bytes are the data from the microcontrolller... End If End Sub
and it's working :) ... but it still kinda slow ... 1 mean to catch up 100 - 200 hz signal ... but still good for monitoring purposes :)
