Title: Hi-Tech PIC Compiler latest versions Post by: mnasabir on February 22, 2006, 02:45:11 02:45 :cool: info:
http://upload.caxapa.ru/ (http://upload.caxapa.ru/) direct Links http://upload.caxapa.ru/PICC9.50pl2NoHiTide.rar (http://upload.caxapa.ru/PICC9.50pl2NoHiTide.rar) http://upload.caxapa.ru/PICC-18_9.50_manual.rar (http://upload.caxapa.ru/PICC-18_9.50_manual.rar) http://upload.caxapa.ru/PICC_9.50PL2_manual.rar (http://upload.caxapa.ru/PICC_9.50PL2_manual.rar) :eek: http://upload.caxapa.ru/PICC-18_9.50_13Feb2006.rar (http://upload.caxapa.ru/PICC-18_9.50_13Feb2006.rar) Title: Hi-Tech PIC Compiler latest versions Post by: maveric on February 22, 2006, 06:06:54 06:06 The file read.me can be had with the codes of activation in English?
A lot of graces. Title: Hi-Tech PIC Compiler latest versions Post by: sam_des on February 22, 2006, 01:27:08 13:27 Really Great..
A very crude Translation of "read.me" .... ****************************************** I?? 9.50?L2, healthy. For reduction of the size are not included: plug-ins for Find fault-Ôá®ñá also with a management. To unpack in " C: \Program Files \HI-TECH Software \ " To start C: \Program Files \HI-TECH Software \PICC \9.50 \resources \setup.exe To be connected to the Internet and to request a 28-day's demo the license. If so it is impossible to be disconnected from the Internet, to remove a branch HKEY_LOCAL_MACHINE \Software \HI-TECH Software \PICC \9.50 - ---it is possible to create and start a file clean.reg - it will clean this branch - --- REGEDIT4 [-HKEY_LOCAL_MACHINE \Software \HI-TECH Software \PICC \9.50] - ---the end of a file - --- And to lead offline activization. To not forget to start C: \Program Files \HI-TECH Software \PICC \9.50 \bin \MPLABConfig.exe And to register a way to C: \Program Files \HI-TECH Software \PICC \9.50 \bin \picc.exe For the compiler, the assembler and ???????. ************************************************************ Though I followed above instructions, I am not able to "activate" it. :( Can anyone tell, How to do that ???? Thanks, Sam Title: Hi-Tech PIC Compiler latest versions Post by: maveric on February 22, 2006, 01:48:16 13:48 A lot of graces sam_des, but I have unloaded these files
http://upload.caxapa.ru/PICC9.50pl2NoHiTide20Feb.rar (http://upload.caxapa.ru/PICC9.50pl2NoHiTide20Feb.rar) http://upload.caxapa.ru/PICC-18_9.50_20Feb2006.rar (http://upload.caxapa.ru/PICC-18_9.50_20Feb2006.rar) and if you copy them above an installation DEMO, these they work. Hi. Title: Hi-Tech PIC Compiler latest versions Post by: sam_des on February 22, 2006, 05:30:03 17:30 Hi Maveric,
A very Heart-felt thanks. I downloaded files pointed by you. Though the compiler still shows as "Evaluation Version", it's expiary date is now "27th Sept. 1976". Well I guess that's OK. I also checked that compiler compiles for code > 1KWord. Does evaluation version has any other limitations ? Can you check that ? HI-TECH's web says as follows ... ******* The demo programs below are intended for prospective customers of HI-TECH Software to evaluate our products before making a purchase decision. The demos typically have some deliberate limitations compared to the full versions. Also, the demos are time-limited and will expire within approximately 28 days after installation. ******* Anyways, Thanks a lot again. _Sam Title: Hi-Tech PIC Compiler latest versions Post by: sam_des on February 25, 2006, 02:51:12 14:51 Hi Dax
Here it is, as you wish . 1. Application Name : HI-TECH PICC C Compiler & PICC-18 C Compiler 2. Version : 9.50 PL2 3. Description : PIC-14 & PIC-18 C Compilers. PL2(Patch Level-2) released in Feb, 2006 4. Size of Download : About 2-3 Mbytes for Actual compilers' zip & 1-2 MBytes for "pdfs" 5. Link To Download : PIC-14 :- http://upload.caxapa.ru/PICC9.50pl2NoHiTide20Feb.rar PIC-18 :- http://upload.caxapa.ru/PICC-18_9.50_20Feb2006.rar 6. Now these are "evaluation versions" active for 28-days with activation key from HI-TECH. But just register the ".reg" file in compiler zip file & you will get the evaluation version with expiry date -> "27th Sept. 1976". As there will be no one with computer-clock ticking backwords, I guess it'll never expire. There is minor problem though. HI-TECH says that they've deliberately kept something out of "evaluation version". But what it is, I don't know. Package contains everything from "lib-sources" to all tools. It compiles code >1kByte hex output. So you've a eval version with no expiry & not the full version. What you call it now, depends on you. By the way, there is no need to taunt someone for having English as second language. Just ask to repeat more clearly. We are here to help each other despite the language barriers. No offence intended. & Hoping that harmony of our forum will not be disturbed by trivial matters as language. _Sam "Et quacunque viam dederit fortuna sequamur" Title: Hi-Tech PIC Compiler latest versions Post by: sam_des on February 26, 2006, 01:16:08 13:16 Hi Dax,
May be I just over-reacted !! But as I said "No Offence Intended" _Sam "Et quacunque viam dederit fortuna sequamur" Title: HI-TECHPICC18v.9.50 Post by: robban on March 02, 2006, 10:33:23 22:33 I tested the above and got this output aftyer a compilation:
HI-TECH PICC-18 COMPILER (Microchip PIC micro) V9.50 Copyright (C) 1984-2006 HI-TECH SOFTWARE licensed for evaluation purposes only FAE license only - not for use in commercial applications licensed for educational use only this licence will expire on Mon, 27 Sep 1976 Full optimization and all other options are available. When you are trying to compile the canned examples You might get strange messages about obsolete options, don't worry, because it's it's only the difference between one and two dashes in front of command line options(change in syntax). Of course You must edit the PICC18.reg file in the "resources" folder to suite your needs(in my case I had to change InstDir"="C:\\PICC-18\\9.50". After that You'll be a happy C18-developer For those interested I included the -help output (http://www.sonsivri.com/forum/images/icons/icon7.gif) Title: Hi-Tech PIC Compiler latest versions Post by: lucasdark on March 09, 2006, 04:48:48 16:48 I did not find:
http://upload.caxapa.ru/PICC9.50pl2NoHiTide.rar (http://upload.caxapa.ru/PICC9.50pl2NoHiTide.rar) http://upload.caxapa.ru/PICC_9.50PL2_manual.rar (http://upload.caxapa.ru/PICC_9.50PL2_manual.rar) Can somebody help us with an other link. Thanks, Title: Hi-Tech PIC Compiler latest versions Post by: zerro on May 14, 2006, 12:03:57 00:03 Go here and you'll find what you looking for. (on the first page)
http://upload.caxapa.ru (http://upload.caxapa.ru) Good luck! :) Title: Hi-Tech PIC Compiler latest versions Post by: btreng on June 16, 2006, 12:13:50 12:13 hi
i didnt find picc 9.50 at this page http://upload.caxapa.ru (http://upload.caxapa.ru) somebody help me? Title: PICC 9.50PL2 workaround Post by: robban on June 18, 2006, 03:30:33 15:30 This is the PICC v.9.50PL2, plus original 9.50. There is no visible difference between the two as far as I can see...
See the Readme.txt in 9.50 folder http://rapidshare.de/files/23406381/htpicc950.rar.html (http://rapidshare.de/files/23406381/htpicc950.rar.html) http://rapidshare.de/files/23402406/PICC9.50PL2.rar.html (http://rapidshare.de/files/23402406/PICC9.50PL2.rar.html) Title: Hi-Tech PIC Compiler latest versions Post by: ruggine on June 19, 2006, 10:03:15 10:03 what language is written the file readme?
can someone translate it in English? thanks Title: Latin Post by: robban on June 19, 2006, 02:28:45 14:28 Sorry 'bout that...
Title: Hi-Tech PIC Compiler latest versions Post by: draggy on June 23, 2006, 10:25:37 10:25 anyknow know where does hi-tech hide it license in window registry? I mean th path...
I have installed it once with the 28 demo license, now 28 days pass my license expired so i re-request the 28 demo license but it keep on saying your license expired.......... I deleted everything related to hi-tech, which include directory and .reg registery..... :( Can anyone help me to reactive the 28 days license? Thanks Title: HI-Tide v.9.50 Post by: robban on June 23, 2006, 08:55:07 20:55 Hi!
Instead of fiddling with registry do like this: HI-TECH PICCv.9.50 comes in a bundle consisting of the 'picc-demo', a 'cgpic' and the PICC-engine. It also includes a reg.file called 'htpicc9.50'. Start the picc-demo, request a 28 day demo(be sure to be online) and then uncheck HI-TIDE integration(which I find useless). When the install is finished, copy cgpic and picc into the bin folder of Hi-TECH insallation dir. After that, register the 'reg.file into the register(be sure to set the path according to Yr. needs). When it comes to the PICC18, You have to copy the folder PICC-18 to a folder of Yr. choice. Next open the folder 'Resources' and there You will find an 'setup' file. Run it and choose a 28-day evaluation. Run the Reg.file again and all features will be avaible...:) Godd luck and return if it doesn't work Title: Hi-Tech PIC Compiler latest versions Post by: robban on June 23, 2006, 09:55:32 21:55 By the way, if You plan to upgrade PICC9.50 to 9.50PL2, You just have to copy the reg.file in the PICC 9.50 install folder to PIC9.50PL2 and change the reg.file to [HKEY_LOCAL_MACHINE\SOFTWARE\HI-TECH Software\PICC\9.50PL2].
Title: Hi-Tech PIC Compiler latest versions Post by: draggy on June 23, 2006, 10:57:50 22:57 ok..... I stuck at the request 28 days demo license it say your license expired
Title: Hi-Tech PIC Compiler latest versions Post by: draggy on June 24, 2006, 01:49:59 13:49 now can't compile error 128
Title: install problem Post by: ahmetuyanik on July 17, 2006, 07:50:18 07:50 Dear All,
I have hi-tech pic programmer 9.50 and I had installed. accidentally I uninstalled. Unfourtunately I can't install again because of the evaluating period of 28 days has ended and I can't install again. If you have any idea please share with us. Many Thanks, Title: Hi-Tech PIC Compiler latest versions Post by: daemone on July 19, 2006, 04:16:06 16:16 Thanks for ur contribution!!!!!!! a gifted man
Title: Hi-Tech PIC Compiler latest versions Post by: lavaboy on August 03, 2006, 05:27:53 17:27 Where did all the PICC 9.50pl2 download gone?
Title: Hi-Tech PIC Compiler latest versions Post by: lavaboy on August 04, 2006, 04:34:07 16:34 oops...sorry didn't check the other thread. Robban has it there.:)
Title: Re: Hi-Tech PIC Compiler latest versions Post by: KSA on October 20, 2006, 07:49:59 19:49 Hi,
I download picc_9_50_PL2_2006_05_03.rar from the http://upload.caxapa.ru/ BUT it's password protected. Please what is the password for this file. KSA Title: Re: Hi-Tech PIC Compiler latest versions Post by: xirix on October 31, 2006, 08:34:04 08:34 It should be "НеДляЛиберастов"
Title: Re: Hi-Tech PIC Compiler latest versions Post by: c0rnn on October 31, 2006, 10:09:53 10:09 Incorrect password.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: xirix on October 31, 2006, 03:33:04 15:33 Sorry, this is for PICC-18_9.50PL2_23oct2006_pass.rar
Give me a ftp: I'll upload picc9.50pl2 without pass. Title: Re: Hi-Tech PIC Compiler latest versions Post by: bookcat on October 31, 2006, 06:03:40 18:03 hi xirix
thanks for help :) Above password not work for PICC-18_9.50PL2_23oct2006_no pass.rar also. I have tried it. can u upload to rapidshare (both rar file without password) thank you. Title: Re: Hi-Tech PIC Compiler latest versions Post by: cerebronico on November 01, 2006, 02:11:32 02:11 These new stickies are awesome! Thanks! THANK YOU FOR PROVIDING RECENT COMPILER. How did you got this working?, I downloaded both files but have no password, could you please share it?? Title: Re: Hi-Tech PIC Compiler latest versions Post by: ashan on November 01, 2006, 04:23:56 04:23 lots of people downloaded the same including me!!!
without password how we use the same please give proper infrmation regarding the same thanks ashan :'( Title: Re: Hi-Tech PIC Compiler latest versions Post by: xirix on November 01, 2006, 06:35:22 06:35 Uploaded at http://rapidshare.com/files/1512124/PICC_9.50_PL2.tar.bz2
Title: Re: Hi-Tech PIC Compiler latest versions Post by: c0rnn on November 01, 2006, 08:16:38 08:16 Thanks xirix! But what does the read.me say? I can't read any of that... There is no crack included and it would change back to trial version I think.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: xirix on November 01, 2006, 09:02:18 09:02 It's a FAE release; run \..\PICC\9.50\resources\PICC9.50PL2_REG.reg to activate
then \..\PICC\9.50\bin\MPLABConfig.exe for MPLAB Read.me it's in russian. All PICC versions from upload.caxapa.ru are FAE releases. Title: Re: Hi-Tech PIC Compiler latest versions Post by: c0rnn on November 01, 2006, 09:19:57 09:19 Hey thanks! I just copied all the files to ..\PICC\9.50 and than ran PICC9.50PL2_REG.reg and MPLABConfig.exe.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: carlos789 on November 01, 2006, 09:36:44 21:36 I am beginning to use DSPICC 9.50 of HITECH with the MPLAB . The Project is:
#include <stdio.h> void main (void) { puts("Hello, world!"); } But when compiling I have the following error, it doesn't recognize the instruction PUTS: Executing: "C:\Archivos de programa\HI-TECH Software\HTSOFT\dsPICC_9.50\bin\dspicc.exe" -C -E"uno.cce" "uno.c" -O"uno.obj" -I"C:\Archivos de programa\HI-TECH Software\HTSOFT\dsPICC_9.50\lib" --opt=c_all,+as_all -G -Q --IDE=MPLAB --chip=30F6014 Executing: "C:\Archivos de programa\HI-TECH Software\HTSOFT\dsPICC_9.50\bin\dspicc.exe" -E"uno.lde" "C:\Archivos de programa\HI-TECH Software\HTSOFT\dsPICC_9.50\Ejemplos\uno\uno.obj" -M"uno.map" -O"uno.cof" -O"uno.hex" -G -Q --IDE=MPLAB --chip=30F6014 Error[499] 0 : undefined symbol: _putch (C:\Archivos de programa\HI-TECH Software\HTSOFT\dsPICC_9.50\lib\dspicc-sc.lib: puts.obj) BUILD FAILED: Tue Oct 31 16:30:59 2006 It doesn't pass the same thing when I use PICC-18 I would Thank a lot that somebody helps me Title: Re: Hi-Tech PIC Compiler latest versions Post by: xirix on November 02, 2006, 08:20:23 08:20 You should add following line at the top of your source file
#include <conio.h> Title: Re: Hi-Tech PIC Compiler latest versions Post by: xirix on November 02, 2006, 08:25:37 08:25 Added dsPICC_v9.60 at http://rapidshare.com/files/1648174/dsPICCv9.60Full.tar.bz2
Title: Re: Hi-Tech PIC Compiler latest versions Post by: xirix on November 02, 2006, 09:52:51 09:52 PICC18 at http://rapidshare.com/files/1654567/PICC-18_9.50PL2_23oct2006.tar.bz2
Title: Re: Hi-Tech PIC Compiler latest versions Post by: RedAlert on November 03, 2006, 05:25:35 17:25 what happened? who complainted??? :( :( :( :( greetings Xirix My guess: Guest(s)/user(s) who related to HT-SOFT company. Title: Re: Hi-Tech PIC Compiler latest versions Post by: xirix on November 05, 2006, 10:36:40 10:36 Sorry for all inconveniences;
'Something like that' will not happen again Title: PICC-18 PRO v9.61PL1 Post by: marcodassi on July 17, 2008, 06:28:49 18:28 Hello everybody :)
PICC-18 PRO v9.61PL1 is out! Lots of bugfixes, optimization, etc... http://www.htsoft.com/news/#news281 Anybody "got" it? :-X Regards, M EDIT:do not start a new topic for one thats open! & first post and it's a I want post too. Title: Re: Hi-Tech PIC Compiler latest versions Post by: preatorian on November 11, 2008, 12:12:37 00:12 Hi all,
here is user and email one to be able to update all compilers of hitech ;D: 1017432 [email protected] Title: Re: Hi-Tech PIC Compiler latest versions Post by: FriskyFerret on November 11, 2008, 04:22:31 04:22 Seems as if Hi-Tech doesn't agree with your assertion.
(http://img401.imageshack.us/img401/3498/73571287vz1.jpg) Title: Re: Hi-Tech PIC Compiler latest versions Post by: preatorian on November 11, 2008, 10:05:18 10:05 Hm, strange. OK then, Here is the package of all latest PIC compilers, WITHOUT the cracks. Includes:
hi-tide_v3.15.exe // test build HCPIC32-pro-9.60.exe // pic32 dsPIC-PIC24_9.60PL2-demo.exe // dspic HCPIC18P-PRO-9.63.exe // PICC-18 PRO HCPIC18-std-9.51PL2.exe // pic18 HCPICP-pro-9.60PL3.exe // HI-TECH C for the PIC10/12/16 MCU Family picc-std_9.60PL2-demo.exe file size: 169932 KB http://rapidshare.com/files/162695954/Hitech_PICC_suite.zip.html Title: Re: Hi-Tech PIC Compiler latest versions Post by: 2MRoss on November 11, 2008, 12:58:23 12:58 http://rapidshare.com/files/162695954/Hitech_PICC_suite.zip.html Error This file is neither allocated to a Premium Account, or a Collector's Account, and can therefore only be downloaded 10 times. This limit is reached. :( Title: Re: Hi-Tech PIC Compiler latest versions Post by: FriskyFerret on November 11, 2008, 04:00:16 16:00 If you didn't buy a Rapidshare account, they block access to your files after 10 downloads. Rapidshare changed their policy lately and have rendered their service basically useless unless you pay them.
This has been announced on the board many times but will probably be a nuisance for months to come. Use the file hosting service of your choice other than Rapidshare unless you own an account. Title: Re: Hi-Tech PIC Compiler latest versions Post by: preatorian on November 11, 2008, 06:18:06 18:18 Try these links:
http://www.mediafire.com/?or5ydmjrzw2 // part 1 http://www.mediafire.com/?0lmlukdmdeh // part 2 Title: Re: Hi-Tech PIC Compiler latest versions Post by: kigba on November 12, 2008, 06:28:56 18:28 Hi,
how to download from http://www.mediafire.com/ thnx Title: Re: Hi-Tech PIC Compiler latest versions Post by: preatorian on November 12, 2008, 07:14:46 19:14 Hi, Hi,how to download from http://www.mediafire.com/ thnx click on the links I posted, then click the link named "Click here to start download..". Your download shall start. Title: Re: Hi-Tech PIC Compiler latest versions Post by: tete on November 14, 2008, 04:35:59 16:35 can anyone suggest where to obtain crack for dsPIC-PIC24_9.60PL2-demo.exe?
I have a crack for version 9.60 Is it posible to apply it in some shape or form to newer version? Regards Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on November 25, 2008, 04:59:23 04:59 Tete try this i saw your post and made the demo "pro" for you
do me a favour tho please test it fully and let me know any bugs ill sort them for you U saw it here first!! :) ps..no key needed :) bunion i removed attachment ..22 downloads cool get it here now finished project >>> Re: Hi-Tech PIC Compiler latest versions « Reply #79 on: December 05, 2008, 10:29:16 22:29 » Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on November 25, 2008, 06:10:11 18:10 Hello bunion,
thank you very very very much for your work :) If you're going to "make" PICC-18 PRO 9.63 PL1, I'll gladly check it out (I think PL0 still has some problems)... Best regards, Mark Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on November 25, 2008, 10:54:29 22:54 no probs will do, i never knew newer version was out ie..pl1 from pl0
bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: newboy on November 26, 2008, 05:00:20 05:00 LATEST PICC18 PRO v9.63 ill do picc32 and picc later ... of course if u have enuff savvy u can check changes i make and apply them yourselves :) U saw it here first :) bunion i removed attachment get it here now _http://www.4shared.com/file/73081957/ed9e73c/PIC18_PRO_V963.html?dirPwdVerified=4ebe3674 Can u share also the demo version in www.4shared.com ... as i confius to download it from the original site, if u done mind. thanks. Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on November 26, 2008, 08:16:35 08:16 marcodassi ,,please test the omniescent code gen part plz ok ..cheers :)
bunion finished project >>> Re: Hi-Tech PIC Compiler latest versions « Reply #79 on: December 05, 2008, 10:29:16 22:29 » Title: Re: Hi-Tech PIC Compiler latest versions Post by: acat_lm on November 26, 2008, 10:55:16 10:55 Hi,
HI-TECH PICC STD v9.60 PL2: http://rapidshare.com/files/167533311/9.60PL2.rar Password: sonsivri HCPIC-pro-960PL3.exe: http://rapidshare.com/files/165911150/HCPICP-pro-9.60.rar Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on November 26, 2008, 12:21:11 12:21 Thanks a lot, bunion - very appreciated!
There's still a problem, but I cant tell if it's my program (I really don't think so, 'cause it compiles OK with the "non-pro" picc18), my winshit installation or the hi-tech compiler. With picc-18 pro 9.63 PL0 I get this error while linking: HI-TECH PICC-18 PRO COMPILER (Microchip PIC micro) V9.63 Copyright (C) 1984-2008 HI-TECH SOFTWARE Serial number: HCDSPIC-xxxxx Advisory[1233] Employing 18F4525 errata work-arounds: Advisory[1234] * Corrupted fast interrupt shadow registers Advisory[1234] * Data in RAM location can be corrupted if async. reset occurs during write Error [712] C:\Program Files\HI-TECH Software\PICC-18\PRO\9.63\sources\asftadd.c; 6. can't generate code for this expression strange enough, asftadd.c is one of hi-tech source files (look at the directory) ! BUT, with picc-18 pro 9.63 PL1 (the latest bunion one), I get a nice *CRASH* while linking!... I'll try later with a simpler source project, but, I repeat, I've got no problem compiling & linking with STD version. Anyway, thanks bunion for his work! (I think crack is OK, but hi-tech is still gettin' a lot of problems with his "pro" series) cheers mark UPDATE: I try the 18PRO-9.63 PL1 without the bunion crack, and it give me some (linker) error but NO CRASH: HI-TECH C PRO for the PIC18 MCU Family V9.63PL1 Copyright (C) 1984-2008 HI-TECH SOFTWARE licensed for evaluation purposes only this licence will expire on Fri, 09 Jan 2009 Advisory[1233] Employing 18F4525 errata work-arounds: Advisory[1234] * Corrupted fast interrupt shadow registers Advisory[1234] * Data in RAM location can be corrupted if async. reset occurs during write Error [712] C:\Documents and Settings\Administrator\Desktop\xxxxx\Firmware\BaseConversions.c; 526. can't generate code for this expression Error [712] C:\Documents and Settings\Administrator\Desktop\xxxxx\Firmware\I2C.c; 70. can't generate code for this expression well, those errors are really strange, but let's go ahead: after I copy bunion's cracked .exes into bin dir, I get: HI-TECH C PRO for the PIC18 MCU Family V9.63PL1 Copyright (C) 1984-2008 HI-TECH SOFTWARE Serial number: HCPIC18P-DEMO FAE license only - not for use in commercial applications licensed for educational use only Advisory[1233] Employing 18F4525 errata work-arounds: Advisory[1234] * Corrupted fast interrupt shadow registers Advisory[1234] * Data in RAM location can be corrupted if async. reset occurs during write and then the nice *CRASH* :) cgpic18.exe has encountered a problem and needs to close. We are sorry for the inconvenience AppName cgpic18.exe AppVer 0.0.0.0 ModName cgpic18.exe ModVer 0.0.0.0 Offset: 0000eea8 hope this helps :) cheers M Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on November 26, 2008, 04:58:11 16:58 great marc with ur help we will beat it
ok...i was being fancy so ill keep it simple ..new patch has 1 changed byte so it will always be evaluation with no expiry...u must use included reg file tho ...good luck... Title: Re: Hi-Tech PIC Compiler latest versions Post by: 94491203 on November 26, 2008, 05:06:46 17:06 Hi, HI-TECH PICC STD v9.60 PL2: http://rapidshare.com/files/167533311/9.60PL2.rar Password: sonsivri HCPIC-pro-960PL3.exe: http://rapidshare.com/files/165911150/HCPICP-pro-9.60.rar please updata again Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on November 26, 2008, 07:08:19 19:08 marc and others heres latest patch to test...this will work now :)
link deleted ... bunion ps..plz let me know if working now Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on November 26, 2008, 08:31:00 20:31 Hello bunion,
thanks again for all yr efforts. Here are the results: picc18.exe + picc18.reg CRASH picc18.exe + picc181.reg CRASH picc18.exe + picc182.reg CRASH 2picc18.exe + picc18.reg CRASH 2picc18.exe + picc181.reg CRASH 2picc18.exe + picc182.reg CRASH (*) 3picc18.exe + picc18.reg don't even start in MPLAB (MPLAB does not recognize it) 3picc18.exe + picc181.reg don't even start in MPLAB (MPLAB does not recognize it) 3picc18.exe + picc182.reg don't even start in MPLAB (MPLAB does not recognize it) One question: should I replace the "cgpic18.exe" file too (from older crack) ? And one note: on the test marked with (*), I got this message (just before crashing): HI-TECH C PRO for the PIC18 MCU Family V9.63PL1 Copyright (C) 1984-2008 HI-TECH SOFTWARE licensed for evaluation purposes only FAE license only - not for use in commercial applications licensed for educational use only (1273) Omniscient Code Generation not available in Lite mode (warning) this licence will expire on Mon, 27 Sep 1976 Phone me if u need me makin' some other tests ;) and thank you again ;D M Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on November 27, 2008, 04:37:52 04:37 hmm marc thanks but...u r meant to rename each file back to picc18.exe b4 starting so u started with picc18 then afterwards u put that somewere abd u take 2picc18 and rename to picc18 so on and so on
the 1st picc18.exe has 1 change so it wonyt expire...they all work here no crashes picc18 + 1st reg =evalution no expirty..wotks great in hitide 3.15 using pwm sample 3picc18 = PRO " " 2picc is a mix of thetoo so leave that with the other reg they both run as eval and education and fae so that we r on same hymm sheet plz try in hittide please as mines dont crash????? thankss marc we will get there :) bunion ps..yes dont use patched cg exe till we get ur picc18 running so delete that or install demo again using 35553 as reg key amd checking offline install as pro then browse to folder and place picc18 in bin folder and dbl cli8ck 1st reg .. then run in hitide ide..using a sample from picc18 samples and see how u get on ... it looks ok here but im not a pic person so ur the tester...ill make changes axxording to what you find out there all code same so we fix one we get them all heh good luck :) Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on November 27, 2008, 02:53:38 14:53 Hello bunion!
Here's the deal: we're gonna use this great program for testing, the chip is PIC18F4525 (any PIC18 will do, however): void main(void) { volatile unsigned char a, b, c; a = b + c; } Here are the results (using MPLAB IDE, sorry, but I have no time to learn HI-TIDE now :) with PICC18 STD 9.51 PL3: ------------------------- optimizations: global (9), assembler large memory mode, code pointer size = 16 bit HI-TECH PICC-18 STD COMPILER (Microchip PIC micro) candidate build 2908 V9.51PL3 Copyright (C) 1984-2008 HI-TECH SOFTWARE Serial number: HCPIC18-xxxx this licence will expire on Thu, 31 Dec 2037 Advisory[1233] Employing 18F4525 errata work-arounds: Advisory[1234] * Corrupted fast interrupt shadow registers Advisory[1234] * Data in RAM location can be corrupted if async. reset occurs during write Memory Summary: Program space used 1Ah ( 26) of C000h bytes ( 0.1%) Data space used 3h ( 3) of F80h bytes ( 0.1%) EEPROM space used 0h ( 0) of 400h bytes ( 0.0%) External data memory None available ID Location space used 0h ( 0) of 8h nibbles ( 0.0%) Configuration bits used 0h ( 0) of 7h words ( 0.0%) This is the generated code: 0000: LFSR 0, 0xfd NOP CLRF POSTINC0, ACCESS CLRF POSTINC0, ACCESS CLRF POSTINC0, ACCESS GOTO main main: MOVLB 0 MOVF c, W, BANKED ADDWF b, W, BANKED MOVWF a, BANKED GOTO 0 NOP Looks and run OK, as usual. with PICC18 PRO 9.63 PL1, DEMO installation with 45 day license: ---------------------------------------------------------------- optimizations: global (9), assembler large memory mode, code pointer size = 16 bit HI-TECH C PRO for the PIC18 MCU Family V9.63PL1 Copyright (C) 1984-2008 HI-TECH SOFTWARE licensed for evaluation purposes only this licence will expire on Fri, 09 Jan 2009 Advisory[1233] Employing 18F4525 errata work-arounds: Advisory[1234] * Corrupted fast interrupt shadow registers Advisory[1234] * Data in RAM location can be corrupted if async. reset occurs during write Warning [1257] C:\Documents and Settings\Administrator\Desktop\test\test.c; 5. local variable "_b" is used but never given a value Memory Summary: Program space used Eh ( 14) of C000h bytes ( 0.0%) Data space used 3h ( 3) of F80h bytes ( 0.1%) EEPROM space used 0h ( 0) of 400h bytes ( 0.0%) ID Location space used 0h ( 0) of 8h nibbles ( 0.0%) Configuration bits used 0h ( 0) of 7h words ( 0.0%) Saved some ROM bytes :) Here's the generated code: 0000: GOTO main main: MOVF c, W, ACCESS ADDWF b, W, ACCESS MOVWF a, ACCESS GOTO 0 NOP Looks nice, compiler has automatically placed all our vars into ACCESS area (faster), and there's no cloacks in the code (like the 3 * "CLRF POSTINC0, ACCESS" generated by PICC18 STD) with PICC18 PRO 9.63 PL1, DEMO installation + bunion's "picc18.exe" AND picc18.reg ---------------------------------------------------------------------------------- optimizations: global (9), assembler large memory mode, code pointer size = 16 bit HI-TECH C PRO for the PIC18 MCU Family V9.63PL1 Copyright (C) 1984-2008 HI-TECH SOFTWARE Serial number: HCPIC-DEMO licensed for evaluation purposes only this licence will expire on Sat, 06 Dec 2008 Advisory[1233] Employing 18F4525 errata work-arounds: Advisory[1234] * Corrupted fast interrupt shadow registers Advisory[1234] * Data in RAM location can be corrupted if async. reset occurs during write Warning [1257] C:\Documents and Settings\Administrator\Desktop\test\test.c; 5. local variable "_b" is used but never given a value Warning [1269] ; . there are 9 days left until this licence will expire Memory Summary: Program space used 1Ah ( 26) of C000h bytes ( 0.1%) Data space used 3h ( 3) of F80h bytes ( 0.1%) EEPROM space used 0h ( 0) of 400h bytes ( 0.0%) ID Location space used 0h ( 0) of 8h nibbles ( 0.0%) Configuration bits used 0h ( 0) of 7h words ( 0.0%) Oh shit! :o What's happened? 0000: GOTO main main: MOVLB 0 MOVLB 0 MOVF b, W, BANKED MOVLB 0 MOVLB 0 ADDWF c, W, BANKED MOVLB 0 MOVLB 0 MOVWF a, BANKED GOTO 0 NOP Looks even WORST than PICC18 STD! Lot of unnecessary code in the sum! I think the compiler discovered that something has changed, and turn off the optimizer phase or something like that! This thing will happen with "picc18.exe" and "2picc18.exe" (obviously renamed to picc18.exe), with any .reg file; "3picc18.exe" is still not recognized by MPLAB IDE (at compiling time, IDE switchs to PICC18-STD) I think you can check it out by yourself, using the .c program at the top; just compile it and check if program bytes = 14 / 3 (like in the second example). Anyway, thanks for your efforts!!! ;) C U, Mark PS Just tested the "demo" version of PRO compiler (no cracks) on my current project, and it still crashes!... so, that wasn't bunion's fault ;D I think HI-TECH still has some bugs to squash.... Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on November 29, 2008, 06:36:17 18:36 NICE WORK Marcodassi...think we have cracked it bro...i didnt want to let u down so ive been on it 24/7 last 2 days thats y i didnt reply so heres code my patched picc18 ( patched by my all hitech universal patcher :P ) <PROPER
HI-TECH C PRO for the PIC18 MCU Family V9.63PL1 Copyright (C) 1984-2008 HI-TECH SOFTWARE Advisory #1192: ; : licensed for evaluation purposes only Advisory #1193: ; : this licence will expire on Wed, 14 May 2031 Advisory #1233: ; : Employing 18F4525 errata work-arounds: Advisory #1234: ; : * Corrupted fast interrupt shadow registers Advisory #1234: ; : * Data in RAM location can be corrupted if async. reset occurs during write Warning #1257: ..\main.c; 3: local variable "_b" is used but never given a value (col ) Build complete for project ooo Time consumed: 2500 ms. hmm im gettimg the line a=b+c highlighted as a prob in hitide b4 i even start heres code its a mess think yet i think it might be a hitide prob mayb? 146 00BFF4 _main: 147 opt stack 31 148 ; BSR set to: ? 149 00BFF4 0100 movlb 0 ; () banked 150 00BFF6 51FF movf (??_main+2)& (0+255),w,b ;volatile 151 00BFF8 25FE addwf (??_main+1)& (0+255),w,b ;volatile 152 00BFFA 6FFD movwf ??_main& (0+255),b ;volatile 153 ;main.c: 6: } 154 ; BSR set to: ? 155 00BFFC EF00 F000 goto start 156 i tried mplab but dunno how to create a simple progam in that please advise my fix is whole diff way from last attemps ps im newbie wi pics cheers bunion think you can check it out by yourself, using the .c program at the top; just compile it and check if program bytes = 14 / 3 (like in the second example). 10/3 here ps... Title: Re: Hi-Tech PIC Compiler latest versions Post by: solarwind on November 30, 2008, 07:09:27 19:09 Does anyone have the latest version of the PICC18 pro compiler?
Posted on: November 30, 2008, 08:07:09 20:07 - Automerged Nevermind, I found them: http://www.4shared.com/network/search.jsp?searchmode=2&searchName=picc18 Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on December 01, 2008, 09:18:13 09:18 Cheers bunion!!!
Thank you very much for all yr efforts I'm gonna d/l yr new patch and try it... I'll let you know if it's ok now :) Sorry but I'm out of my home these days, got a shitty 56k line and can't be online 24/7 as usual ;D See you, - m Posted on: December 01, 2008, 10:14:43 10:14 - Automerged woops bunion, where's the patch? :) please gimme a link ;D ;D ;D Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 01, 2008, 10:36:20 22:36 marcodass this any better ??
this licence will expire on Sun, 09 Dec 2029 Advisory[1233] Employing 18F4525 errata work-arounds: Advisory[1234] * Corrupted fast interrupt shadow registers Advisory[1234] * Data in RAM location can be corrupted if async. reset occurs during write Warning [1257] C:\Program Files\Microchip\Third Party\PICC\Examples\main.c; 3. local variable "_b" is used but never given a value Memory Summary: Program space used 12h ( 18) of C000h bytes ( 0.0%) Data space used 3h ( 3) of F80h bytes ( 0.1%) EEPROM space used 0h ( 0) of 400h bytes ( 0.0%) ID Location space used 0h ( 0) of 8h nibbles ( 0.0%) Configuration bits used 0h ( 0) of 7h words ( 0.0%) --- C:\Program Files\Microchip\Third Party\PICC\Examples\main.c -------------------------------- 1: void main(void) { 2: volatile unsigned char a, b, c; 3: a = b + c; BFF6 5001 MOVF 0x1, W, ACCESS BFF8 2402 ADDWF 0x2, W, ACCESS BFFA 6E00 MOVWF 0, ACCESS 4: } BFFC EF00 GOTO 0 i did it in mplab ..y does it show my main.c code in with the finished deal...please advise..must admit my code looks cool now eh? bunion Posted on: December 01, 2008, 11:33:44 23:33 - Automerged marcodassi i just mised u plz get back to me soon as bro Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on December 02, 2008, 07:48:02 07:48 Hello bunion!
I'm still alive but I can't be online 24/7 these days, I have to use a old analog 56k line :( Please gimme a link to download your patcher, I can't see it in your latest posts!... ;D so I can test it too Cheers, mark Posted on: December 02, 2008, 08:18:31 08:18 - Automerged BTW, now your code looks really COOL!!! I think you've finally done it ;D ;D ;D ;D Title: dspicc pl2 download Post by: tete on December 02, 2008, 02:31:14 14:31 Bunion,
thanks very much for dspicc pl2 however I cannot download from link Do you have an alternate? Regards, Tete Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 02, 2008, 03:32:03 15:32 tete yes ..plz pm me YOUR demo key to check if it runs any pc key
thanks bunion if not ill built one 4 u :) never mind thats silly ill send u a tester see pm Posted on: December 02, 2008, 03:34:12 15:34 - Automerged ok everyone that people got testers for picc18,dspicc and c51...teter is to show it never expires when using valid demo key...im now onto 2nd stage ..making them all run on same key im on it folks :) dont release testers plz im workin hard on ths for u all :) Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 04, 2008, 07:57:29 07:57 SUCCESS!!!!!!!!!!!
Finally got it running as pro eval with any license and no expiry till 2030 somthing ive gave tester to marcodassi and ferret and once they say its ok ill create patches for all the latest versions job done :) Title: Re: Hi-Tech PIC Compiler latest versions Post by: mitsos on December 04, 2008, 09:38:40 09:38 hi
can you share the crack? regards mitsos Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 04, 2008, 01:04:33 13:04 miltos certainly,
im doing it for the members here but we3 r still testing at mo ...just got pm from marc saying he needed regfile altered which i done...just waiting on word from marcodassi and frisky_ferret and if alls well we.ll release fixes for all hitechprods bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on December 04, 2008, 01:53:14 13:53 ;D ;D ;D SUCCESS ;D ;D ;D
Please take a bow to BUNION who finally got it running OK! :D My friend, you've really done it, congratulations, this is very appreciated!!! Code is OK now and the compiler will expire on 2029 something... Again, thank you very much! Next step will be a universal cracker appz for all hitech's compilers! Best regards, thank you and call me whenever you need! Mark Title: Re: Hi-Tech PIC Compiler latest versions Post by: 94491203 on December 04, 2008, 02:07:12 14:07 I cannot download this files,who can share the crack files?
Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 04, 2008, 03:04:32 15:04 great marco thx, heh:)
ok taking dog for a walk then ill come back and start releasing :);):) ps...sorry marco did u download the regfix or sort it by just uninstalling + reinstalling it? ..the reg rar i made doesnt seem to have been downloaded?....dont want to add stuff thats not needed plz advise Title: Re: Hi-Tech PIC Compiler latest versions Post by: newboy on December 04, 2008, 06:54:26 18:54 Just for remind !
Please upload the software and patch all together to avoid any confusion. If possible please upload also into Megaupload. Thanks Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on December 04, 2008, 09:40:39 21:40 Hello bunion,
I've downloaded the regfix and then everything worked OK, don't know why there's no download traces ??? I think you should include the fixed .reg in your release, just for safety... Thank you again my friend ;D Mark Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 05, 2008, 09:29:16 21:29 no probs marc thank you mate
LATEST Hitech compilers available HCPICP-pro-960PL3...Full HCPIC18P-PRO-963PL1...Full HCPIC32-pro-960...Full dsPIC-PIC24_960PL2...Full HC51_PRO_970...Full HCPSOC-pro-9.61PL2...Full See 50caliber's excellent sticky which deserves a big thank you! :) Enjoy bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: si_bin on December 06, 2008, 01:24:06 13:24 bunion: mor thx for u work
i have download the "HCPICP-pro-960PL3...Full", but i found there is no "picc.reg" in the rar package, and others worked ok!! Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 06, 2008, 01:29:01 13:29 okidoke si_vin thx letting me know...ill sort it noe
Title: Re: Hi-Tech PIC Compiler latest versions Post by: 94491203 on December 07, 2008, 03:14:52 15:14 download the "HCPIC18P-PRO-9.63PL1...Full", but i found there is no "1st_picc18.reg,cgpic18.exe,picc18.exe" in the rar package
Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 07, 2008, 06:56:55 18:56 the "HCPIC18P-PRO-9.63PL1...Full", but i found there is no "1st_picc18.reg,cgpic18.exe,picc18.exe" in the rar package
ill check again thx hmmm just checked everythings there bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on December 08, 2008, 07:01:33 19:01 hello bunion
just checked... there's no .reg file in this archive: HCPICP-pro-960PL3...Full _http://www.4shared.com/file/74686183/3c20e9fa/HCPICP-pro-960PL3.html can you please check out all of them? I think there's a problem with 4shared.com... maybe you can pack up the releases with a password (like "sonsivri" or "bunion"), so 4shared won't mess it up thank you! and have a nice day ;D Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 09, 2008, 03:23:16 03:23 HCPICP-pro-960PL3...Full ******UPDATED***** Now includes reg file and works as pro in HITIDE...so best to redownload :)
bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: jzaghal on December 09, 2008, 04:09:40 16:09 Hi,
Link not valid!! Please upload to Rapidshare. Thanks. Title: Re: Hi-Tech PIC Compiler latest versions Post by: speedtripleaja on December 10, 2008, 11:35:12 23:35 The file link that you requested is not valid.
:'( Sorry Posted on: December 11, 2008, 12:23:43 00:23 - Automerged Sorry, the link in the post marcodassi is not correct... http://www.4shared.com/file/75121911/61ea7933/HCPICP-pro-960PL3g.html Thanks Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 15, 2008, 05:02:20 05:02 LATEST Hitech compilers here ****UPDATED with HCPSOC-pro TO COMPLETE the SET****
HCPICP-pro-960PL3...Full ******UPDATED***** HCPIC18P-PRO-963PL1...Full HCPIC32-pro-960...Full dsPIC-PIC24_960PL2...Full HC51_PRO_970...Full HCPSOC-pro-961PL2...Full See 50caliber's excellent sticky which deserves a big thank you! :) Enjoy bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: localcrack on December 15, 2008, 05:41:12 05:41 hello bunion
is all the files requires to download ....? Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 15, 2008, 03:28:34 15:28 yes localcrack :)
bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on December 16, 2008, 01:36:05 13:36 Quote This file is no longer available because of claim by HI-TECH Software. >:( Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on December 16, 2008, 06:43:33 18:43 ...Doesn't work...
:( Title: Re: Hi-Tech PIC Compiler latest versions Post by: metal on December 16, 2008, 08:49:54 20:49 You better wait people, bunion is working hard on it, give him some time, and no need for million posts complaining about links not working, one post is enough.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: lillbear on December 17, 2008, 02:10:33 14:10 well i downloaded them..with no fuzz. but personaly i prefer mihd or ifile. Compilers not tested yet.
yours Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on December 17, 2008, 06:52:18 18:52 Bunion - I think Dropbok links only work if you are logged into the account. They do not appear to be public links.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 17, 2008, 07:00:38 19:00 i know so i removed em from there and put them elsewhere see my last post above « Reply #97 ....mums the word :)
bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 17, 2008, 07:57:23 19:57 hi pickit
sorry, thats the way i was taught to add links in forums as peeps have to copy n paste the link to use as apposed to just dbl clicking... why? pasting doesnt leaves a trace back to the board...dbl clicking links do its a saftety thing those links r dead now anyway hopefully metal will change sticky to my reply #97 bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: pickit2 on December 17, 2008, 08:04:59 20:04 you can still copy and paste ie. http://www.4shared.com/file/76018857/2d3b8f57/HCPSOC-pro-961PL2.html
just left click and hold mouse button after the end of what you want to copy and release when you reach start of Text/Links your after. Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on December 17, 2008, 11:10:03 23:10 Edit - New links 04 February 2010 - Mirror of individual files as of this date:
8051-C_9.01 with HI-TIDE_2.13.rar (20.68 MB) http://www.multiupload.com/FQCPZOEZK0 ARMC9.rar (17.86 MB) http://www.multiupload.com/NJHR5F00P0 HC8051-pro-9.70.rar (7.76 MB) http://www.multiupload.com/UPG42ESRW3 HC8051-pro-9.70PL1.3321_release_candidate.rar (7.78 MB) http://www.multiupload.com/5KRPIUCBPE HCDSPIC-std-9.60.PL3.rar (7.84 MB) http://www.multiupload.com/VC8OAG930J HCDSPIC-std-9.60.PL3_Patch_only.rar (16.86 KB) http://www.multiupload.com/2PLFVP973U HCDSPIC-std-9.60PL3-2903_release_candidate.rar (7 MB) http://www.multiupload.com/M13XRYBM7P HCPIC18-std-9.51PL2.rar (16.14 MB) http://www.multiupload.com/FZ0BO4A3SL HCPIC32-pro-9.60PL1.3453_release_candidate.rar (14.33 MB) http://www.multiupload.com/2NFROBYIGK HCPICP-pro-9.60PL5.rar (5.76 MB) http://www.multiupload.com/JG4DSSER6B HCPIC-pro-9.65.rar (5.72 MB) http://www.multiupload.com/ZX6OKQPERG HCPIC-pro-V9.65PL1.rar (5.89 MB) http://www.multiupload.com/KT2CQ33TIF HCPIC-std-9.60PL3.rar (8.11 MB) http://www.multiupload.com/5APWOHU85Q HCPSOC-pro-9.61PL4.rar (4.3 MB) http://www.multiupload.com/AA6SU8QG5R HCPSOC-pro-9.61PL5.3451_release_candidate.rar (4.31 MB) http://www.multiupload.com/K2Y8S5LH93 HI-TECH Enterprise Edition.rar (49.94 MB) http://www.multiupload.com/LYDDQ13EU4 HI-TECH for HOLTEK C.rar (2.56 MB) http://www.multiupload.com/JLBQ2GYK6T HI-TECH PICC-18 9.51 PL3 RC.rar (16.26 MB) http://www.multiupload.com/Q7H7GZ4DMW HI-TECH PICC PRO 9.70.rar (5.53 MB) http://www.multiupload.com/AE7BMBILM7 HI-TECH Universal Patcher.rar (19.09 KB) http://www.multiupload.com/2W2OXPRTA9 msp430c.rar (77.28 KB) http://www.multiupload.com/B8WX6HOYA2 PIC18_PRO_963PL3_Patch.rar (16.96 KB) http://www.multiupload.com/LAUN1IY8FQ HCPIC18-pro-9.63PL3+Patch.rar (26.06 MB) http://www.multiupload.com/HIEDCYXEBD XA773P1.rar (1.78 MB) http://www.multiupload.com/31KQO0TTUS HCPIC18-pro-9.64.5502.rar (17.97 MB) http://www.multiupload.com/RSCHS4X7PB HCPIC18-pro-9.64.5502_Patcher.rar (17.75 KB) http://www.multiupload.com/DX3XDBHNG0 HI-TECH ENTERPRISE PLATINUM SUITE.rar (98.76 MB) http://www.multiupload.com/94H2NQQGLU HI-TECH PIC32-PRO-9.60 PL2 Patcher.rar (17.48 KB) http://www.multiupload.com/7NCHK51UT4 HI-TECH PIC32-PRO-9.60 PL2.rar (17.79 MB) http://www.multiupload.com/KJKSWHI7BD Password (if needed) unchanged = Sonsivri See my post of 04 February 2010 for old links. Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on December 18, 2008, 07:56:31 07:56 I have a strange error with picc18 pro:
Code: error 140: can't open library file "C:\Program Files\HI-TECH Software\PICC-18\PRO\9.63\lib\pic82l-l.lpp": No such file or directory This file it's not there. Does anyone experienced this? Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 18, 2008, 02:03:57 14:03 Here's an all-in-one (70MB - you only need to download one of the links) :D GREAT JOB 50caliber hopefully someone will make your post a sticky too :) tavioman sorry dunno why u got that but think its a prob in YOUR projects code or something...try cleaning ur project and retry...i dont use these tools as im just a learner good luck bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: sohel on December 18, 2008, 03:20:43 15:20 its work for me without any problem.
thanks Title: Re: Hi-Tech PIC Compiler latest versions Post by: preatorian on December 18, 2008, 09:55:58 21:55 Hi. Any chance of sharing the latest non PRO version for PIC 10,12,16 ?
Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on December 19, 2008, 06:12:06 06:12 I must say. I'm really impressed by the PICC18 PRO version. Amazing flash saver. Amazing.
Regarding the problem I posted in my previous post, I solved. Was just something wrong with the command line arguments. Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 23, 2008, 03:08:17 03:08 LATEST Hitech compilers here ****UPDATED with HCPSOC-pro TO COMPLETE the SET**** HCPICP-pro-960PL3...Full ******UPDATED***** HCPIC18P-PRO-963PL1...Full HCPIC32-pro-960...Full dsPIC-PIC24_960PL2...Full HC51_PRO_970...Full HCPSOC-pro-961PL2...Full members only see attachment for details :) Enjoy bunion New addition >> HCPSOC-pro-961PL4...Full thanks to pika for headsup :) bunion for singles see info in my post below for complete set see 50calibers exellent sticky Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 24, 2008, 02:52:15 02:52 New addition >> HI-TECH C PRO for the PIC10/12/16 MCU family candidate build 4612 V9.65PL1
HI-TECH C PRO Universal Software Patch reg files are always updated to cover latest versions! Pack changes : HCPICP-PRO-9.60PL5 HCPIC18P-PRO-9.63PL1 HCPIC32-PRO-9.60 dsPIC-PIC24_STD_9.60PL2 are now bundled together in a HI-TECH Enterprise Edition Single packs: HCPIC-std-9.60PL3 HCPIC18-std-9.51PL2 HCPSOC-pro-9.61PL4 HC8051-pro-9.70 HI-TECH C for Holtek-9.10PL6 HI-TECH ARM-C v9.12 + HI-TIDE_2.12PL3 HI-TECH for XA v7.73PL1 - legacy compiler 8051-C_9.01 with HI-TIDE_2.13 HCPICP-PRO-9.60PL5 added as single! HCPIC-pro-9.65 added 24th march! Release_candidates: HCPIC32-pro-9.60PL1.3453_release_candidate HCPSOC-pro-9.61PL5.3451_release_candidate HCDSPIC-std-9.60PL3-2903_release_candidate HC8051-pro-9.70PL1.3321_release_candidate HI-TECH C PRO for the PIC10/12/16 MCU family candidate build 4612 V9.65PL1 added 22nd may :) Please note that release candidate builds have not necessarily been tested to the same degree as official releases, and should be used at your own risk. ALL packs include Universal patch upgrade for singles see info (new one with links!) ...links are old now so just use common sense :) for complete set see 50calibers exellent sticky BUNDLES UPDATED FEB 02 BY 50CALIBER SO SEE STICKY :) ...and you never know if he gets a couple of thanks for all the work he's put in he might just update his COMPLETE BUNDLES Sticky :) Hassle free installing see kcsoft's post few posts below Enjoy bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on December 26, 2008, 08:34:24 20:34 Hi Bunion - Are there more pending updates? If not, I will do a re-up when I get home from the holiday. Thanks for your hard work on these.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 27, 2008, 07:17:52 19:17 Nope thats it for now 50caliber :)
bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on December 30, 2008, 02:13:34 02:13 Nope thats it for now 50caliber :) bunion Done. :D Title: Re: Hi-Tech PIC Compiler latest versions Post by: sonsivritwchen on December 30, 2008, 03:42:05 15:42 Hi, 50Caliber,
All the attached files are compressed and encrypted twice. The 'www.sonsivri.com' password can only decompressed the first compression level. Each compiler, for example, PIC18, are compressed and encrypted with a password different from 'www.sonsivri.com'. In short, one can not decompress these files. Please provide the password for the second compression. Best regards Title: Re: Hi-Tech PIC Compiler latest versions Post by: FriskyFerret on December 30, 2008, 05:08:52 17:08 Wasn't the password given in the attachment of http://www.sonsivri.com/forum/index.php?topic=935.msg69555#msg69555 ?
50Calibre repackaged the bunion archives for our convenience. So doesn't it follow that bunion's passwords would still be on the original archives? Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on December 30, 2008, 06:00:30 18:00 Hi, 50Caliber, All the attached files are compressed and encrypted twice. The 'www.sonsivri.com' password can only decompressed the first compression level. Each compiler, for example, PIC18, are compressed and encrypted with a password different from 'www.sonsivri.com'. In short, one can not decompress these files. Please provide the password for the second compression. Best regards Thanks for pointing out. There is a Info.txt inside my all-in-one archive which states the password (pass=Sonsivri). I will add a note in my sticky post with the internal password. Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 31, 2008, 03:22:52 03:22 LATEST Hitech compilers here HCPICP-pro-960PL4...Full HCPIC18P-PRO-963PL1...Full HCPIC32-pro-960...Full dsPIC-PIC24_960PL2...Full HC51_PRO_970...Full HCPSOC-pro-961PL4...Full See 50caliber's excellent sticky which deserves a big thank you! :) Enjoy bunion Latest addition HI-TECH ARM-C v9.12 + HI-TIDE_2.12PL3 HI-TECH for ARM Architecture - legacy compiler^ Delivering excellent code density and reliability, HI-TECH for ARM allows embedded firmware development in a fraction of the time required for conventional assembly language programming. Programs may be comprised of any mix of ARM or Thumb™ functions. Features: ANSI C - full featured and portable Efficient - equals or betters hand-written assembler code Reliable - based on HI-TECH Software's mature, field-proven embedded compiler and tools technology Modular - includes full object code linker and library manager Cost-effective - productivity gains rapidly repay purchase cost Compatible - command-line driver integrates into 3rd-party development tools Library Source - for standard libraries and sample code for I/O drivers Complete - includes macro assembler, preprocessor and one-step driver This is genuinely licensed to 50caliber!!! erm well its fully licensed to his name without patching :) Latest addition HI-TECH for XA v7.73PL1 - legacy compiler Philips Semiconductors’ XA (eXtended Architecture) family of high-performance single-chip microcontrollers are powerful 16-bit devices with an architecture based on the popular 8051 family, but without the 8051’s 8-bit limitations. HI-TECH for XA provides the programmer with a total development system for C and assembler. HI-TECH for XA is used by Philips and others in projects ranging in size up to multi-megabytes. It was the first XA compiler available, and is still the best choice for serious projects. Several different memory models are offered by compile-time selection. In Huge model the XA’s Harvard architecture (separate data and program memory spaces) is hidden from the programmer. Enjoy bunion for singles see info couple posts above (new one with links!) for complete set see 50calibers exellent sticky Work in progress more to come :) Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 06, 2009, 12:42:47 00:42 Latest additions >> HI-TECH C PRO Universal Software Patch
HI-TECH C PRO for the PIC32 MCU Family V9.60 Copyright (C) 1984-2008 HI-TECH SOFTWARE Serial number: HCPIC32-***** this licence will expire on Wed, 12 Dec 2029 Completely reworked my patch so looking like it should :):) ive learnt a lot so keygen maybe soon! Also HI-TECH C for Holtek MCU v9.10PL6 Featuring the latest code generation technology, HI-TECH for HOLTEK MCU is a high-performance C compiler for the full range of HOLTEK embedded microcontrollers. HI-TECH for HOLTEK MCU Compiler Features: ANSI C, full featured and portable, supporting all standard data types Reliable - mature, embedded tools and technology Unlimited number of source files Multiple optimization levels Comprehensive C library with all source code provided Includes support for 32-bit IEEE floating point and 32-bit long data types Mixed C and assembler programming Listings showing generated assembler Optimizing assembler Full linker, with overlaying of local variables to minimize RAM usage Compatible - integrates into many 3rd-party development tools Enjoy bunion for singles see info couple posts above (new one with links!) for complete set see 50calibers exellent sticky Work in progress more to come :) see attachment for Universal patch password Title: Re: Hi-Tech PIC Compiler latest versions Post by: preatorian on January 06, 2009, 07:02:07 19:02 Hi all,
All this is very nice but is there any chance hi-tech or any other company-producer to read this and fix their next release so the keygens and cracks stop working? Regards Title: Re: Hi-Tech PIC Compiler latest versions Post by: omni on January 06, 2009, 11:34:10 23:34 @praetorian
of course, it's a game of cat and mouse, and I bet they read this and other forums where files are posted. But that never stopped people in the past and it should really be a message to all these companies who spend large amounts of time and money developing crazy ways of software protection to simply drop it and spend those resources in bettering their products instead. Just my 2c. Title: Re: Hi-Tech PIC Compiler latest versions Post by: ennio on January 07, 2009, 07:51:37 07:51 Hi
New update avaliable HI-TECH C PRO for the PIC10/12/16 MCU Family 9.60.4.3834 http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en535448 patch not working. regards ennio Title: Re: Hi-Tech PIC Compiler latest versions Post by: preatorian on January 07, 2009, 11:07:09 11:07 HI all,
here is direct download link to PICC PRO v9.60PL4: http://www.htsoft.com/portal/demo-picpro Release notes: http://www.htsoft.com/microchip/products/compilers/documentation/hcpicp-readme.pdf Regards Title: Re: Hi-Tech PIC Compiler latest versions Post by: kcsoft on January 08, 2009, 03:18:04 03:18 I made an installer for Hi-tech PICC. In just 2 clicks you can install one of these compilers
PICC STD 9.60 PICC PRO 9.60PL4 PICC-18 PRO 9.63PL1 dsPICC24 9.60PL2 PICC32 9.60 The package also contains my favorite editor for Hi-TECH. Credits for fixing go to bunion. I take credits for re-packing. Download one of these. No pass. http://rapidshare.com/files/180913878/Hi-TECH.7z.html (http://rapidshare.com/files/180913878/Hi-TECH.7z.html) http://www.filefactory.com/file/a012ah4/n/Hi-TECH_7z (http://www.filefactory.com/file/a012ah4/n/Hi-TECH_7z) It works fine for me but i need confirmation that it works on a clean machine. Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 08, 2009, 05:06:07 05:06 HI-TECH C PRO Universal Software Patch updated to work with HI-TECH PICC 9.60.4.3834
Pack changes : HCPICP-PRO-9.60PL4 HCPIC18P-PRO-9.63PL1 HCPIC32-PRO-9.60 dsPIC-PIC24_STD_9.60PL2 are now bundled together in a HI-TECH Enterprise Edition Single packs: HCPIC-std-9.60PL3 HCPIC18-std-9.51PL2 HCPSOC-pro-9.61PL4 HC8051-pro-9.70 HI-TECH C for Holtek-9.10PL6 HI-TECH ARM-C v9.12 + HI-TIDE_2.12PL3 HI-TECH for XA v7.73PL1 - legacy compiler ALL packs include Universal patch upgrade for singles & Enterprise bundle see info couple posts above for complete set see 50calibers exellent sticky Hassle free installing see kcsoft's post Enjoy bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on January 08, 2009, 10:03:17 10:03 Hello bunion, glad to see you still workin' on these compilers ;D
how can I get the updated universal software patch you mention on your latest post? I see no link... (HI-TECH C PRO Universal Software Patch updated to work with HI-TECH PICC 9.60.4.3834) Thanks and happy new year! (I got flu , not a nice new year start, anyway) Update 1: From Hitech site, noy you can download only PICC 9.60.4.3851, does the patch still works on it??? Update 2: Just published: Patch Level Update - PICC STD v9.60PL3 Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 08, 2009, 03:53:55 15:53 hi marcodassi ...it should do
..also didnt think STD versions mattered if you already had the PRO version? anyway ive now updated the storage with these std versions HCPIC-std-9.60PL3. HCPIC18-std-9.51PL2 also corrected an error in patcher that missed few bytes on picc std cg so grab current patcher :) marcodassi...for latest patcher see my "info" attachment few posts above bro bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on January 08, 2009, 04:12:03 16:12 hi bunion :)
got the updates, thank you very much. I have a suggestion: append a "version number" on your patcher so we all know if we've got the latest one, thanks :) about "std": well, i like to use the "pro" version, but some very big projects i'm working on doesn't compile on "pro" version (lots of strange errors, etc.) and it's not your fault (they do the same on demo version). cheers! ;D Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 08, 2009, 04:23:39 16:23 hi bunion :) got the updates, thank you very much. I have a suggestion: append a "version number" on your patcher so we all know if we've got the latest one, thanks :) about "std": well, i like to use the "pro" version, but some very big projects i'm working on doesn't compile on "pro" version (lots of strange errors, etc.) and it's not your fault (they do the same on demo version). cheers! ;D Latest will always be the currently upped one marco...no slacking here bro :) bunion erm in saying that the patcher in Enterprise pack is older than current standalone patcher....still works tho for those enterprise versions and std too but it has slight error so it doesnt fully patch picc std cgpic.exe only halve of it ..so thats y the update :) Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on January 08, 2009, 06:18:27 18:18 PATCHER PROBLEMS
hello again bunion, I think there are some problems with the PRO versions of the compiler. I've written a short program to let you check it out on your PC; I've already report my personal results on the comments at the top. // // Test program for HI-TECH compilers // // This program is used to test the generated code size for microchip 10/12/16 and 18 // MCU family HI-TECH C compilers; result should be compared only with same compiler version // // Selected MCU for 10-12-16 family is PIC12F629 // Selected MCU for 18 family is PIC18F4525 // // All compiler options are leaved as "defaults" after installation // // Compiler 45-day demo Cracked :) // ROM/RAM ROM/RAM // ---------------------------------------------------------------------------------------------- // // HI-TECH PICC 9.60 PL3 141/17 141/17 OK (bunion crack) // HI-TECH C PRO for the PIC10-12-16 MCU Family 9.60 PL4 125/20 164/22 BAD (bunion crack) // // HI-TECH PICC-18 9.51 PL3 RC 266/14 266/14 OK (Kappa crack) // HI-TECH C PRO for the PIC18 MCU Family 9.63 PL1 254/15 272/17 BAD (bunion crack) // // Obviously, there should be no difference in code size between "demo" and "cracked" versions // unsigned char add1(unsigned char, unsigned char); unsigned char add2(unsigned char, unsigned char); unsigned int power(unsigned char, unsigned char); void main(void) { volatile unsigned char a, b, c; unsigned int i, j; a = b + c; i = a * 2; j = i * i; a = add1(b, c); c = add2(a, b); j = power(a, b); if (i <= j) a = b - c; else c = (unsigned char) j - a; i <<= 7; } unsigned char add1(unsigned char i, unsigned char j) { return i + j; } unsigned char add2(unsigned char i, unsigned char j) { return i + j; } unsigned int power(unsigned char i, unsigned char j) { unsigned int p = 1; while (j--) p *= i; return p; } As you can see, it seems the same old problem that I've discovered about a month ago, when you begin to crack the compilers; for example, variables should be promoted to "ACCESS" type (kinda of "register") instead of "BANKED"; this should save a lot of rom code and greatly speed up program execution I hope all the community use this super-program ;D as a check for future releases too I've uploaded "HI-TECH PICC-18 9.51 PL3 RC" to dropboks, just in case you wanna see how "kappa" cracked the beast (and also this is a nice update for all picc-18 std users :) ) Also, another suggestion for the patcher: if you copy it into destination directory, make it find the files automatically :) keep the good times roll! - mark Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 08, 2009, 10:45:37 22:45 hehe nice one marco :)
...thats what i like im on it bro :) shouldnd need to copy somebody elses work as way ive done it is sweet :) bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 09, 2009, 12:38:00 00:38 ps marcodassi i just came back to say ..your quick to forget ive already successfully cracked all these latest versions so no need to go looking at other peeps old work bro..you forgot i cracked latest picc18 for u ???
only prob is im trying to be fancy now and run them all off the same key which i see now has a problem BUT snyone can go to 50calibers sticky and download latest working versions because he upped the ones i cracked individually so dont worry folks no need to use old stuff we still have the very latest WORKING compilers here at Sonsivri :) bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on January 09, 2009, 12:51:27 00:51 hey bro :)
don't panic, I know you've successfully cracked entire hi.tech production :) I tested "kappa" crack just because I've just restored the hard disk image (new year cleanup) and in that image there was kappa's crack already installed and I was in a hurry to inform you about latest patch problems ;D tomorrow I'll check out the 50calibers version and tell you what's happen thank you again ! ciao marco PS btw, my greatest program ;D can still be used to check out next cracks Title: Re: Hi-Tech PIC Compiler latest versions Post by: solarwind on January 09, 2009, 02:46:26 02:46 I'm getting this warning in HI-TIDE: (1273) Omniscient Code Generation not available in Lite mode for both the PICC compiler and PICC18 compiler.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: mick on January 09, 2009, 12:18:08 12:18 1. uninstall older soft
2. clean regs 3. new install 4.(dont forget double click reg files) Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on January 09, 2009, 03:08:51 15:08 Bunion - Let me know when you want to "release" these, and I'll update the all-in-one.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 10, 2009, 04:58:33 04:58 OK Universal patch is current for all versions mentioned above except STD....theyll be done once i get the keys
patched apps have been tested using marcs tester so fully working ...reverted back to individual keys but still using uni patcher enjoy bunion ps currently deleting and upping fresh packs so wait a bit ...latest patch has CURRENT on end of name ok :) Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on January 10, 2009, 07:40:23 07:40 Got it. ;D
Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on January 10, 2009, 11:27:16 11:27 hi bunion
i've downloaded the massive pack from 50caliber, but i see that there are not the latest versions of compilers... for example: HI-TECH C PRO for the PIC10/12/16 latest version from hi-tech site is 9.60.4.3851 50caliber version is 9.60.4.3206 i'm hoping for a new patcher from you ;D ;D ;D ciao, have a nice day - marco Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 10, 2009, 11:56:58 11:56 50calber cheers bro DONT redo ur bundles till we have all current versions...ie we need someone like marc who has access to there UPDATES PAGE to share them :)
marcosassi ...my last post is when i reupped current patcher and redone the singles and Enterprise pack for all current versions we know about ( after u reported problems ) except internal hitech updates we dont know about?....and 50calibers holding off till ALL are current SORRY MARC :( that STD u upped isnt old its a currenT updated std yes?...one for general download is picc18 STD pl2 ur one is PL3!!! bunion http://www.sonsivri.com/forum/index.php?topic=935.msg69555#msg69555 << ATTACHMENT SEE HERE :) Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on January 10, 2009, 12:13:05 12:13 hi bro
well, I've uploaded picc-18 9.51 PL3 RC, which is a Release Candidate (can't remember where I found it), but I'm using it from a while and found no problems with it. for all other compilers, I have no newer version than the ones you or 50calibers have hope this helps :) ciao marco Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 10, 2009, 06:19:03 18:19 okidoke
ANYONE got access to updates page so we can be sure all versions are bang up to date? i know at least one we are missing HI-TECH C PRO for the PIC10/12/16 9.60.4.3851 50caliber bundles only has version 9.60.4.3206 and my info.txt one is 9.60.4.3834 so please if u can fill in the gaps or better still link us to downloadable versions that r newer then that be great :) I also make a promise that if someone is kind enough to share there login details with me for updates then I would NEVER pass on those details and would only login to check for new versions and nothing else bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: preatorian on January 10, 2009, 08:21:59 20:21 Bunion,
here are links to direct download the latest compilers from htsoft. If you are unable to download, I can do it for you and share them. regards Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 12, 2009, 02:39:04 02:39 LATEST NEWS on uploads to HITECH STORAGE
Re-done and uploaded >> HCPIC-std-9.60PL3 HCPIC18-std-9.51PL2 both FULLY working New addition for mick and others >> 8051-C_9.01 with HI-TIDE_2.13 allows them to use 8051 in hitide ide :) bunion http://www.sonsivri.com/forum/index.php?topic=935.msg69555#msg69555 << ATTACHMENT SEE HERE Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 12, 2009, 05:21:58 05:21 LATEST NEWS on uploads to HITECH STORAGE
New additions >> HCPIC32-pro-9.60PL1.3453_release_candidate HCPSOC-pro-9.61PL5.3451_release_candidate HCDSPIC-std-9.60PL3-2903_release_candidate HC8051-pro-9.70PL1.3321_release_candidate bunion http://www.sonsivri.com/forum/index.php?topic=935.msg69555#msg69555 << ATTACHMENT SEE HERE Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on January 12, 2009, 04:48:56 16:48 50calber cheers bro DONT redo ur bundles till we have all current versions...ie we need someone like marc who has access to there UPDATES PAGE to share them :) Bunion - I'll do an upload when you're ready. Will sit tight till then. You are definitely on a "mission" with this project. Good luck. :D Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on January 12, 2009, 08:34:07 20:34 i'm dreaming of the "bunion total supersimple patcher"; install the compiler, launch bunion's trick, press "Ok" and everything's up and running
;D ;D ;D go ahead bunion we're all with you ;D ;D ;D yeah Title: Re: Hi-Tech PIC Compiler latest versions Post by: RedAlert on January 12, 2009, 11:04:31 23:04 i'm dreaming of the "bunion total supersimple patcher"; install the compiler, launch bunion's trick, press "Ok" and everything's up and running ;D ;D ;D go ahead bunion we're all with you ;D ;D ;D yeah Even better - why not make a keygen for it? We have here other good crackers as well, which can help bunion doing it... Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 13, 2009, 05:45:58 17:45 i'm dreaming of the "bunion total supersimple patcher"; install the compiler, launch bunion's trick, press "Ok" and everything's up and running ;D ;D ;D go ahead bunion we're all with you ;D ;D ;D yeah Thats easy...id just need to rar say PICC18 folder with pre-cracked exes and inlude reg file in resources folder with readme.txt saying "click reg file :) just like those older fae versions that werew going about...or simple installer that does same but adds reg file for u :) kcsoft made an installer for us already :) >> http://www.sonsivri.com/forum/index.php?topic=935.msg70545#msg70545 RedAlert to be honest keygenning is beyond me bro..im sure if i took the time to learn it seem a lot easier as it sounds at the mo..i guess that most of the code for making keygens come from the softs themselves so the majority of the learning part will be understanding all the different key algo's there is and then earning how to find them in your targets code..I have cracked a couple of apps though where i made it generate a valid serial in message box instead of saying "wrong serial" :) bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 14, 2009, 05:58:24 17:58 Kcsoft ive downloaded and tested your hitech installer
>>http://www.sonsivri.com/forum/index.php?topic=935.msg70545#msg70545 it works great,makes installing simple and looks professional!! Well done mate :) bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: kcsoft on January 14, 2009, 06:38:06 18:38 Thanks to you bunion.
I'm waitting for new/final releases of the latest versions before i'll make a new one. Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 14, 2009, 07:49:43 19:49 ok ta kcsoft :)
LOOK somebodys watching us post cracks on sonsivri and upping to a pay download service :( http://www.download-provider.com/search/HI-TECH+Universal+Patcher.html?aff.id=1805 bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: pickit2 on January 14, 2009, 07:56:21 19:56 http://www.download-provider.com/en/search/bunion-HI-TECH+Universal+Patcher.html
Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 20, 2009, 02:23:18 02:23 All our stuffs there pickit2 even kcsofts hitech installer heh
i wouldnt mind but im not allowed to download it :) bunion Posted on: January 14, 2009, 09:01:51 21:01 - Automerged LATEST NEWS on uploads to HITECH STORAGE New additions >> HCPICP-pro-9.60PL5 << Just released!! ..uploaded as a single ( includes uni patcher ) HI-TECH for HOLTEK PL6 re-upped ( includes uni patcher ) HI-TECH Universal Patcher_CURRENT.rar updated with new regfiles for holtek and picc PL5 Still to do ...add PICC PL5 to Enterprise pack ..thats why the single :) bunion http://www.sonsivri.com/forum/index.php?topic=935.msg69555#msg69555 << FOR MORE INFO & ATTACHMENT SEE HERE Title: Re: Hi-Tech PIC Compiler latest versions Post by: Jagi on January 25, 2009, 07:31:32 07:31 bunion, I downloaded the HCPICP-pro-9.60PL5 and used the crack on it. Result : Works great... Testing : I adapted some old CCS C code (about 8K), compiled with the latest HCPICP using your crack and the generated HEX file works exactly the same on the target. Additionally, the PRO is also doing its job. The original code and data compiled with CCS took 8050 bytes and with the HCPICP took 7520 bytes. Great job man... keep up the good work...
Title: Re: Hi-Tech PIC Compiler latest versions Post by: sohel on January 25, 2009, 02:10:35 14:10 Hello bunion.
Please make a Sticky post. If u dont mind. i personelly requested to u. Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 25, 2009, 09:09:09 21:09 sohel what you mean this one? >> http://www.sonsivri.com/forum/index.php?topic=935.msg69555#msg69555
stickys are made by mods so its up to them bro soz :) bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: 2MRoss on January 27, 2009, 11:14:02 11:14 hi,
BitDefender Free Edition v10 report: HI-TECH C PRO Universal Software Patcher.exe Infected: Trojan.Generic.1351947 ??? ??? ??? Rgds 2MRoss Title: Re: Hi-Tech PIC Compiler latest versions Post by: ajak on January 27, 2009, 11:16:41 11:16 disable first your bitdenfender software, kill its process. or turn off the antivirus, antispyware and firewall..
Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 27, 2009, 02:30:09 14:30 hi, BitDefender Free Edition v10 report: HI-TECH C PRO Universal Software Patcher.exe Infected: Trojan.Generic.1351947 ??? ??? ??? Rgds 2MRoss Yep my macavee virus scanner shows it as trojan too...and most other cracks keygens too..think its because they are made to modify code.....theres no virus in my universal patcher unless DUP+2 makes it a trojan when it makes patcher for me but i doubt they would do that..no probs here :) bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: 2MRoss on January 27, 2009, 10:53:28 22:53 Hi bunion,
thanks for your answer: false positive. Now I am more calm ;) 2MRoss Title: Re: Hi-Tech PIC Compiler latest versions Post by: jaikumar on January 29, 2009, 10:27:41 10:27 Where is the link to
HCPICP-pro-9.60PL5 << Just released!! ..uploaded as a single ( includes uni patcher ) Help somebody? Regards, Jai. Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 29, 2009, 04:54:29 16:54 http://www.sonsivri.com/forum/index.php?topic=935.msg69555#msg69555
bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on January 30, 2009, 04:38:11 04:38 Bunion - You ready for me to do an update ?
Title: Re: Hi-Tech PIC Compiler latest versions Post by: Manuel on January 30, 2009, 11:15:55 23:15 Checked with no problem 16 pro.
;-) Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 31, 2009, 06:02:39 18:02 Bunion - You ready for me to do an update ? Yer may as well thanks 50caliber...do me fav plz when upping can u put picc pl5 in enterprise pck plz in place of older pl4 cheers bro:) bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on February 01, 2009, 12:14:32 00:14 Will do - Bunion.
Edit - Done. ;D Title: Re: Hi-Tech PIC Compiler latest versions Post by: an on February 10, 2009, 08:04:21 08:04 Hi!
The latest version (HCPICP-pro-9.60PL6.4070.exe): http://depositfiles.com/files/g9m1t99ou Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on February 10, 2009, 06:45:06 18:45 Ok uni patcher tested successfully on latest picc PL6 above...
ill update a patcher reg file to suit but if u want to fix your current PICC.reg then just open it in notepad and change "pl5" to "pl6" :) LATEST HITECH Release INFO HERE http://www.sonsivri.com/forum/index.php?topic=935.msg69555#msg69555 bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: ALLPIC on February 27, 2009, 04:44:58 04:44 bunion too good I never though Hitech can be install and can be work for me by such a way :o
Thanks a lot Title: Re: Hi-Tech PIC Compiler latest versions Post by: aamir on February 27, 2009, 08:04:48 08:04 please upload at rapidshare with parts less than 40 mb use hjsplit software to split file
Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on February 28, 2009, 02:17:05 14:17 please upload at rapidshare with parts less than 40 mb use hjsplit software to split file Try this: http://rapidshare.com/files/203465067/htbun3split40.part1.rar.html http://rapidshare.com/files/203465080/htbun3split40.part2.rar.html http://rapidshare.com/files/203465028/htbun3split40.part3.rar.html http://rapidshare.com/files/203464992/htbun3split40.part4.rar.html http://rapidshare.com/files/203464995/htbun3split40.part5.rar.html No pass on this, but see my sticky for pass of contained files. Title: Re: Hi-Tech PIC Compiler latest versions Post by: aamir on March 01, 2009, 07:13:21 07:13 WHAT IS DIFFERENCE BETWEEN HTBUN2 AND HTBUN3 HAVE WE DOWNLOAD ALL SETUPS OR ONY PATACHES
APRIACIATES FOR BROKEN DOWNLOADS Title: Re: Hi-Tech PIC Compiler latest versions Post by: Manuel on March 12, 2009, 10:20:29 10:20 1 6 P R O_ P L 6.4 2 9 7 Patch that can be applied just to PL5 version of just published.
Hi u ALL. Title: Re: Hi-Tech PIC Compiler latest versions Post by: gem1144aaa on March 12, 2009, 12:19:59 12:19 hallow everyone
when i use the universal patcher and browse for the files lick picc.exe and so on it 1st make abackup copy then says nothing patched. ??? any body can explain what is going on? may thanx Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on March 12, 2009, 08:58:34 20:58 gem1144aaa it shouldnt make backups unless it patches something...think..
if you are trying to patch any of the versions listed in packs or patch pack then there guaranteed to be fully working ..ie..patchable...so u must be doing sumthing wrong heres routine you have 2 things>> 1..your hitech installer for prouct u want to install and patch 2..uni patch 1..you install your hitech compiler to chosen folder 2..run patch AFTER READING README.txt and patch your 2 exe files 3..double click included reg file for chosen compiler DONE:) if no success your doing something wrong or your trying to patch files not listedso try again bro ok :) good luck bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: gem1144aaa on March 12, 2009, 11:14:33 23:14 Hi bunion
i appreciate your fast responce the package i down loaded is the interprize one links at the top of all pages of this topic and i followd exactly the readme file then run the .reg files and i chosen the 2 correct .exe files but it searches for pattern 1,2 and 3 and it says no patterns found and nothing were patched Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on March 13, 2009, 01:21:42 13:21 okidoke gem1144aaa im downloading htbun3 pack from sticky above as we speak and will install all setups from enterprise pack to check
will edit post with results....DONE bunion ok iv'e tested the PICC 9.60 PL5 etc thats in the enterprise pack from htbun3 and ALL files patched ok Remember though, this is a universal patch which fixes a number of different files from different compilers so although it patches successfully there will still be some messages in patch window saying pattern not found main thing is if it worked correctly youll see a copy of patched file > .bak you should check to verify if patched or not by running compiler using this switch --version if ok youll see serial number etc :) its working great here :) Title: Re: Hi-Tech PIC Compiler latest versions Post by: gem1144aaa on March 15, 2009, 08:24:25 20:24 Hi bunion
i really appreciate your help i did what you said and executed the version test and its ok now my 2nd pop up now is initiating the hi tide it installed ok when i try to have a new project i chose file -> new project -> hitec c project it gives a new window with a title new project and one line saying You must specify a product before continuing. sorry i'm very newbie to hitec completely i always use mikrobasic and some mikroc and i want to make a change to hitec c thnaks again Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on March 19, 2009, 10:22:27 22:22 i know its a pain gem but best bet is to read the help files for hitide etc
i know answer to above...its asking you to choose which hiteck product to use in your new project..IF when installing hitech you ticked ADD TO SYSTEM PATH..then you will see your hitech product listed in a window in hitide good luck bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on March 26, 2009, 10:55:11 22:55 UPDATE...HCPIC-pro-9.65 has been added to the storage and uni patch updated:)
thanks to manuel for heads up see post below for details http://www.sonsivri.com/forum/index.php?topic=935.msg69555#msg69555 bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: aamir on March 27, 2009, 05:07:00 05:07 Please upload SPLIT file <50 MB ON RAPIDSHARE
Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on March 27, 2009, 08:17:16 08:17 Hey Bunion!
Can you please tell what is the difference between HI-TECH Universal Patcher.rar and HI-TECH Universal Patcher_CURRENT.rar? Thanks!! Title: Re: Hi-Tech PIC Compiler latest versions Post by: Manuel on March 27, 2009, 08:21:40 08:21 Big One!
;-) Title: Re: Hi-Tech PIC Compiler latest versions Post by: pozzolano on March 27, 2009, 12:17:04 12:17 Hi!
for the other files such as HI-TECH Enterprise Edition.rar is required password password: www.sonsivri.com is not correct Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on March 27, 2009, 02:39:21 14:39 sorry tavioman meant to delete current when i upped new patcher...
"current" pack doesnt have the new key for picc 9.65 <<will delete aamir what ones u need and ill email them with unipatcher? pozzolano pass=bunions_carboot < think :) Note... Universal patcher.exe didnt need updated as its still doing its job so only a new regfile was added for picc v9.65 pro Remember for small version changes like pl1 > pl2 > pl3 etc etc you can edit the key.reg yourselves by opening in notepad and changing the "pl" bits to suit any minor updates from hitech Latest PICC PRO v9.65 was a MAJOR version update thats why a new key was needed :) bunion ill add a note next time i redo patch pack ps aamir theres singles in the storage place in case you forgot that :) Title: Re: Hi-Tech PIC Compiler latest versions Post by: mitsos on March 28, 2009, 12:52:50 12:52 hi bunion
can you explain us, what does mean the message "can't find pattern. trying next one..." that patcher displays. of course the compiler is working. regards mitsos Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on March 28, 2009, 06:23:17 18:23 Hi mitsos
Current patcher is universal meaning it patches more than 1 program at a time, so when its running it'll scan through the exe looking for individual code patterns and if sucessfull it'll do its thing ,if not itll report back saying "pattern not found" and then proceed to look for the next pattern in the list This patcher patches %99 of ALL available Hitech compilers :) bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: bliviudaniel on April 02, 2009, 09:34:44 21:34 Quote UPDATE...HCPIC-pro-9.65 has been added to the storage and uni patch updated:) I've just downloaded htbun3.rar but I can't find the update related to HCPIC-pro-9.65. Maybe I missed something or it's not inside htbun3.rar...Can somebody help me to find this update, please. Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on April 03, 2009, 06:00:39 06:00 I've just downloaded htbun3.rar but I can't find the update related to HCPIC-pro-9.65. Maybe I missed something or it's not inside htbun3.rar...Can somebody help me to find this update, please. I need to update the uploads, but have been busy. Try: http://www.rapidspread.com/file.jsp?id=kzbhutd1nn pass = www.sonsivri.com This one contains only HCPIC-pro-9.65 and the patcher. Post back if there are any problems. Title: Re: Hi-Tech PIC Compiler latest versions Post by: bliviudaniel on April 03, 2009, 09:50:36 21:50 I installed picc 9.65, I compiled and I simulated in MPLABSIM a simple task scheduler and everything seems to be OK :)
Title: Re: Hi-Tech PIC Compiler latest versions Post by: ALLPIC on April 21, 2009, 05:01:26 05:01 Dear 50caliber & bunion
Can you please have a look on this, http://www.sonsivri.com/forum/index.php?topic=22189.new#new Because I also faced same problem. if you need I can upload my test code for that and we all can check and see is there problem because of crack or that is Hitech problem Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on April 23, 2009, 06:33:45 18:33 ALLPIC - I haven't had much time to test Bunion's work, but it is not uncommon to have minor incompatibilities between code compiled with v8 and v9. I think best way to verify whether problems exist in Bunion's versions is to install a legitimate trial on a virgin VM running XPSP3. It is always possible for HT to implement a hidden reg check.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: twonuts on May 07, 2009, 10:23:38 10:23 Is there an alternative patcher program for the enterprise edition?
Windows XP SP3 won't allow access to the existing one. I have tried with disabled firewall, antivirus, etc, and updated files from the archive file with these disabled. Same result. Telling Windows to run the patcher as administrator does not work either. The same result with all copies of patcher programs in the archive. AVG reports Gamer trojan in the patchers? False result? Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on May 07, 2009, 04:17:31 16:17 twonuts pather was made using dup 2 which is old way for me now asany patches made with it r reported as viruses so ill make new patch using codefusion patcher 3 ok :)
ALLPIC , upload your test code and the results u get using valid demo AND results using patcher and we will sort it :) BUT to be honest i think its working ok bro..any faults will be ur xp3 etc and not any protections in soft...xp3 is new yes? bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: twonuts on May 07, 2009, 06:15:31 18:15 twonuts pather was made using dup 2 which is old way for me now asany patches made with it r reported as viruses so ill make new patch using codefusion patcher 3 ok :) ALLPIC , upload your test code and the results u get using valid demo AND results using patcher and we will sort it :) BUT to be honest i think its working ok bro..any faults will be ur xp3 etc and not any protections in soft...xp3 is new yes? bunion Service pack 3 for Windows XP has been around for some time now. I have no idea why Windows won't allow the patcher program to run under any circumstances. Might be down to MicroSoft updates, possibly their malicious software program they insist on foisting onto me. I'll look forward to trying your updated one. Title: Re: Hi-Tech PIC Compiler latest versions Post by: ALLPIC on May 08, 2009, 05:17:25 05:17 Dear bunion,
I think crack is working fine, I tested with all version available with me. So there is problem with hitech not with the crack I am now sure on that. As I can't able to report this to hitech... :( Title: Re: Hi-Tech PIC Compiler latest versions Post by: DrSurfer on May 08, 2009, 10:26:55 10:26 A little addition as thank you for the excellent work: If you use a nationalized version of Windows the .REG files may need a little correction, adapting the InstDir key to the actual directory in your system.
For example in Win2k ITA the right one is "C:\\Programmi\\....", and not "C:\\Program Files\\..." I discovered this in the hard way ;) DrSurfer Title: Re: Hi-Tech PIC Compiler latest versions Post by: robban on May 11, 2009, 01:10:57 13:10 I downloaded several HI-TECH compilers and crack and got 7 Generic.dx trojans using Barts PE(DOS!!!
Good work, I must say... To be honest, I don´t give a rats ass about optimization. The MCU:s are so cheap so I don't have to worry about small code size, but it can be thought of as a code tutorial. I settle for my old compilers. ??? Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on May 11, 2009, 02:34:10 14:34 To be honest, I don´t give a rats ass about optimization. The MCU:s are so cheap so I don't have to worry about small code size, but it can be thought of as a code tutorial. I settle for my old compilers. ??? I must disagree with you. It's not about the price! I have an application that uses 99.9 % from a PIC18F4620(64K). I will use some optimisation if it will be more available. :)) Title: Re: Hi-Tech PIC Compiler latest versions Post by: Thiru09 on May 12, 2009, 10:18:34 10:18 Quote I must disagree with you. It's not about the price! Absolutely. Speed of optimized code will be greater than the code that is not optimized. So, always try to use optimization. Title: Re: Hi-Tech PIC Compiler latest versions Post by: robban on May 12, 2009, 11:15:21 11:15 Absolutely. Speed of optimized code will be greater than the code that is not optimized. So, always try to use optimization. Ever tried to debug a fully optimized code? A true nightmare... Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on May 12, 2009, 12:23:57 12:23 Ever tried to debug a fully optimized code? A true nightmare... You are right, but sometimes you don't have any solutions left than to use optimizations. The largest memory PIC18 for TQFP44 packages is 96K. And for large programs I cannot use larger flash PIC18 due to IC package.Title: Re: Hi-Tech PIC Compiler latest versions Post by: robban on May 12, 2009, 02:30:42 14:30 Well, I´ve been trying to step up to ARM, but the cost for development boards are high. (Futurlec has quite cheap ones(ST32F103B with 128K RAM, but no support whatsoever). I bought a parallell port JTAG dongle from Olimex and sometimes it's working, sometimes not. It's like playing Texas hold 'em. The best compiler I tried is Keil (with GNU toolchain), but it needs a startup code which I can live without. >:(
Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on May 12, 2009, 03:27:12 15:27 I want to step up to ARM also. I want to use Luminary Micro CORTEX-M3 devices.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: robban on May 13, 2009, 09:22:04 09:22 I want to step up to ARM also. I want to use Luminary Micro CORTEX-M3 devices. also use Cortex M-3.(ST32F10xxx, 128K RAM), but I had printed out the pin-out and placed it above my working bench, so I know how to connect. How much is a Luminary Cortex M-3 development board? Does it need a J-Link dongle?(they are expensive). My Futurlec board has two serial interfaces(one for downloading the hex, .bin or .s2 code) and one for connecting ex.wise a Telnet debugger. Normally I use the Telnet for debugging purpopses(I write additional code in critical sections for watching what's happening). Do You have a more clever solution? I stopped using Eclipse IDE since it's full of bugs. I think it's better to use Programmer's Notepad and use the "make" utilitity. Good luck and revert with a intelligent remark..... Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on May 13, 2009, 10:05:20 10:05 A LM3S1968 dev board is arrount 40Euro on farnell.
They support a large choice of Jtag tools. I didn't started yet any work on these processors. Title: Re: Hi-Tech PIC Compiler latest versions Post by: robban on May 13, 2009, 11:35:11 11:35 That's a reasonably price. Do You mean Luminary?
Don't forget that ARM has a steep learning curve, so don't give up at the first obstacle. You'll get a great satisfaction when all is hunky dory. An advantage with the startup code(Assembler) is that You can arrange RAM and ROM areas, and tell the compiler to use either 32- or 16-bit(Thumb state code) plus assigning pins, among others. I never use Proteus(nice IDE) but ExpressPCB. For this I'll probably will get a lot of beating.... Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on May 13, 2009, 06:37:03 18:37 Yes. Luminary Micro.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: ALLPIC on May 15, 2009, 06:51:04 06:51 Can some one help me!!!!!
simple code in ht-tech picc 9.60 pl6 #include <pic.h> #include <stdio.h> #include <stdlib.h> char str[10]; void main(void) { float a=1.1234; sprintf(str,"%0.1f",a); } gating error :( HI-TECH C PRO for the PIC10/12/16 MCU family candidate build 4070 V9.60PL6 Copyright (C) 1984-2009 HI-TECH SOFTWARE Serial number: HCPICP-36668 this licence will expire on Wed, 12 Dec 2029 Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\doprnt.c; 1217. fixup overflow storing 0x14F in 1 byte at 0x16BC (VAF.obj 171/0x1E) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\doprnt.c; 1217. fixup overflow storing 0x14E in 1 byte at 0x16BE (VAF.obj 171/0x20) Error [1268] VAF.obj; 188. fixup overflow storing 0x12D in 1 byte at 0x1828 (VAF.obj 188/0x24) Error [1268] VAF.obj; 188. fixup overflow storing 0x12C in 1 byte at 0x182A (VAF.obj 188/0x26) Error [1268] VAF.obj; 232. fixup overflow storing 0x11D in 1 byte at 0x1BBC (VAF.obj 232/0x1E) Error [1268] VAF.obj; 232. fixup overflow storing 0x11C in 1 byte at 0x1BBE (VAF.obj 232/0x20) Error [1268] VAF.obj; 265. fixup overflow storing 0x11D in 1 byte at 0x1E6C (VAF.obj 265/0x2) Error [1268] VAF.obj; 265. fixup overflow storing 0x11C in 1 byte at 0x1E6E (VAF.obj 265/0x4) Error [1268] VAF.obj; 265. fixup overflow storing 0x11D in 1 byte at 0x1E88 (VAF.obj 265/0x1E) Error [1268] VAF.obj; 265. fixup overflow storing 0x11C in 1 byte at 0x1E8A (VAF.obj 265/0x20) Error [1268] VAF.obj; 271. fixup overflow storing 0x121 in 1 byte at 0x1EF4 (VAF.obj 271/0x4) Error [1268] VAF.obj; 271. fixup overflow storing 0x120 in 1 byte at 0x1EF6 (VAF.obj 271/0x6) Error [1268] VAF.obj; 278. fixup overflow storing 0x121 in 1 byte at 0x1F8C (VAF.obj 278/0x1A) Error [1268] VAF.obj; 278. fixup overflow storing 0x120 in 1 byte at 0x1F8E (VAF.obj 278/0x1C) Error [1268] VAF.obj; 280. fixup overflow storing 0x121 in 1 byte at 0x1FAC (VAF.obj 280/0x4) Error [1268] VAF.obj; 280. fixup overflow storing 0x120 in 1 byte at 0x1FAE (VAF.obj 280/0x6) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\lib\doprnt.c; 434. fixup overflow storing 0x151 in 1 byte at 0x938 (VAF.obj 311/0x0) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\lib\doprnt.c; 434. fixup overflow storing 0x150 in 1 byte at 0x93A (VAF.obj 311/0x2) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\lib\doprnt.c; 437. fixup overflow storing 0x151 in 1 byte at 0x9B2 (VAF.obj 316/0x1C) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\lib\doprnt.c; 437. fixup overflow storing 0x150 in 1 byte at 0x9B4 (VAF.obj 316/0x1E) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x14F in 1 byte at 0xE00 (VAF.rlf 3609/0x0) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x14E in 1 byte at 0xE00 (VAF.rlf 3613/0x0) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x12D in 1 byte at 0xE00 (VAF.rlf 4244/0x0) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x12C in 1 byte at 0xE00 (VAF.rlf 4248/0x0) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x11D in 1 byte at 0xE00 (VAF.rlf 5886/0x0) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x11C in 1 byte at 0xE00 (VAF.rlf 5890/0x0) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x11D in 1 byte at 0xE00 (VAF.rlf 7074/0x0) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x11C in 1 byte at 0xE00 (VAF.rlf 7078/0x0) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x11D in 1 byte at 0xE00 (VAF.rlf 7120/0x0) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x11C in 1 byte at 0xE00 (VAF.rlf 7124/0x0) Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x121 in 1 byte at 0xE00 (VAF.rlf 7324/0x0) Advisory[1] too many errors (31) what can be a problem same thing happn in demo mode also even I downloaded new picc 9.65 the same errors I am gatting. As I can't ask hitech regarding this :( can some one help me Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on May 15, 2009, 01:11:42 13:11 yes u can ..join users forum at hitech and tell em :)
bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: sam_des on May 15, 2009, 07:17:35 19:17 Hi,
@ ALLPIC, I don't remember correctly, but I think hitech requires special library for handling 'floating point prints' ?? May be a linker switch ?? I'll check it out asap. regards, sam_des Just remembered - Default standard printf() doesn't support floating point numbers. Use -LF option or whatever newer version requires at command line for linker. Or may be compiler is unable to allocate enough ram for printf() due to large number of vars in your program. If that's the case, you better avoid using standard 'doprnt() function(which is quite ram/rom hungry & bloated to include eveything) & write your own or do domething like this-- Code: putfloat(float f) Title: Re: Hi-Tech PIC Compiler latest versions Post by: preatorian on May 17, 2009, 06:01:25 18:01 Hi all,
reporting new version of Hi-tech C Pro for PIC10/12/16 v9.65 (HCPIC) http://www.htsoft.com/downloads/getfile.php?sourcepage=demos&productid=2192 regards Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on May 19, 2009, 05:30:12 17:30 preatorian do u mean the 23 march release? ..if so i already done it and added it to my big post on 24th march :)
check here (http://www.sonsivri.com/forum/index.php?topic=935.msg69555#msg69555) bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on May 22, 2009, 04:43:49 16:43 My storage link has been updated with a new release of hitech picc pro
HI-TECH C PRO for the PIC10/12/16 MCU family candidate build 4612 V9.65PL1 Uni patcher has also had new reg file added for the new version also to use new version without using this new reg file just open old regfile and change pl0 >pl1 then run patcher and itll be fully regged again:0 bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: preatorian on May 27, 2009, 11:05:53 11:05 Hi bunion,
I mean the 25th march release, I guess this is it. These are the release notes about it: http://www.htsoft.com/microchip/products/compilers/documentation/hcpicp-readme.pdf Best regards Title: Patch Level Update - HI-TECH C® for PIC18 MCUs v9.63PL3 Post by: edalab on June 14, 2009, 07:44:21 07:44 Hi bunion,
Patch Level Update - HI-TECH C® for PIC18 MCUs v9.63PL3 2009-06-08 A patch level update of the HI-TECH C PRO for PIC18 MCUs (v9.63PL3) has been released. The patch level update adds support for new PIC18 devices and fixes known issues and bugfixes reported since the last release. crack is invalid. please update,thanks! Best regards Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on June 14, 2009, 10:15:05 10:15 The prvious version is not good for you?
What limitations are you bumpving into? I'm using 9.63 and I have no problems. What are the fixes in the current version? Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on June 14, 2009, 09:18:19 21:18 Ok done ..
New patcher for HI-TECH PIC18_PRO_963PL3 added to storage storage stops me upping anyrthing over 10mb now so the actuall PIC18_PRO_963PL3 installer has'nt been added ok bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: edalab on June 15, 2009, 12:34:05 12:34 thanks!
Title: Re: Hi-Tech PIC Compiler latest versions Post by: cddx on June 17, 2009, 04:10:10 16:10 Where can I get HI-TECH C® for PIC18 MCUs v9.63PL3 ?
Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on June 17, 2009, 10:46:06 22:46 Theres an attachment 50 posts up that has the download details in it BUT
to make things easier ill attach it here :) Details strictly private or be banned! ah do you mean the actual hitech installer? http://www.htsoft.com/downloads/getfile.php?sourcepage=demos&productid=2362 youll need to register for downloads though bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: vanko on June 29, 2009, 05:44:25 05:44 Some of files are pwd protected.
Any help? Thanks in advance Regards Title: Re: Hi-Tech PIC Compiler latest versions Post by: Memoly on July 06, 2009, 12:01:15 00:01 Some of files are pwd protected. Any help? Thanks in advance Regards yes need password plz for HCPIC-std-9.60PL3. Title: Re: Hi-Tech PIC Compiler latest versions Post by: bbarney on July 06, 2009, 02:01:10 02:01 Why do we bother with sticky's when people can't be bothered to even read one full page from the top where the password is TWICE
Title: Re: Hi-Tech PIC Compiler latest versions Post by: robban on July 07, 2009, 07:34:48 19:34 For all of us used to put our programs in the "Program"-folder instead of "Program Files"-folder, don't forget to open these regfiles with Yr. favourite texteditor and correct it. Btw. the HT-SOFT ARM is actually there, but so far runs only under HI-TIDE... ;)
Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on July 14, 2009, 05:41:18 17:41 Btw. the HT-SOFT ARM is actually there, but so far runs only under HI-TIDE...
is that a restriction ? if so i can maybe remove it bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on August 30, 2009, 10:06:26 22:06 HI-TECH for dsPIC-PIC24 v9.60.3.Build 4951
..added to storage :) bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on October 14, 2009, 06:50:22 06:50 HiTech MSP430
..added to storage :) bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on October 14, 2009, 08:55:12 20:55 To bad that since HT have been taken over by Microchip they don't develop anymore compilersfor other MCU vendors.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: manish12 on October 18, 2009, 08:40:01 08:40 www.sonsivri.com
bunions_carboot need more pw for int rar. Title: Re: Hi-Tech PIC Compiler latest versions Post by: 0sLtEd43bZ5z on October 18, 2009, 09:07:04 09:07 don't be lazy. check previous posts - specially bunions.
also check text files in dropboks. Title: Re: Hi-Tech PIC Compiler latest versions Post by: Memoly on October 19, 2009, 07:14:26 07:14 Ok done .. New patcher for HI-TECH PIC18_PRO_963PL3 added to storage storage stops me upping anyrthing over 10mb now so the actuall PIC18_PRO_963PL3 installer has'nt been added ok bunion Hi bunion, Thank you for your works. I'm using Win7 Ultimate 64 bit. I installed MPLAB 8.40 first. And then installed PIC18_PRO_963PL3 by using your instructions (serial number indicated and off-line activation). Before reg file, I changed installation folder in it and applied it. I patched 2 exe files exactly like you mentioned with your patcher (33 bytes patched succesffuly for both). But the compiler still says it is in lite mode. I uninstalled hitech picc18 pro, delete reg keys and re-install, but the result doesn't change. For the third time, I installed it in demo mode (45 days), and applied your patch. Now it says the compiler is in demo mode but will expire on 2029. Is it normal? Thanks. Title: Re: Hi-Tech PIC Compiler latest versions Post by: RedAlert on October 23, 2009, 02:32:34 14:32 New Major version(v9.70) is out for PIC10/12/16 - http://www.htsoft.com/news/#news491
if someone has time to handle a fix for it... Download link: http://www.megaupload.com/?d=3KVA9X4O Thanks in advance. Title: Re: Hi-Tech PIC Compiler latest versions Post by: alien on October 23, 2009, 04:50:08 16:50 Just compiled one old small project(MCU = 16F676 with 1 kw flash) using above mentioned piccPRO9.70(installed and activated 45 days PRO mode)...errors croped up saying lack of flash by some xx bytes....but this just compiles ok(total flash used = 946 words) using picc standard 9.60pl3....seems it is`nt upto the mark as claimed by htsoft.....I dont know what happend to HTSOFT peoples...old staff might have left the organisation...once they used to be best compiler developers(clever too).
Title: Re: Hi-Tech PIC Compiler latest versions Post by: vovchik02 on October 26, 2009, 06:33:28 06:33 I don't now why, but PICC PRO make bigger code - working project in STD ~500 word of flash and PRO ~900 word. All optimization ON. :(
Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on October 26, 2009, 07:10:48 19:10 OK downloaded 9.7 andwill make it fully registered WITHOUT needing any licence or reg files..gimmee a day asi got pulsonix to do too
bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: ALLPIC on October 27, 2009, 05:22:19 05:22 Great ...
Waiting for that. Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on November 07, 2009, 10:51:05 22:51 Manuel said he tested it and told me no point in cracking it as its too buggy and compiles code strangely
i cracked it and asked him to compile using 45 day eval to compare results with my fixed version and they were same but crappy compared to there single versions 9.65's bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: alien on November 08, 2009, 10:37:13 10:37 yes bunion this particular version is piece of crap....as I said earlier...htsoft says that this version uses a totally new generation of there so called "omniscent code genrator"but it seems instead of having done some huge improvements they have messed up the whole thing.....I think they overengineered it ;D
Title: Re: Hi-Tech PIC Compiler latest versions Post by: DrSurfer on November 12, 2009, 02:22:12 14:22 hi all.... as far as I know "omniscient code generation" is not a "just added" feature but it's available from some time... for sure it's here from 9.60 release, if not earlier...
I found that 9.65PL1 broke my code, so I am stuck using 9.65PL0. Nevertheless, I would like to give a try to 9.70 ... Title: Re: Hi-Tech PIC Compiler latest versions Post by: mitsos on November 12, 2009, 08:42:52 20:42 hi
bunion are you release the patch for the last version (9.70)? regards mitsos Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on November 12, 2009, 09:02:59 21:02 I use PICC 9.60PL5 and and PICC18 9.63PL3 and I have no problems. Do somebody knows some issues with these versions and needs to update to the "latest" one?
Thank you! Title: Re: Hi-Tech PIC Compiler latest versions Post by: GeneralMadDog on November 15, 2009, 01:05:26 13:05 Hi bunion, Thank you for your works. I'm using Win7 Ultimate 64 bit. I installed MPLAB 8.40 first. And then installed PIC18_PRO_963PL3 by using your instructions (serial number indicated and off-line activation). Before reg file, I changed installation folder in it and applied it. I patched 2 exe files exactly like you mentioned with your patcher (33 bytes patched succesffuly for both). But the compiler still says it is in lite mode. I uninstalled hitech picc18 pro, delete reg keys and re-install, but the result doesn't change. For the third time, I installed it in demo mode (45 days), and applied your patch. Now it says the compiler is in demo mode but will expire on 2029. Is it normal? Thanks. Hi! I have the same effect on Win7 x64: If I install the full version with serial #, I get the messages (after patching): dsPIC 9.60PL3: compiler is not activated PIC pro 9.65PL1 release candidate: lite mode If I install both compilers in demo-mode (after patching): dsPIC 9.60PL3: no special message PIC pro 9.65PL1 release candidate: this licence will expire on Wed, 12 Dec 2029 Regards, MadDog Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on November 16, 2009, 12:08:32 00:08 yes maddog normal...heres the story
up until latest dspic 96pl3 id been using a vaild 45 day license key to crack all the compilers...what the crack allowed was for that valid key generated for my pc to run on ANY other pc and also to extend the period to 2029 ...i did not think choosing to install as full or demo made much diff so told u all to install as full ..maybe demo is best bet for win 7 now.. ALSO im noticing very slight changes to there code which was messing with universal patcher so when i done the new patch for latest dspic i used a completely diff crack method which bypasses needing to have a licence key altogether...only thing needed in regfile is a serial=HCDSPIC-53118 so it shows something in main window..the ACTIVATION key is completely phoney using any numbers whatsoever and the reason why u dont get any expiry data etc is because i now completely bypass date checking routine too...it compiles ok and runs normally so from mow on thats the way the others will be done also...and no uni patcher from now on itll be individual crack versions :) about picc 9.70...attach a test peice of code that you can successfully compile using the 45 day evaluation along with the results you get....attach the .asm file too...using mplab...if ur happy with those results compared to older picc version then ill create crack for it BUT i already cracked it and code looked to long and not as good as last picc version but manuel gets same results using legit version so he said 9.70 is a waste of time to release crack for till they fix it bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: DrSurfer on November 27, 2009, 05:17:36 17:17 Dear friends, this thread on htsoft forum should clarify about 9.70 pro "performance issues"...
hxxp://forum.htsoft.com/all/showflat.php/Cat/0/Number/132662/an//page//vc/1 BTW my problem with 9.65PL1 is this error message: Quote HI-TECH C PRO for the PIC10/12/16 MCU family V9.65PL1 Copyright (C) 1984-2009 HI-TECH SOFTWARE Serial number: HCPICP-36668 this licence will expire on Wed, 12 Dec 2029 Error [468] DisplayLCD.obj; 170. undefined symbol "_sprintf" in FNCALL record if I use the 9.65PL0 compiler compilation is successful. The sprintf call occurs in a source different from the one that contains main() function. The error disappears if I put a fake call to sprintf [for example sprintf(buf,"");] in the body of the main function. I hate this kind of workarounds. DrS. Title: Re: Hi-Tech PIC Compiler latest versions Post by: robban on November 28, 2009, 09:30:00 09:30 If You think expiry date 2029 is too late, You can dismiss further inquiries abt. HI-TECH. Myself, it's quite enough...
Title: Re: Hi-Tech PIC Compiler latest versions Post by: pirvcb on December 06, 2009, 06:00:54 18:00 Maybe, part of attention on 9.70 hi-tech release, is motivated by flowcode compatibility. In 4.2 version of flowcode, matrixmultimedia declared its compatibility with hi-tech C 9.70 and explain how to use this compiler from inside flowcode 4.2 application. So, i guess, this would be a motivation for someone to wish 9.70 cracked. Just a supposition....
http://www.matrixmultimedia.com/mmforums/viewtopic.php?f=26&t=6812 Title: Re: Hi-Tech PIC Compiler latest versions Post by: DrSurfer on December 07, 2009, 07:18:15 07:18 The only sure thing is that nobody wants updated cracks just to defeat the 2029 "limit".
Is it possible to install "side by side" different versions of hitech compiler? In crack's infos is always stated that every previous version must be removed before install another one. I didn't try it, and I wonder if this is only a bit... paranoid or it's a real issue. Having different versions on the same machine could help to choose and understand if many "improvements" are for real or are only marketing claims. Title: Re: Hi-Tech PIC Compiler latest versions Post by: oldvan on December 07, 2009, 07:51:12 07:51 Is it possible to install "side by side" different versions of hitech compiler? ... Having different versions on the same machine could help to choose and understand if many "improvements" are for real or are only marketing claims. If you can't do it on one computer, you could use VMWare and clone a virtual machine, then install the versions of the cmmpiler you wish to compare on these identical virtual machines. I'm sure others here would love to hear what you learn! Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 10, 2009, 01:53:33 01:53 Thats cool if it can be used with flowcode
If someone attaches a test bit of code i can run in 9.70 and also the results youll get when its compled correctly then ill create new crack with no expiry bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: DrSurfer on December 10, 2009, 09:01:02 09:01 I don't understand your request: a different compiler could generate totally different binary code given the same source code.
I could send you a complete MPLAB/hitech project, that compiles with 9.65 and works (as far as my own bugs allows! :)), but without the actual board what kind of testing could you perform? Anyway if you think that my code could be useful, I will send you my project, complete of any generated output. I'm afraid that it's much more than a "test bit of code"... 8) DrS Title: Re: Hi-Tech PIC Compiler latest versions Post by: ALLPIC on December 13, 2009, 05:27:30 17:27 bunion
Please find source code and hex file all attached for PICC9.65pl1 and picc9.70 PICC9.70 45 days demo shows 24% picc9.65pl1 shows 19% if some one can see output and suggess the reson? Posted on: December 13, 2009, 06:26:02 18:26 - Automerged sorry Both are working ok no problems on hardware Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 13, 2009, 06:26:43 18:26 thats y i never released crack b4 as 9.70 code is bigger than 9.65's...but ill go ahead and test allpics code in crack ..if it gives same then ill release
bunion im getting 18.9% taking dog walk then ill up for testing Title: Re: Hi-Tech PIC Compiler latest versions Post by: DrSurfer on December 13, 2009, 07:00:39 19:00 I'm very anxious to read about your test: the 9.70 when registered as "time limited demo" (and in Lite mode) is known to generate bigger code. :(
It's not known if this is a wanted behavior. ??? I have the suspect that this is a way to avoid the cracking by extending the demo period beyond the 45 days, because the time limited demo cracked with this tecnique will generate the same "inflated" code of the Lite version. A little unfair for those that want genuinely evaluate the compiler, IMHO. 8) Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 13, 2009, 08:29:35 20:29 allpic maybe why your results are bigger is because your startup options differ from mines i think
yours ;Licensed for evaluation purposes only. ;This licence will expire on Sun, 31 Jan 2010 ; Auto-generated runtime startup code for final link stage. ; ; Compiler options: ; ; -oSteperMotorDriver.cof -mSteperMotorDriver.map --summary=default \ ; --output=default delay.p1 main.p1 --chip=16F886 -P --runtime=default \ ; --opt=default -D__DEBUG=1 -g --asmlist \ ; --errformat=Error [%n] %f; %l.%c %s --msgformat=Advisory[%n] %s \ ; --warnformat=Warning [%n] %f; %l.%c %s ; mines ;Serial no. HCPICP-35553 ; Auto-generated runtime startup code for final link stage. ; ; Compiler options: ; ; -otry7.cof -mtry7.map --summary=default --output=default delay.p1 \ ; main.p1 --chip=16F886 -P --runtime=default \ ; --opt=default,+asm,-debug,-speed,+space,9 --warn=0 --addrqual=ignore \ ; -g --asmlist --errformat=Error [%n] %f; %l.%c %s \ ; --msgformat=Advisory[%n] %s --warnformat=Warning [%n] %f; %l.%c %s ; yours not showing "space,9" amongst others...9 is highest optimisation codewise bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: ALLPIC on December 14, 2009, 03:01:26 03:01 too good I made clean project rather than just changing compiler driver and now it is showing 18.9% :))
Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 14, 2009, 04:14:54 04:14 ok
HI-TECH PICC PRO 9.70 added to storage for testing puposes...no expiry report back if its working corrrectly bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: Manuel on December 14, 2009, 10:01:30 10:01 Bunion, Reg Missing?
M! Title: Re: Hi-Tech PIC Compiler latest versions Post by: raham on December 15, 2009, 02:05:47 02:05 working in Lite mode,Missing Reg file.
Raham Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 15, 2009, 03:11:06 03:11 yep sorry about that forgot to add regfile...sorry:(..ok added :)
bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 16, 2009, 05:25:11 17:25 noones come back and moaned about it not working so im GUESSing its working ok?
Remember folks i added it as a tester meaning u gotta come back and report if its working or not! bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: Manuel on December 16, 2009, 06:57:17 18:57 it's ok,
but generated code as advanced....is not so optimized....in both code and ram. (this is not your fault) take care Bunion. Manuel Title: Re: Hi-Tech PIC Compiler latest versions Post by: robban on December 17, 2009, 03:45:49 03:45 noones come back and moaned about it not working so im GUESSing its working ok? Remember folks i added it as a tester meaning u gotta come back and report if its working or not! bunion I must say, bunion, that You have put in a lot of effort regarding C-compilers and other stuff. I take my imaginary hat off for You, and I think it goes for the rest of this community. Keep on truckin' Regards robban Title: Re: Hi-Tech PIC Compiler latest versions Post by: DrSurfer on December 17, 2009, 01:03:01 13:03 here the result of my first test, very same sources, compiler and link settings.
compiler 9.65PL1: Program: 1225 words (59.8%) Data: 77 words (60.2%) compiler 9.70PL0: Program: 1179 words (57.6%) ;D Data: 76 words (59.4%) My program works as expected and, as an additional bonus, with 9.70 I can remove my workaround for "(s)printf-in-files-different-from-the-one-with-main()" bug 8) DrS Title: Re: Hi-Tech PIC Compiler latest versions Post by: Mr. Spock on December 17, 2009, 08:03:29 20:03 Hi Bunion
Do you have the patch for the latest version of PIC32 compiler ? REgards Title: Re: Hi-Tech PIC Compiler latest versions Post by: ALLPIC on December 20, 2009, 04:06:42 16:06 Things also working for me now. Good thanks very thanks
Title: Re: Hi-Tech PIC Compiler latest versions Post by: ppa88 on December 28, 2009, 05:15:47 05:15 I apologize with all my heart for having got carried away in an effort to help someone. I promise to be extra careful in future.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: robban on December 29, 2009, 01:09:48 01:09 I don't know where You reside, maybe on desolation row, come on, let's have a gas,
Cheers from robban... ;D Title: Re: Hi-Tech PIC Compiler latest versions Post by: Wizpic on December 29, 2009, 08:41:04 08:41 I apologize with all my heart for having got carried away in an effort to help someone. I promise to be extra careful in future. You don't need to apologize for helping someone ;D I don't know where You reside, maybe on desolation row, come on, Cheers from robban... ;D Did you miss reading the Rule about new year ? ALOS LET THIS BE A WARNING TO EVERYONE WE DONOT LIKE WARS HERE SO DON'T START ONE Title: Re: Hi-Tech PIC Compiler latest versions Post by: picaboo on December 29, 2009, 12:19:55 12:19 Guys,
I am having hard luck installing PICC. First, I could not use v9.65 because my Symantec is saying that universal patcher has trojan. Now I tried to install v9.70. I am not seeing the application in the menu after installation. When I start the installation, the flash screen does not say it is PRO version. I hope it is fine. (http://giftnetindia.com/screen1.gif) Step 1 in Readme1st.txt says: INSTALL OFFLINE as PRO USING XXXXX. The selection screen says PRO/STD. So I do not know how to choose only PRO mode. I did this (I masked the serial number in the screenshot. I used the number from Readme1st.txt), (http://giftnetindia.com/screen2.gif) Hope the above is correct. In the next to next screen, the default installation path is shown as, (http://giftnetindia.com/screen3.gif) Note that the path does not contain "PRO" or "STD". It simply contains "PICC/9.70" In the next screen I selected the "Add to enc path" box. The files are copied by the installer. Then the last screen comes, where "Email Now" button is shown. I click on the "Finish" button. So far I have not applied the patch. This is clean "offline" installation. When I try to start the application, I do not see the application in the menu. (http://giftnetindia.com/screen4.gif) I thought that since the application has not been activated, it is not showing up in the start menu. Then I ran the patcher and chose the files (mentioned in the readme1st.txt) using the browse button. It reported success (23 bytes written for each file). Then I double clicked on the file mentioned in readme1st.txt. This also returned success. But I still do not see the application in the start menu. (http://giftnetindia.com/screen5.gif) Now if I click on the "Activate or trial PRO mode", the following screen appears. (http://giftnetindia.com/screen6.gif) Note that the serial number is different than what I entered. This serial number appears in registry. What did I do wrong? Title: Re: Hi-Tech PIC Compiler latest versions Post by: pickit2 on December 29, 2009, 01:26:49 13:26 Yes your doing something wrong ;D
try selecting right version to install Title: Re: Hi-Tech PIC Compiler latest versions Post by: alien on December 29, 2009, 03:10:09 15:10 Dear picaboo,
Yes its obvious that you will not see any application listing/icon in menu becuse this is a command line compiler...you should first learn how to use command line tools or use some Integrated Development Enviornment(IDE) like Mplab IDE from microchip or Hitechs own HI-TIDE IDE...these IDEs will act as graphical interface for your hitech c compiler...as u have already mentioned that patch returned success message then your compiler is ready to use and its fully functional now,hope this all helps. Title: Re: Hi-Tech PIC Compiler latest versions Post by: pirvcb on December 29, 2009, 03:31:54 15:31 Dear picaboo, Yes its obvious that you will not see any application listing/icon in menu becuse this is a command line compiler...you should first learn how to use command line tools or use some Integrated Development Enviornment(IDE) like Mplab IDE from microchip or Hitechs own HI-TIDE IDE...these IDEs will act as graphical interface for your hitech c compiler...as u have already mentioned that patch returned success message then your compiler is ready to use and its fully functional now,hope this all helps. Also you can set up Flowcode to use HI-TECH compiler instead BOOST C compiler bundled with it. Title: Re: Hi-Tech PIC Compiler latest versions Post by: picaboo on December 30, 2009, 01:19:25 01:19 Pickit,
that was exactly my point. Your screenshot show the word "PRO" for v9.60. But my screenshot does not show that, though bunion's .rar file is named PICC PRO v9.70. Posted on: December 30, 2009, 02:14:24 02:14 - Automerged Alien, Thanks a lot. I am used to MicroElectronika which has its own IDE. I was expecting PICC to be same. After reading your post I did some more reading online and now I think i understand how to do it with MPLAB. I will try this today. Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on December 31, 2009, 03:22:47 03:22 See attachment for new storage details
...remember its private!!! bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: ALLPIC on December 31, 2009, 04:31:47 04:31 picaboo
I think you are useing Hi-tech first time. You will never see any application after installing Hi tech compiler. Hi-tech compiler is always linked with MPLAB. If you not like MPLAB then install HTIDE. regards Title: Re: Hi-Tech PIC Compiler latest versions Post by: sittichoke on January 01, 2010, 02:58:00 02:58 bunion
could you tell about password on another file?. thanks you sittichoke Title: Re: Hi-Tech PIC Compiler latest versions Post by: kiashee on January 02, 2010, 04:18:36 04:18 bunion could you tell about password on another file?. thanks you sittichoke Hi... were you able to look the inside of it? or my guess, you can't download it, right? Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 02, 2010, 09:35:19 21:35 Theres no passes on any of the latest stuff so u must be using an older pacl like hitech enterprise pack..if so the passwords are all covered in this topic so take some time and look thru posts or use common sense and guess its either sonsivri , Sonsivri , Sonsivri.com or bunion
bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: arslanweb on January 17, 2010, 08:42:13 08:42 See attachment for new storage details ...remember its private!!! bunion What is the right password of the "HCPIC18-std-9.51PL2.rar" files. Regarts Title: Re: Hi-Tech PIC Compiler latest versions Post by: waicon on January 17, 2010, 09:40:27 09:40 refer to: reply from bunion at page 11, Reply #274
« Reply #274 on: January 03, 2010, 06:35:19 06:35 » Title: Re: Hi-Tech PIC Compiler latest versions Post by: manofthe_day on January 19, 2010, 07:54:17 19:54 hello every one please somebody pls post the universal patcher for the latest hitech pic c compiler only please and please because i cant get down that huge 17*mb of file .
somebody pls help. Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 20, 2010, 02:42:26 02:42 Dont make uni patcher now
Heres patcher for latest picc pro 9.70 HTPICP 970.rar (http://www.4shared.com/file/201804342/b7718c69/HTPICP_970.html) bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: sukumar on January 21, 2010, 07:05:39 07:05 Hi all,
Hitech Pro v9.70 with patch canbe downloaded here. http://rapidshare.com/files/338644120/HI-TECH_PICC_PRO_9.70.rar Regards, M.Sukumar Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on January 21, 2010, 08:46:10 20:46 Heres patcher for latest picc18 pro 0.63 pl3
HTPICP18 963PL3.rar (http://www.4shared.com/file/203398929/c1f04b92/HTPICP18_963PL3.html) IF NOT latest le me know bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: mitsos on January 21, 2010, 10:08:39 22:08 hi
recently I check the optimisation between v8.05PL2 (full version),v9.65PL1 and last v9.70PL0. I do that with a keeloq project (based on an745) and I see these: version size(code words) optimisation level 8.05PL2 2084 no 8.05PL2 1321 max 9.65PL1(pro) 1816 min 9.65PL1(pro) 1268 max 9.70PL0(pro) 1779 min 9.70PL0(pro) 1295 max 9.65PL1(lite) 2304 no 9.70PL0(lite) 2241 no it is obvious that engineers of hitech thinking like a fox... in the lite versions the optimiser operates in the opposite way:deoptimiser...! and by this way the optimiser in the pro version seems to optimise the size of code more than it trully do so. regards mitsos Title: Re: Hi-Tech PIC Compiler latest versions Post by: oldvan on January 21, 2010, 10:55:10 22:55 it is obvious that engineers of hitech thinking like a fox... in the lite versions the optimiser operates in the opposite way:deoptimiser...! and by this way the optimiser in the pro version seems to optimise the size of code more than it trully do so. Did you have a peek at the .LST files and find their excess baggage? I'd be interested to know the real difference. Is it possible the new version has errata workarounds not found in the earlier version, and creates somewhat bulkier code as a result but will thus make your device more reliable? An example from the 18F452: (http://oldvan.com/misc/compiled.gif) We are only using 220 bytes or 11% more ROM with the LITE version they give away for free. The new compiler still does 2% better on MAX setting, which is a nerdy selling point. Title: Re: Hi-Tech PIC Compiler latest versions Post by: chyelim on January 24, 2010, 04:26:05 16:26 Mirror link for PICC18 PRO 9.63 PL3 + Patch Megaupload
http://www.megaupload.com/?d=JTWZ938T Title: Re: Hi-Tech PIC Compiler latest versions Post by: devfirat on February 03, 2010, 12:13:36 00:13 Edit - New all-in-one with updates as of 01 February 2009: http://rapidshare.com/files/192313038/htbun3.rar.html http://www.zshare.net/download/549421754f5122da/ http://www.rapidspread.com/file.jsp?id=g1arblnvsb http://www.megaupload.com/?d=UYZGU3ND http://www.filefactory.com/file/a04bh27/n/htbun3_rar pass = www.sonsivri.com [ Note - see text file inside archive for internal passwords ] All-in-one is approx. 172MB - Let me know if it needs to be split. I have win7 64 bit os. I installed my computer those programs and crack it but when i did project and compiled it it said "hi-tech is lite". Do you know that problem and how can i solve this? I have 4gb ram and i can't go back 32bit because of this version of win hav 3.25gb ram max. How can i solve this, please help me? Thanks for everyone... Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on February 04, 2010, 12:20:20 00:20 get latest versions as the packs in sticky are old...see my attachment above or better still latest picc + picc18 have been linked by members few posts above :)
bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on February 04, 2010, 07:38:59 19:38 Links in sticky (top of page) updated. Old info in sticky was:
Quote OLD STICKY INFO: Edit - New all-in-one with updates as of 01 February 2009: http://rapidshare.com/files/192313038/htbun3.rar.html http://www.zshare.net/download/549421754f5122da/ http://www.rapidspread.com/file.jsp?id=g1arblnvsb http://www.megaupload.com/?d=UYZGU3ND http://www.filefactory.com/file/a04bh27/n/htbun3_rar pass = www.sonsivri.com [ Note - see text file inside archive for internal passwords ] All-in-one is approx. 172MB - Let me know if it needs to be split. ************ Old Links Below **************** New all-in-one with updates as of 29 December 2008: http://www4.zippyshare.com/v/32921399/file.html http://rapidshare.com/files/178014139/htbun2.rar.html http://www.zshare.net/download/534556980fcf3425/ http://uploaded.to/?id=pl504v http://www.filefactory.com/file/a009245/n/htbun2_rar http://www.megaupload.com/?d=6U9AIXKL http://w19.easy-share.com/1903045775.html pass = www.sonsivri.com [ Note - pass for files inside the all-in-one is Sonsivri ] Post back if there are any problems. Thanks for all your hard work, Bunion. Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on February 04, 2010, 09:12:58 21:12 Nice one bro! :)
bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: juabba on February 10, 2010, 04:15:31 16:15 pls help
the internal pass.txt pass do not work for the extract file of: HCPICP-pro-9.60PL5.rar or with HI-TECH Enterprise Edition.rar will appreciate information thanks juan Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on February 11, 2010, 12:54:54 12:54 pls help the internal pass.txt pass do not work for the extract file of: HCPICP-pro-9.60PL5.rar or with HI-TECH Enterprise Edition.rar will appreciate information thanks juan Sonsivri works for me. Title: Re: Hi-Tech PIC Compiler latest versions Post by: juabba on February 12, 2010, 12:44:30 00:44 thanks a lot 50caliber 8) 8) 8) 8)
it works An aditional basic question pls I want to install hi-tec C pro for c-18 family + c_wiz . Wonder which of several installation packages into the "htbun3" download should be used thanks in advance juan Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on February 12, 2010, 04:28:38 04:28 Heres patcher for latest picc18 pro 0.63 pl3 HTPICP18 963PL3.rar (http://www.4shared.com/file/203398929/c1f04b92/HTPICP18_963PL3.html) IF NOT latest le me know bunion Mirror link for PICC18 PRO 9.63 PL3 + Patch Megaupload http://www.megaupload.com/?d=JTWZ938T Why not just use the single of 18 pro latest above bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: DrSurfer on February 18, 2010, 04:37:57 16:37 Does someone as a cure to install 9.70 on an ancient Windows 2000 machine?
For the curious, the 9.70 installer uses some kernel.dll functions that are available from XP SP1 and above. I don't know if the same happens to the program(s) too, because I'm stuck at install. DrSurfer Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on February 18, 2010, 05:15:24 17:15 this is a guess but you could try placing an xp kernel32.dll inside your compilers folder and see if it runs...when installing have it alongside the insta.ller exe
bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: DrSurfer on February 22, 2010, 09:19:45 09:19 No, bunion, I tried this way but it doesn't work. Win2k kernel32.dll is already loaded and all references are taken from it.
Anyway I was succesful installing the compiler on a Vista machine and copying the directory and the related registry keys to the old PC, it was simpler than we thought. I tried a compilation and it seems to works fine. DrSurfer Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on February 25, 2010, 02:44:52 14:44 Hello bunion!!! Long time....
Straight to the point: I'm moving from STD to PRO 9.63PL3 (PIC18), and found a lot of problems... well, at least the compiler compiles and the proggie "seems" to work, but there's a lot of bugs... some of 'em are reported on release notes too (i.e. multidimensional array of pointers problem, the compiler can't calc the correct size!!! very annoying!!!!!) On the hi-tech forums, btw, there are some references on a "9.63 PL4" version, not counting a "9.64 release candidate": "The header file is broken for the 13K22/14K22 on 9.63PL3. You'll probably have to move to PL4. " "Downloaded 'HI-TECH C Compiler for PIC18 MCUs v9.64 Release Candidate' from PIC W.I.P. forum and this worked near perfectly." Weeeeell, any possibility to get 'em??? I'll hate to move back to STD 'cause the PRO saves me a lot of code rom, and I've almost filled up the PIC (18F4525). In the meantime I'll try to search if I can find 'em!!! Thanks!!! And God bless! UPDATE: Just tested the 9.64 Release Candidate... and, apart from the header files change (they're moving to Microchip C18 style, it requires some modifications in your source), a lot of bugs seems to be gone... and the code is smaller than ever! :) Bunion, you can grab it here: h**p://forum.htsoft.com/all/showflat.php/Cat/0/Number/147962/Main/138462/ ... it's a 45-day PRO demo... waiting for your cure ;D ;D ;D ;D ;D ANOTHER UPDATE: Well, it seems that they've fixed a lot of very annoying bugs from previous release (PICC-18 PRO 9.63 PL3), a lot of them were really NASTY and could crash all your programs (and drive you mad figuring out what's happened)... so I say: DON'T USE PICC-18 PRO 9.63 PL3 ... it's REALLY a MESS of DIRTY NASTY BUGS, and it will make your program UNSTABLE and NOT WORKING!!! >:( Instead, wait for the great cure from our great Mr. Bunion for PICC-18 PRO 9.64 Release Candidate ;D Title: Re: Hi-Tech PIC Compiler latest versions Post by: fasa on February 27, 2010, 06:28:30 18:28 If it is possible, could someone upload sticky files to rapidshare please?
Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on February 28, 2010, 05:34:26 17:34 If it is possible, could someone upload sticky files to rapidshare please? Multiupload mirrors files to multiple file sharing sites including rapidshare. Have you tried the rapidshare links? Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on March 04, 2010, 04:17:24 04:17 HCPIC18-pro-9.64.5502 Setup + Patcher (http://www.4shared.com/file/233910336/9f13a53f/HCPIC18-pro-9645502.html) 8)
HCPIC18-pro-9.64.5502 Patcher only (http://www.4shared.com/file/233910339/facb8ae/HCPIC18-pro-9645502_Patcher.html) Do usual testing bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on March 04, 2010, 07:02:04 07:02 ;D ;D ;D Our great bunion do it again ;D ;D ;D
Thank you very much pal, it works like a charm (as usual with your stuff!) Have a nice day! ;D ;D ;D Title: Re: Hi-Tech PIC Compiler latest versions Post by: GeneralMadDog on March 04, 2010, 07:03:02 19:03 Is the integration in HI-TIDE missing? There is no folder "hitide" in the installation directory. (Win 7 x64)
Regards MadDog Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on March 05, 2010, 01:56:38 01:56 Updated the sticky with links for:
HCPIC18-pro-9.64.5502.rar (17.97 MB) http://www.multiupload.com/RSCHS4X7PB HCPIC18-pro-9.64.5502_Patcher.rar (17.75 KB) http://www.multiupload.com/DX3XDBHNG0 Will monitor this thread and update as needed. Title: Re: Hi-Tech PIC Compiler latest versions Post by: mbandala on March 06, 2010, 03:42:29 03:42 Dear bunion
Is there a possibility of patching the Linux versions? I really don't like using Windows OS, besides the Linux community can really benefit from your contributions. Regards Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on March 06, 2010, 05:32:04 05:32 HI-TECH ENTERPRISE PLATINUM SUITE 8)
HI-TECH PICC PRO 9.70 HI-TECH PIC18-pro-9.64.5502 HI-TECH for dsPIC-PIC24 v9.60.3.4951 HCPIC32-pro-9.60PL1.3453_release_candidate HCPSOC-pro-9.61PL5.3451_release_candidate HI-TECH ARM-C v9.12 + HI-TIDE_2.12PL3 HI-TECH C for 8051 9.01 + HI-TIDE_2.13 HI-TECH MSP430-C HI-TECH for HOLTEK C HI-TECH Z80 7.80PL2 C Compiler HI-TECH for XA v7.73PL1 HI-TECH ENTERPRISE PLATINUM SUITE.rar (http://www.4shared.com/file/235125978/eeadf55f/HI-TECH_ENTERPRISE_PLATINUM_SU.html) Enjoy bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: RedAlert on March 06, 2010, 09:47:57 09:47 @bunion
for PIC32 latest official version is: HCPIC32-9.60PL2 Download link: http://www.megaupload.com/?d=CFNRVN8Y Not tested with crack yet Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on March 06, 2010, 10:32:25 22:32 Dear bunion Is there a possibility of patching the Linux versions? I really don't like using Windows OS, besides the Linux community can really benefit from your contributions. Regards mbandala id like to but my hdd is damaged at mo so untill i can get a new drive and install a partition with linux on it im just hobbling along at mo ...sorry bro :( bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: sphinx on March 06, 2010, 11:17:07 23:17 i can allways share a linux virtual pc for you just install ms vpc 2007 and away you go :)
/mike Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on March 09, 2010, 12:20:28 00:20 HI-TECH PIC32-PRO-9.60 PL2.rar (http://www.4shared.com/file/237157489/995c4fe7/HI-TECH_PIC32-PRO-960_PL2.html) 8)
HI-TECH PIC32-PRO-9.60 PL2 Patcher.rar (http://www.4shared.com/file/237157487/7ee462e0/HI-TECH_PIC32-PRO-960_PL2_Patc.html) sphinx upload the virtual linux ill give it a go ..cheers 50Caliber deserves a bit more thanks for continously updating the sticky for you lot! bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: sphinx on March 10, 2010, 02:31:47 02:31 sure bunion no problems will sort out a linux vpc for u, just tell me where to upload it since RS sucks with 10 downloads. and what kind of linux/debian you want i use just console mode for myself if u want X(windows) i can add that to it. just give me the message on what you want i sort it for you no worries man, its the least i could do for you u do lots of nice work for us
regards mike Title: Re: Hi-Tech PIC Compiler latest versions Post by: j0k3r on March 10, 2010, 09:21:10 09:21 HI-TECH ENTERPRISE PLATINUM SUITE 8) HI-TECH PICC PRO 9.70 HI-TECH PIC18-pro-9.64.5502 HI-TECH for dsPIC-PIC24 v9.60.3.4951 HCPIC32-pro-9.60PL1.3453_release_candidate HCPSOC-pro-9.61PL5.3451_release_candidate HI-TECH ARM-C v9.12 + HI-TIDE_2.12PL3 HI-TECH C for 8051 9.01 + HI-TIDE_2.13 HI-TECH MSP430-C HI-TECH for HOLTEK C HI-TECH Z80 7.80PL2 C Compiler HI-TECH for XA v7.73PL1 HI-TECH ENTERPRISE PLATINUM SUITE.rar (http://www.4shared.com/file/235125978/eeadf55f/HI-TECH_ENTERPRISE_PLATINUM_SU.html) Enjoy bunion Hi, the link is not working, "The file link that you requested is not valid. " could we get a mirror? Thank´s in advance Title: Re: Hi-Tech PIC Compiler latest versions Post by: 50caliber on March 10, 2010, 02:26:02 14:26 Hi, the link is not working, "The file link that you requested is not valid. " could we get a mirror? Thank´s in advance Check the sticky (top of page). :) Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on March 11, 2010, 07:31:52 07:31 Kappasm nice attempt bro but above keygen didnt work on my machine because i think you forgot the app id is diff for each machine and the hardcoded one you used is no good without a further patch to accept it which is easy enough but then that defeats the purpose of having it .Thats why i settled on patches as they work a treat and on any machine
In saying that though your keygen idea has got me wondering if i can make a proper keygen that doesnt involve any patching of the exe similar to the keygens i do for armadillo's elgamal.. sorry i updated suite to include picc 32 pro pl2 heres new link HI-TECH ENTERPRISE PLATINUM SUITE.rar (http://www.4shared.com/file/237157738/fe918e3/HI-TECH_ENTERPRISE_PLATINUM_SU.html) bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on March 14, 2010, 05:21:18 05:21 In saying that though your keygen idea has got me wondering if i can make a proper keygen that doesnt involve any patching of the exe similar to the keygens i do for armadillo's elgamal.. Well your first step will be to break 1024-bit RSA key used to encrypt the activation code :) Kappasm keygen working OK here! Title: Re: Hi-Tech PIC Compiler latest versions Post by: jrcy2 on March 19, 2010, 08:47:44 08:47 ALSO im noticing very slight changes to there code which was messing with universal patcher so when i done the new patch for latest dspic i used a completely diff crack method which bypasses needing to have a licence key altogether...only thing needed in regfile is a serial=HCDSPIC-53118 so it shows something in main window..the ACTIVATION key is completely phoney using any numbers whatsoever and the reason why u dont get any expiry data etc is because i now completely bypass date checking routine too...it compiles ok and runs normally so from mow on thats the way the others will be done also...and no uni patcher from now on itll be individual crack versions :) bunion I think I have found a bug in the patch for HI-TECH C DSPIC 9.60PL3 build 4951. Code: void something(void) The compiler throws the following error: \Temp\s4ok.: 289: (845) multiply defined symbol "S0" I can get the code to compile by putting the "something" and "nothing" functions in two separate files, OR, by commenting out some of the case statements; either 1 case statement early in the switch, or two case statements at the end. This problem does not occur when the compiler is installed in demo mode ??? Title: Re: Hi-Tech PIC Compiler latest versions Post by: ALLPIC on March 20, 2010, 05:40:55 05:40 HItech DSPIC toolkit is very bad so I am never going to use that. Use C30 or IAR
Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on March 22, 2010, 08:38:34 20:38 jrcy2 attach ur sample code ill take a look
bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: jrcy2 on March 23, 2010, 08:40:05 08:40 jrcy2 attach ur sample code ill take a look bunion Thanks Bunion. I've attached a complete project. I know the code in itself is meaningless but it represents the part of my code that's causing me trouble :-p I've tried the compiler on several different Windows XP machines and reinstalled it several times. As I said, I can only get it to compile if I install the compiler in evaluation mode. Cheers Title: Re: Hi-Tech PIC Compiler latest versions Post by: juabba on March 25, 2010, 09:10:09 21:10 hi bunion
program was compiling Ok with previous version then, I installed the HCPIC18-pro-9.64.5502 Setup + Patcher installation (plus patching ) went 100% all right after selecting the right "include search paths ", especially the C:\Program Files\HI-TECH Software\PICC-18\PRO\9.64\lib I have following error --------------------------------------------------------------------------------- Error [140] C:\Program Files\HI-TECH Software\PICC-18\PRO\9.64\lib\doprnt.c; 1532. can't open library file "plib-18f2x1x.lpp": No such file or directory ********** Build failed! ********** --------------------------------------------------------------------------------- I tried with different processors and same problem, can not find the proper "plib-18fZxZx.lpp", being Z the number corresponding to the different cpus tried Already verified if LIB directory has the necessary files, and they are there. The new version is correct on the windows PATH Any hint pls Thanks in advance juan Title: Re: Hi-Tech PIC Compiler latest versions Post by: jrcy2 on March 28, 2010, 07:34:24 19:34 Hi, New Ht-Soft PICC, PICC18, PICC32, dsPICC with no crack but full keygen with Public RSA key replaced. * HT-Soft PICC PRO 9.70 (http://hotfile.com/dl/35066307/610cb28/HT-Soft.PICC.PRO.9.70.by.Kappasm.rar.html) * HT-Soft PICC18 PRO 9.63 PL3 (http://hotfile.com/dl/35073762/8755311/HT-Soft.PICC18.PRO.9.63.PL3.by.Kappasm.rar.html) * HT-Soft PICC32 PRO 9.60 PL2 (http://hotfile.com/dl/35072058/75d4346/HT-Soft.PICC32.PRO.9.60.PL2.by.Kappasm.rar.html) * HT-Soft dsPICC STD 9.60 PL2 (http://hotfile.com/dl/35066462/34fda81/HT-Soft.dsPICC.STD.9.60.PL2.by.Kappasm.rar.html) Pass : www.sonsivri.com Kappasm. I've got HCDSPIC std 9.60PL4 build 5813 on Rapidshare. Kappasm's patch works with it too. Both PL3 and PL4 will build the code I was having problems with... http://rapidshare.com/files/369253434/HCDSPIC-std-9.60PL4.5813.exe Great! Title: Re: Hi-Tech PIC Compiler latest versions Post by: microtech on March 29, 2010, 06:47:35 06:47 Hi
Need Activation resposnse file for HI-TECH PICC PRO 9.70 to activate. any idea? Thanks Title: Re: Hi-Tech PIC Compiler latest versions Post by: ALLPIC on March 29, 2010, 11:38:32 11:38 hi kappasm
do you have crack for HT-Soft PICC18 PRO 9.63 PL4? if so then please share with us. So I can check the difference bettn bunion and your one Title: Re: Hi-Tech PIC Compiler latest versions Post by: jrcy2 on March 29, 2010, 09:50:13 21:50 Hi jrcy2, Htsoft released only dsPICC 9.60 PL3, how can you find dsPICC 9.60 PL4 ? Microchip (http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en542865) Kappasm. I got it from HI TECH support as I was having problems with PL3. I'm not sure when it's going to be officially released though... Have you tried it? Title: Re: Hi-Tech PIC Compiler latest versions Post by: microtech on March 30, 2010, 03:00:25 15:00 Hi Caliber,
HI-TECH PICC PRO 9.70.rar (5.53 MB) http://www.multiupload.com/AE7BMBILM7 is this realy working?, I have installed this using the patch, but it's show only lite mode. nor PRO. Please help if anybody try this software. thanks. Title: Re: Hi-Tech PIC Compiler latest versions Post by: pickit2 on March 30, 2010, 03:04:28 15:04 Hi Caliber, Some patches only patch the soft, they don't change the about splash screen, you can only say the soft is patched. To prove it you have to run it, and see no limits in function of the soft.HI-TECH PICC PRO 9.70.rar (5.53 MB) http://www.multiupload.com/AE7BMBILM7 is this realy working?, I have installed this using the patch, but it's show only lite mode. nor PRO. Please help if anybody try this software. thanks. Plus you don't say what version you used and or what patchs you tried. Title: Re: Hi-Tech PIC Compiler latest versions Post by: microtech on March 30, 2010, 03:33:25 15:33 Some patches only patch the soft, they don't change the about splash screen, you can only say the soft is patched. To prove it you have to run it, and see no limits in function of the soft. Plus you don't say what version you used and or what patchs you tried. Hi Pickit2, Thanks for your reply. I have installed this software. 1- HCPIC-pro-9.70 2-HI-TECH PICC PRO 9.70 Patcher as per the instructions below: To install & register INSTALL OFFLINE as PRO USING 36668 Use patch and patch picc.exe Use patch and patch cgpic.exe Double click picc.reg file Thats it! An Original bunions_carboot release! Title: Re: Hi-Tech PIC Compiler latest versions Post by: microtech on April 03, 2010, 02:10:09 14:10 Hi All,
Is there any working files for this software 1- HCPIC-pro-9.70 2-HI-TECH PICC PRO 9.70 Patcher Thanks.. Title: Re: Hi-Tech PIC Compiler latest versions Post by: greybeard on April 04, 2010, 11:08:48 11:08 hi
has anyone else used the z80 7.80pl2 compiler? I've tried running it and get an 'compiler not installed properly' error. have tried altering the creation date of the hidden files under the /lib directory but haven't been succesful. gb Title: Re: Hi-Tech PIC Compiler latest versions Post by: Sepiroth on April 06, 2010, 09:24:07 09:24 Hi all,
I've read that PICC18 Pro 9.63 PL3 has many bugs, which version of C18 Pro is better to use? Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on April 07, 2010, 01:03:49 01:03 Hi Caliber, HI-TECH PICC PRO 9.70.rar (5.53 MB) http://www.multiupload.com/AE7BMBILM7 is this realy working?, I have installed this using the patch, but it's show only lite mode. nor PRO. Please help if anybody try this software. thanks. hi has anyone else used the z80 7.80pl2 compiler? I've tried running it and get an 'compiler not installed properly' error. have tried altering the creation date of the hidden files under the /lib directory but haven't been succesful. gb will check both and report back bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: greybeard on April 07, 2010, 01:09:44 01:09 will check both and report back I've since been in contact with aplank and the original z80 package works ok. From what I can see the original package modifies the install program and you do an install rather than copying the installed packages. HTHbunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on April 09, 2010, 11:41:27 23:41 so ur sorted then?...or do u want the patched installer that installs without pass...you got that or will i get it 4 u?
bunion Title: Re: Hi-Tech PIC Compiler latest versions Post by: greybeard on April 09, 2010, 11:49:30 23:49 so ur sorted then?...or do u want the patched installer that installs without pass...you got that or will i get it 4 u? I've got what I need thanks.bunion However I believe that the package for the z80 compiler that has been released as part of the platinum package has issues and isn't working. Someone else trying to use it could have the same problem. I don't have a 100% understanding of how the installation checks for a correct install but I'd suspect that there is something either machine specific and/or time specific that hasn't been bypassed. Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on April 17, 2010, 04:04:05 16:04 HI-TECH Universal RSA Keygen
* HI-TECH Universal RSA Keygen generates real RSA signed activation data. * Replaces HI-TECH RSA public key with self-generated RSA key - different every time! * Generates permanent PRO key - no expiry date! * Tested with:
* New in version 2.2
* New in version 2.3
HI-TECH Universal RSA Keygen (v2.0) HI-TECH Universal RSA Keygen (v2.1) HI-TECH Universal RSA Keygen (v2.2) HI-TECH Universal RSA Keygen (v2.3) http://depositfiles.com/files/v6vup2azq (http://depositfiles.com/files/v6vup2azq) You can find 50caliber post here, the older sticky: http://www.sonsivri.com/forum/index.php?topic=935.msg69111#msg69111 Title: Re: Hi-Tech PIC Compiler latest versions Post by: mitsos on April 18, 2010, 04:42:57 16:42 hi
is that possible to add, in the last rsa keygen, support for picc18 std v9.51pl2 compiler? regards mitsos Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on April 18, 2010, 07:46:03 19:46 is that possible to add, in the last rsa keygen, support for picc18 std v9.51pl2 compiler? HI-TECH Universal RSA Keygen v2.1 now works with this compiler! Code: >picc18 --ver Title: Re: Hi-Tech PIC Compiler latest versions Post by: mbandala on April 29, 2010, 04:36:05 16:36 HI-TECH Universal RSA Keygen v2.1 now works with this compiler! Code: >picc18 --ver Will it work with the linux versions? Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on April 29, 2010, 07:48:21 19:48 Will it work with the linux versions? No, only Windows! Title: Re: Hi-Tech PIC Compiler latest versions Post by: bunion on May 01, 2010, 06:35:59 18:35 You cant beat the keygen approach , NICE JOB :)
Title: Re: Hi-Tech PIC Compiler latest versions Post by: microtech on May 02, 2010, 01:36:36 01:36 HI-TECH Universal RSA Keygen * HI-TECH Universal RSA Keygen generates real RSA signed activation data. * Replaces HI-TECH RSA public key with self-generated RSA key - different every time! * Generates permanent PRO key - no expiry date! * Tested with:
* New v2.1 detection algorithm should work with even more compilers. HI-TECH Universal RSA Keygen (v2.0) HI-TECH Universal RSA Keygen (v2.1) http://depositfiles.com/files/oy699bhti (http://depositfiles.com/files/oy699bhti) Hi, Please upload in rapidshare or other sites, cannot download from depositefiles.com. Thanks Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on May 11, 2010, 03:28:09 15:28 HI-TECH Universal RSA Keygen for LINUX
* HI-TECH Universal RSA Keygen generates real RSA signed activation data. * Replaces HI-TECH RSA public key with self-generated RSA key - different every time! * Generates permanent PRO key - no expiry date! * Tested on Ubuntu Linux 9.04 with:
HI-TECH Universal RSA Keygen for LINUX (v1.0) http://depositfiles.com/files/f25aamcnr (http://depositfiles.com/files/f25aamcnr) Title: Re: Hi-Tech PIC Compiler latest versions Post by: vovchik02 on May 12, 2010, 06:29:29 06:29 Hi, Please upload in rapidshare or other sites, cannot download from depositefiles.com. Thanks mirror http://rapidshare.com/files/386307332/HI-TECHv2.1.rar.html MD5: 344683215A92E2C498B4040316A1C6C7 http://rapidshare.com/files/389420103/HI-TECHv2.2.rar.html MD5: FD229A03C6F59202D303B6DDD9D83ACD Title: Re: Hi-Tech PIC Compiler latest versions Post by: cjq_sh on May 13, 2010, 04:01:34 16:01 HI-TECH Universal RSA Keygen
Will it work with the win7(64bit) versions? I tested it, still in lite mode? Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on May 13, 2010, 05:12:27 17:12 HI-TECH Universal RSA Keygen Will it work with the win7(64bit) versions? I tested it, still in lite mode? If you have 64-bit versions of the compilers then please upload them! If you are having problems activating the 32-bit versions on a 64-bit OS then please post the output from the keygen. I've tested the keygen on Windows 7 (64-bit) and it worked without problem. You must start with a clean install of the compiler; if you have applied any other patches then re-install the compiler. Title: Re: Hi-Tech PIC Compiler latest versions Post by: metal on May 13, 2010, 06:54:07 18:54 May be he has to run the keygen as an administrator, it writes the registry, and must be running as administrator.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on May 13, 2010, 08:12:29 20:12 May be he has to run the keygen as an administrator, it writes the registry, and must be running as administrator. It shouldn't run without elevated priviledges; in the manifest "requireAdministrator". Title: Re: Hi-Tech PIC Compiler latest versions Post by: cjq_sh on May 15, 2010, 03:24:17 15:24 May be he has to run the keygen as an administrator, it writes the registry, and must be running as administrator. I re-tested it as you say, but ...Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on May 15, 2010, 04:37:56 16:37 Very strange; I tested on Windows 7 64-bit and results are below.
Maybe this is a language issue; you are not using english Windows 7? Things to try: 1. Restart MPLAB; you need to restart MPLAB for changes in compilers to show. 2. Open a command prompt and type (maybe adjust for your language): Code: "C:\Program Files (x86)\HI-TECH Software\PICC-18\PRO\9.63\bin\picc18" --ver 3. Open registry and check Code: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\HI-TECH Software\PICC-18\PRO\9.63 Title: Re: Hi-Tech PIC Compiler latest versions Post by: cjq_sh on May 17, 2010, 02:28:13 14:28 I tested it both in Chinese Language Windows XP&Win7(64bit).
It is Ok in XP, It is not in win7(64bit). In win7(64bit), I tested Picc-v8.05PL2 and picc18-v8.35PL3, They works well. Title: Re: Hi-Tech PIC Compiler latest versions Post by: cjq_sh on May 18, 2010, 03:30:18 15:30 Thank you very much TOP.
I tested v2,2, it is still in lite mode. Title: Re: Hi-Tech PIC Compiler latest versions Post by: DrSurfer on May 18, 2010, 07:22:03 19:22 I've tested 2.1 on a win7-64 italian and PICC 9.70PL0 and it worked perfectly, activated in pro mode.
BTW, where is the 2.2 version? Title: Re: Hi-Tech PIC Compiler latest versions Post by: cjq_sh on May 19, 2010, 03:03:20 15:03 I tested CLEAN.BAT and v2.2x64.
Then it works well in pro mode. Thank you very much TOP !!! Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on May 19, 2010, 04:02:17 16:02 tested CLEAN.BAT and v2.2x64. Then it works well in pro mode. Thank you very much TOP !!! Problem was due to virtualization in Vista & Windows 7. Activation data written to registry by older keygen is written to VirtualStore and takes precedence over newer global data written by HI-TECH Universal RSA Keygen. Solution is to delete HI-TECH data from VirtualStore, CLEAN.BAT included in HI-TECH Universal RSA Keygen v2.2 deletes this data. HI-TECH Universal RSA Keygen v2.2 http://www.sonsivri.com/forum/index.php?topic=935.msg97630#msg97630 (http://www.sonsivri.com/forum/index.php?topic=935.msg97630#msg97630) Title: Re: Hi-Tech PIC Compiler latest versions Post by: Sideshow Bob on June 03, 2010, 12:59:13 12:59 Hi Caliber, Is is a small problem with the crack method in the HI-TECH PICC PRO 9.70.rar (5.53 MB). If you are using a non English windows version. HI-TECH PICC PRO 9.70.rar (5.53 MB) http://www.multiupload.com/AE7BMBILM7 is this realy working?, I have installed this using the patch, but it's show only lite mode. nor PRO. Please help if anybody try this software. thanks. You have to open open the "picc.reg" and check if the Code: "InstDir"="C:\\Program Files\\HI-TECH Software\\PICC\\9.70" By the way! Keep up the very good work both bunions and 50caliber Title: Re: Hi-Tech PIC Compiler latest versions Post by: juabba on June 09, 2010, 06:21:19 18:21 HI-TEC PIC18C + WIN 7 does not work
Hi I changed from a XP to a WIN 7 PC installed fresh MPLAB + HI-TECH 9.70 for PIC 10/12/16 that is offered as an option on the MPLAB installation. During the installation, I let installer to modify the PATH. Additionally I installed HCPIC18-pro-9.64.5502, also updating the PATH. For testing porpoises (because the hi-tech is not working) I also installed the MCC18 trial downloaded from microchip site. As a result I have MPLAB working 100% with MCC18, compiling, simulating, etc, but when I try to use any HI-TECH compiler, no luck main symptoms ( when using the “Project wizard” to generate a new project using hi-tech ) are: 1>on step two “select a language toolsuite” the HI_TECH Tool suite does not appear. If “show all installed toolsuites” is selected, it shows as “active toolsuite” the HI_TECH universal tool suite, but if I use browse to select the “C:\Program Files\HI-TECH Software\PICC\9.70\bin\picc.exe, the “store tool location in project” CAN NOT BE SELECTED, IS gray. 2>After finishing to define the new project with the wizard (including a main.c as a source file), if we go to project-->build options-->project I noticed following a> the main.c included as source program do not appear on the little window, only “project” appears as an option b> selecting the project option, if we go to the “diver” tab, the drivers list is totally empty, as if no hi-tech suite were installed. I don't think is an installation problem. Of course I removed and installed all over again at lest once to verify if any installation problem did occur pls help jjose Posted on: June 09, 2010, 07:02:10 19:02 - Automerged HI-TEC PIC18C + WIN 7 does not work Hi I changed from a XP to a WIN 7 PC installed fresh MPLAB + HI-TECH 9.70 for PIC 10/12/16 that is offered as an option on the MPLAB installation. During the installation, I let installer to modify the PATH. Additionally I installed HCPIC18-pro-9.64.5502, also updating the PATH. For testing porpoises (because the hi-tech is not working) I also installed the MCC18 trial downloaded from microchip site. As a result I have MPLAB working 100% with MCC18, compiling, simulating, etc, but when I try to use any HI-TECH compiler, no luck main symptoms ( when using the “Project wizard” to generate a new project using hi-tech ) are: 1>on step two “select a language toolsuite” the HI_TECH Tool suite does not appear. If “show all installed toolsuites” is selected, it shows as “active toolsuite” the HI_TECH universal tool suite, but if I use browse to select the “C:\Program Files\HI-TECH Software\PICC\9.70\bin\picc.exe, the “store tool location in project” CAN NOT BE SELECTED, IS gray. 2>After finishing to define the new project with the wizard (including a main.c as a source file), if we go to project-->build options-->project I noticed following a> the main.c included as source program do not appear on the little window, only “project” appears as an option b> selecting the project option, if we go to the “diver” tab, the drivers list is totally empty, as if no hi-tech suite were installed. I don't think is an installation problem. Of course I removed and installed all over again at lest once to verify if any installation problem did occur pls help jjose I have following additional information for the PIC18 MCU Family V9.63PL3 ( loaded also for testing ) "C:\Program Files\HI-TECH Software\PICC-18\PRO\9.63\bin\picc18" --ver HI-TECH C PRO for the PIC18 MCU Family V9.63PL3 Copyright (C) 1984-2009 HI-TECH SOFTWARE licensed for evaluation purposes only this licence will expire on Fri, 30 Jul 2010 looking at registry HKEY_LOCAL_MACHINE\SOFTWARE\HI-TECH Software\PICC-18\PRO\9.63 Activation “long series of binary values” expiry Fri, july 30,2010 license evaluation only serialNo HCPIC18P-DEMO Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on June 09, 2010, 07:43:31 19:43 Additionally I installed HCPIC18-pro-9.64.5502, also updating the PATH. It seems like your HCPIC18 is not getting detected by MPLAB. HCPIC18-pro-9.64.5502 is a release candidate, uninstall it and install HCPIC18-pro-9.63PL3. Quote 1>on step two “select a language toolsuite” the HI_TECH Tool suite does not appear. If “show all installed toolsuites” is selected, it shows as “active toolsuite” the HI_TECH universal tool suite, but if I use browse to select the “C:\Program Files\HI-TECH Software\PICC\9.70\bin\picc.exe, the “store tool location in project” CAN NOT BE SELECTED, IS gray. This is normal if you have chosen a PIC18 processor and MPLAB does not recognise your HCPIC18 installation. When you select 'Show all installed toolsuites' it is showing your PIC 10/12/16 compiler. 'Store tool locations in project' checkbox for the HI-TECH Universal Toolsuite is not used. Quote 2>After finishing to define the new project with the wizard (including a main.c as a source file), if we go to project-->build options-->project I noticed following a> the main.c included as source program do not appear on the little window, only “project” appears as an option b> selecting the project option, if we go to the “diver” tab, the drivers list is totally empty, as if no hi-tech suite were installed. a) I don't understand you. b) Have you got the 'Show XXXXX drivers only' box ticked? Quote I don't think is an installation problem. I think it is :) HI-TECH and Windows 7 does work. See previous posts/screenshots. Title: Re: Hi-Tech PIC Compiler latest versions Post by: Sideshow Bob on June 09, 2010, 08:16:47 20:16 Have you used the keygen in the sticky? That is the most easy one to get working. I am now using the both the 18 series and the 10/12/16 series C compiler from Hi-Tech. You could also try the clean.bat found in the sticky keygen, and then do a reinstall
Title: Re: Hi-Tech PIC Compiler latest versions Post by: juabba on June 10, 2010, 03:17:01 15:17 actually I am testing with Hi-Tech compilers downloaded from microchip ( 45 days evaluation copies) , so there is no keygen need.
looking at registry at HKEY_LOCAL_MACHINE / SOFTWARE / HI-TECH Software / PICC / PRO / 9.70 or HKEY_LOCAL_MACHINE / SOFTWARE / HI-TECH Software / PICC-18 / PRO / 9.63 I verified the programs are 100% validated. jjose Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on June 10, 2010, 04:08:20 16:08 actually I am testing with Hi-Tech compilers downloaded from microchip ( 45 days evaluation copies) , so there is no keygen need. looking at registry at HKEY_LOCAL_MACHINE / SOFTWARE / HI-TECH Software / PICC / PRO / 9.70 or HKEY_LOCAL_MACHINE / SOFTWARE / HI-TECH Software / PICC-18 / PRO / 9.63 I verified the programs are 100% validated. jjose If you have used any HI-TECH patches or keygens on this machine before then clean out any HI-TECH data from the VirtualStore and check the "InstDir" string in the following keys is correct. Windows 7 (32-bit) Code: HKEY_LOCAL_MACHINE\SOFTWARE\HI-TECH Software\PICC-18\PRO\9.63\PL0 Windows 7 (64-bit) Code: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\HI-TECH Software\PICC-18\PRO\9.63\PL0 Title: Re: Hi-Tech PIC Compiler latest versions Post by: juabba on June 10, 2010, 04:47:43 16:47 Hi Top
looking at registry at : HKEY_LOCAL_MACHINE / SOFTWARE / HI-TECH Software / PICC / PRO / 9.70 InsDir = C:\Program Files\HI-TECH Software\PICC\9.70 and on HKEY_LOCAL_MACHINE\SOFTWARE\HI-TECH Software\PICC-18\PRO\9.63\PL3 InsDir = C:\Program Files\HI-TECH Software\PICC-18\PRO\9.63 it looks correct, is it???? thanks for help jjose Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on June 10, 2010, 04:58:05 16:58 looking at registry at : HKEY_LOCAL_MACHINE / SOFTWARE / HI-TECH Software / PICC / PRO / 9.70 InsDir = C:\Program Files\HI-TECH Software\PICC\9.70 and on HKEY_LOCAL_MACHINE\SOFTWARE\HI-TECH Software\PICC-18\PRO\9.63\PL3 InsDir = C:\Program Files\HI-TECH Software\PICC-18\PRO\9.63 it looks correct, is it???? This looks OK but do you have any HI-TECH Software keys in: Code: HKEY_CURRENT_USER\Software\Classes\VirtualStore\MACHINE\SOFTWARE Title: Re: Hi-Tech PIC Compiler latest versions Post by: juabba on June 10, 2010, 05:16:09 17:16 I think you got it ;D
there is one left over HKEY_CURRENT_USER\Software\Classes\VirtualStore\MACHINE\SOFTWARE\HI-TECH Software\PICC-18\PRO\9.64\PL0 MPIndex = 00001 should I clean it??? thanks again jjose Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on June 10, 2010, 05:34:47 17:34 I think you got it ;D there is one left over HKEY_CURRENT_USER\Software\Classes\VirtualStore\MACHINE\SOFTWARE\HI-TECH Software\PICC-18\PRO\9.64\PL0 MPIndex = 00001 should I clean it??? Maybe not your problem but delete that key and check this folder for HI-TECH Software: Code: %LOCALAPPDATA%\VirtualStore\Program Files Title: Re: Hi-Tech PIC Compiler latest versions Post by: juabba on June 10, 2010, 06:00:06 18:00 Top
marvelous. :o :o thanks a lot. cleaned the two of them and 9.70 compiled ok latter will check the others regards jjose Title: Re: Hi-Tech PIC Compiler latest versions Post by: juabba on June 10, 2010, 07:51:03 19:51 when tested the 9.63 original, it reported no drivers.
in order to gain time, I used the CLEAN.BAT from the HI-TECHv2.2.rar package, and now 9.70 as well as 9,63 official versions are working ok on windows 7. now I wonder if installing the HCPIC18-pro-9.64.5502 package from this site on the windows 7 machine will function. thanks a lot to all jjose Title: Re: Hi-Tech PIC Compiler latest versions Post by: juabba on June 22, 2010, 02:32:19 14:32 I found a bug on the plib of PICC-18\PRO\9.64. Is not difficult to fix. ( have reported to microchip and they approved it) testing HI-TECH Software\PICC-18\PRO\9.64, you get an error on the HI-TECH Software\PICC-18\PRO\9.64\include\peripheral\usart.h when your source program use the UART (USART_Status), you get Error [499] ; 0. undefined symbol: _USART_Status(xxxx.obj) the problem is the lack of local definition of following union: ------------------------------------------------------------------- union USART { unsigned char val; struct { unsigned RX_NINE:1; // Receive Bit 8 if 9-bit mode is enabled unsigned TX_NINE:1; // Transmit Bit 8 if 9-bit mode is enabled unsigned FRAME_ERROR:1; // Framing Error for USART unsigned OVERRUN_ERROR:1; // Overrun Error for USART unsigned fill:4; }; }; extern union USART USART_Status; ------------------------------------------------------------------- as you can see, it has the “extern” keyword at the beginning of last line above. Just removing the extern fix the problem ( you'll find same problem on 3 places of “PRO\9.64\include\peripheral\usart.h”) extern union USART USART_Status; extern union USART1 USART1_Status; extern union USART2 USART2_Status; regards juabba Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on June 24, 2010, 01:49:24 13:49 HI-TECH C Compiler for PIC10-12-16 MCUs V9.71a
http://depositfiles.com/files/mzw39xyxw (http://depositfiles.com/files/mzw39xyxw) * New release (24-jun-2010) HI-TECH Universal RSA Keygen v2.3 http://www.sonsivri.com/forum/index.php?topic=935.msg97630#msg97630 (http://www.sonsivri.com/forum/index.php?topic=935.msg97630#msg97630) Title: Re: Hi-Tech PIC Compiler latest versions Post by: cddx on July 01, 2010, 01:57:07 01:57 I found a bug on the plib of PICC-18\PRO\9.64. Is not difficult to fix. ( have reported to microchip and they approved it) testing HI-TECH Software\PICC-18\PRO\9.64, you get an error on the HI-TECH Software\PICC-18\PRO\9.64\include\peripheral\usart.h when your source program use the UART (USART_Status), you get Error [499] ; 0. undefined symbol: _USART_Status(xxxx.obj) the problem is the lack of local definition of following union: ------------------------------------------------------------------- union USART { unsigned char val; struct { unsigned RX_NINE:1; // Receive Bit 8 if 9-bit mode is enabled unsigned TX_NINE:1; // Transmit Bit 8 if 9-bit mode is enabled unsigned FRAME_ERROR:1; // Framing Error for USART unsigned OVERRUN_ERROR:1; // Overrun Error for USART unsigned fill:4; }; }; extern union USART USART_Status; ------------------------------------------------------------------- as you can see, it has the “extern” keyword at the beginning of last line above. Just removing the extern fix the problem ( you'll find same problem on 3 places of “PRO\9.64\include\peripheral\usart.h”) extern union USART USART_Status; extern union USART1 USART1_Status; extern union USART2 USART2_Status; regards juabba I found a bug on the plib of PICC-18\PRO\9.64. it's not a bug! since you have only declarationIs not difficult to fix. ( have reported to microchip and they approved it) testing HI-TECH Software\PICC-18\PRO\9.64, you get an error on the HI-TECH Software\PICC-18\PRO\9.64\include\peripheral\usart.h when your source program use the UART (USART_Status), you get Error [499] ; 0. undefined symbol: _USART_Status(xxxx.obj) the problem is the lack of local definition of following union: ------------------------------------------------------------------- union USART { unsigned char val; struct { unsigned RX_NINE:1; // Receive Bit 8 if 9-bit mode is enabled unsigned TX_NINE:1; // Transmit Bit 8 if 9-bit mode is enabled unsigned FRAME_ERROR:1; // Framing Error for USART unsigned OVERRUN_ERROR:1; // Overrun Error for USART unsigned fill:4; }; }; extern union USART USART_Status; ------------------------------------------------------------------- as you can see, it has the “extern” keyword at the beginning of last line above. Just removing the extern fix the problem ( you'll find same problem on 3 places of “PRO\9.64\include\peripheral\usart.h”) extern union USART USART_Status; extern union USART1 USART1_Status; extern union USART2 USART2_Status; regards juabba Title: Re: Hi-Tech PIC Compiler latest versions Post by: Manuel on July 03, 2010, 10:44:59 10:44 Something I got reading on Mchip site related to Compiler...
Note: Version 9.71a is intended for midrange devices only. Baseline support is limited at this time and will be fully supported in version 9.72 take care u all! Title: Re: Hi-Tech PIC Compiler latest versions Post by: kipkip on July 06, 2010, 08:18:43 08:18 Mirror D/L link --> HI-TECHv2.3.rar
http://ifile.it/phbe5ng Title: Re: Hi-Tech PIC Compiler latest versions Post by: dientuso on July 20, 2010, 06:04:15 18:04 HI-TECH Universal RSA Keygen for LINUX * HI-TECH Universal RSA Keygen generates real RSA signed activation data. * Replaces HI-TECH RSA public key with self-generated RSA key - different every time! * Generates permanent PRO key - no expiry date! * Tested on Ubuntu Linux 9.04 with:
HI-TECH Universal RSA Keygen for LINUX (v1.0) http://depositfiles.com/files/f25aamcnr (http://depositfiles.com/files/f25aamcnr) Anyone tested on Karmic(Ubuntu 10.04) It fail on Karmic with message: Activatation error : Invalid serial number Exit status 161 anybody can help me??? Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on July 20, 2010, 07:04:36 19:04 Anyone tested on Karmic(Ubuntu 10.04) It fail on Karmic with message: Activatation error : Invalid serial number Exit status 161 anybody can help me??? Look in the README; this is normal on Linux as there is no option for off-line activation. You now need to run the keygen and then the 'activate' command with the keyfile.dat. Also, note that the Linux Keygen (v1.0) has not been tested with v9.71a. Title: Re: Hi-Tech PIC Compiler latest versions Post by: omni on August 02, 2010, 03:57:14 15:57 Hmm,
Are Mac users left out in the cold, I see Windows and Linux but no Mac keygen? :( If you require help porting it, I might be able to assist... Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on August 21, 2010, 12:24:57 12:24 HI-TECH C for the PIC10/12/16 MCU Family v9.80
http://depositfiles.com/files/2qkj1y42p (http://depositfiles.com/files/2qkj1y42p) * New release (19-aug-2010) Title: Re: Hi-Tech PIC Compiler latest versions Post by: metal on August 21, 2010, 01:53:03 13:53 Looking at the release notes, thought people who don't read the release note might be interested to know:
Quote from: Release Notes 2.2 Delay Functions The __delay_ms and __delay_us function descriptions in the manual indicate that a macro _XTAL_FREQ needs to be defined to be the oscillator frequency. This value should be a frequency 4 times the instruction frequency. It may not be the same as the crystal frequency if multipliers are used. This is it: _XTAL_FREQ = Instruction Working Frequency x 4 For example: If we have a crystal of 8MHz, then _XTAL_FREQ = 8000000 If we are using 4MHz crystal, and a multiplier makes it 48MHz which becomes the system clock (this is a rough & quick example) then the instruction frequency is 12MHz and _XTAL_FREQ = 48000000, although we are using 4MHz crystal. Kindly correct me if I am wrong. HI-TECH C Compiler for PIC10/12/16 MCUs (PRO/Standard/LITE) v9.80 download link (http://ww1.microchip.com/downloads/en/DeviceDoc/HCPIC-pro-9_80.zip) Title: Re: Hi-Tech PIC Compiler latest versions Post by: pickit2 on August 21, 2010, 03:40:24 15:40 Metal it's the same in PDS you have to use the pll (40Hz) speed in your code not the xtal freq (10Hz).
as this shows. Code: Device = 18F2431 Title: Re: Hi-Tech PIC Compiler latest versions Post by: metal on August 21, 2010, 04:49:28 16:49 Strange is that they have not modify this in the User Manual yet..
Title: Re: Hi-Tech PIC Compiler latest versions Post by: Yahma on August 28, 2010, 06:10:08 18:10 HI-TECH Universal RSA Keygen for LINUX * HI-TECH Universal RSA Keygen generates real RSA signed activation data. * Replaces HI-TECH RSA public key with self-generated RSA key - different every time! * Generates permanent PRO key - no expiry date! * Tested on Ubuntu Linux 9.04 with:
HI-TECH Universal RSA Keygen for LINUX (v1.0) http://depositfiles.com/files/f25aamcnr (http://depositfiles.com/files/f25aamcnr) Do you have a new version of the linux Keygen that will work with 9.80? Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on August 29, 2010, 12:15:54 00:15 Do you have a new version of the linux Keygen that will work with 9.80? v1.0 is working OK; edit Reactivate-PICC-PRO-9.80 adding the --keyfile switch at the end and then run it. Title: Re: Hi-Tech PIC Compiler latest versions Post by: robban on September 08, 2010, 05:37:23 05:37 May You could change "program Files" to Program"
Don't now it will solve the problem, but may it will comply with a clean output. Good luck. and if You get stuck. Pls. revert. Regards Robban Title: Re: Hi-Tech PIC Compiler latest versions Post by: m_saeed_soliman on December 15, 2010, 09:44:07 09:44 Hi, all
I have a problem integrating PICC compiler for PIC10/12/16 v9.80 with Hi-TIDE v3.15. Please, could any one tell me how to add the plugin to allow Hi-TIDE use PICC, I cannot find it in the compiler selection. Title: Re: Hi-Tech PIC Compiler latest versions Post by: ALLPIC on December 25, 2010, 03:57:37 03:57 Hitech Pro 9.65 for PIC18 released
http://ww1.microchip.com/downloads/en/DeviceDoc/HCPIC18-pro-9.65.exe HI-TECH Universal RSA Keygen (v2.3) :- works fine no issues Title: Re: Hi-Tech PIC Compiler latest versions Post by: zaalzaalak on January 02, 2011, 04:25:32 16:25 Please send rapidshare link for above link.(please send the latest versions of HiTech PICs on RS if possible)
Question: If we use the given l RSA Keygen (v2.3) with HiTech ,is there any remained limitation in software? Can we work with the libraries?(I am new in HiTech) Title: Re: Hi-Tech PIC Compiler latest versions Post by: pickit2 on January 02, 2011, 10:29:28 22:29 Please send rapidshare link for above link.(please send the latest versions of HiTech PICs on RS if possible) Question: If we use the given l RSA Keygen (v2.3) with HiTech ,is there any remained limitation in software? Can we work with the libraries?(I am new in HiTech)Why do you need rapidshare link, link is for Microchip site? Title: Re: Hi-Tech PIC Compiler latest versions Post by: Sideshow Bob on January 02, 2011, 11:22:16 23:22 Please send rapidshare link for above link.(please send the latest versions of HiTech PICs on RS if possible) Just download the HI-Tech C compiler from microchip. Then use the RSA Keygen. And you will have the pro version for more than 30 days Question: If we use the given l RSA Keygen (v2.3) with HiTech ,is there any remained limitation in software? Can we work with the libraries?(I am new in HiTech) Title: Re: Hi-Tech PIC Compiler latest versions Post by: Manuel on January 20, 2011, 07:45:53 07:45 Released new C pro compiler for PIC16 family. V9.81_PL0
2.3 did great Job ! Useful Note: in headers changed some register naming..... Manuel. Title: Re: Hi-Tech PIC Compiler latest versions Post by: jss on March 28, 2011, 11:12:19 23:12 v1.0 is working OK; edit Reactivate-PICC-PRO-9.80 adding the --keyfile switch at the end and then run it. Now about 9.81 (for linux), it's not working (ubuntu 10.10), and this is what I found: 1. With network connected # sudo ./picc-9_81-linux.run ... ==> This script will install HI-TECH PICC PRO version 9.81. ... ==> Do you accept the terms of the licence agreement? [y/n] y ==> Please enter the installation directory [/usr/hitech/picc/9.81]:/usr/hitech/picc/9.81 ... ==> Please enter Serial Number, demo or lite: HCPICP-111222 ==> Activating... ==> Command succeeded. ... # sudo ./HI-TECH HI-TECH Universal RSA Keygen v1.0 ==> Enter serial number [e.g. HCPIC18P-654321]: HCPICP-111222 ==> Enter the installation directory: /usr/hitech/picc/9.81 ... # /usr/hitech/picc/9.81/bin/activate --datfile=/usr/hitech/picc/9.81/bin/activate.dat --product=PICC/pro --version=9.81 --serial=HCPICP-111222 -f --keyfile=/usr/hitech/picc/9.81/keyfile.dat HI-TECH Product Activator v1.1 Copyright (C) 2010 Microchip Technology Inc. Activation error: Key not valid: error 1187 Exit status 90 Now, delete installation: /usr/hitech/ /etc/htsoft.xml has not been created or was deleted by failed activation, doesn't matter. 2. With network disconnected: Same scenario up to activation, then: # /usr/hitech/picc/9.81/bin/activate --datfile=/usr/hitech/picc/9.81/bin/activate.dat --product=PICC/pro --version=9.81 --serial=HCPICP-111222 -f --keyfile=/usr/hitech/picc/9.81/keyfile.dat HI-TECH Product Activator v1.1 Copyright (C) 2010 Microchip Technology Inc. Activation successful. # sudo ./picc --ver HI-TECH C Compiler for PIC10/12/16 MCUs (PRO Mode) V9.81 Copyright (C) 2010 Microchip Technology Inc. Serial number: HCPICP-111222 (PRO) Seems ok? Now reconnect network # sudo ./picc --ver (1273) Omniscient Code Generation not available in Lite mode (warning) HI-TECH C Compiler for PIC10/12/16 MCUs (Lite Mode) V9.81 Copyright (C) 2010 Microchip Technology Inc. I've tested this countless times and used wireshark to detect outbound communication; even disconnected ntpd to have less packets to examine: couldn't find any packet going outbound except dhcp, imgp and dns protocols. It's really puzzling me, I'll leave it to you Top. jss Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on March 29, 2011, 08:27:12 08:27 Now about 9.81 (for linux), it's not working (ubuntu 10.10), and this is what I found: ... Did v9.80 work OK? I'm guessing it's something to do with your MAC address; how many network adaptors are in the machine? Please provide a link to v9.81 for Linux. Title: Re: Hi-Tech PIC Compiler latest versions Post by: jss on March 29, 2011, 10:50:50 10:50 I never had 9.80 but I downloaded 9.80a together with mplab x; it didn't activate but I didn't investigate further, just moved on to 9.81 from here: http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en542849 Downloads at end of page. I wonder whether you can reach the page without registering. I can upload it to a server of your choice if necessary. The machine has wlan0 and eth0 (wireless and wired) apart, of course, from loopback. eth0 was always disconnected during the tests which just made with wlan0. You mean that I should completely disable one of them to hide the mac address? And the compiler installation is supposed to be made with net on? Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on March 29, 2011, 11:37:14 11:37 I never had 9.80 but I downloaded 9.80a together with mplab x; it didn't activate but I didn't investigate further, just moved on to 9.81 from here: http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en542849 Downloads at end of page. I wonder whether you can reach the page without registering. I can upload it to a server of your choice if necessary. Can't download without account. Please upload to RapidShare or http://ifile.it/ (http://ifile.it/) Quote The machine has wlan0 and eth0 (wireless and wired) apart, of course, from loopback. eth0 was always disconnected during the tests which just made with wlan0. You mean that I should completely disable one of them to hide the mac address? And the compiler installation is supposed to be made with net on? The key is locked to MAC address and I'm guessing that the keygen is finding a different MAC to the compiler. I'll test v9.81 when you upload it and modify the keygen to display the MAC it is locking to. Title: Re: Hi-Tech PIC Compiler latest versions Post by: jss on March 29, 2011, 11:57:36 11:57 Can't download without account. Please upload to RapidShare or http://ifile.it/ (http://ifile.it/) Done: http://ifile.it/w8h9ozm The key is locked to MAC address and I'm guessing that the keygen is finding a different MAC to the compiler. I'll test v9.81 when you upload it and modify the keygen to display the MAC it is locking to. Just tested with ubuntu inside virtualbox with only one eth1, connected during full process. Got: Activation error: Key not valid: error 1187 By the way, keygen is working perfectly with 9.81 for windows, just FYI Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on March 29, 2011, 03:17:32 15:17 Just tested with ubuntu inside virtualbox with only one eth1, connected during full process. Got: Activation error: Key not valid: error 1187 Seems like the Linux ELF files are now packed and that's why the keygen is not working. I don't know anything about unpacking ELF files but if you can unpack them then a patch would be simple. By the way, keygen is working perfectly with 9.81 for windows, just FYI Glad to hear this! Title: Re: Hi-Tech PIC Compiler latest versions Post by: jss on March 29, 2011, 04:25:58 16:25 When I open the file with hex editor what I see is no ELF header but a script that starts: #!/bin/sh # This script was generated using Makeself 2.1.4 So, this is a self-extracting archive made by Makeself. Perhaps I led you in mistake by compressing the file into .tar.gz? I just didn't want the name of the file to appear indexed on google. I'm sorry if I wasted your time. So, please either extract from the file you already have with tar or dowload again with a .zip archiving format and try again? http://ifile.it/fgh89td You can then: # ./picc-9_81-linux.run --noexec --target anydir and the filesystem will extract to <anydir> that you have created previously. Sorry for the mess. I'll be here for any further assistance. jss Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on March 29, 2011, 04:49:34 16:49 When I open the file with hex editor what I see is no ELF header but a script that starts: #!/bin/sh # This script was generated using Makeself 2.1.4 So, this is a self-extracting archive made by Makeself. Perhaps I led you in mistake by compressing the file into .tar.gz? I just didn't want the name of the file to appear indexed on google. I'm sorry if I wasted your time. So, please either extract from the file you already have with tar or dowload again with a .zip archiving format and try again? http://ifile.it/fgh89td You can then: # ./picc-9_81-linux.run --noexec --target anydir and the filesystem will extract to <anydir> that you have created previously. Sorry for the mess. I'll be here for any further assistance. jss I wasn't talking about the install file. I'm referring to the executables; activate & picc in the bin folder. Title: Re: Hi-Tech PIC Compiler latest versions Post by: jss on March 29, 2011, 04:59:59 16:59 Yes, I got that; after you uncompress the zip dowloaded file you get picc-9_81-linux.run If you then run: # ./picc-9_81-linux.run --noexec --target anydir you get the file structure inside <anydir> which contains what you want: anydir/bin/activate anydir/bin/picc If necessary, I can upload the whole filesystem tree, please inform. jss Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on March 29, 2011, 05:23:08 17:23 Forget about the tar.gz and run files, I have it installed and have the 'whole filesystem tree'.
I'll try and explain again :) It looks like the Linux ELF executable files, activate and picc are now packed or protected with something and I am having trouble running them in a debugger. If you try to load activate into a disassembler you'll see what I mean. I don't know anything about unpacking Linux ELF executable files but if you can unpack them then a patch will be simple. Title: Re: Hi-Tech PIC Compiler latest versions Post by: jss on March 29, 2011, 05:31:03 17:31 Ok, I'm very sorry I was wandering around; I feel a bit silly :-[ I have to go out now but I'll try to do that and get back as soon as it's ready. jss Title: Re: Hi-Tech PIC Compiler latest versions Post by: jss on March 30, 2011, 12:54:00 00:54 I have to confess that I also don't know much about ELF files but I already learned a lot since this afternoon. I'm mostly a firmware man, on the hardware / software boarder. I was a windows user up to about four years ago and I must confess that I find debugging / disassembling tools much better on windows (OllyDbg, ...) than on linux. The probable cause is linux applications being opensource (large majority), who wants to reverse engineer them? Linux also doesn't have virus (almost) to study. That said, I know your final purpose but I don't know how you are planning to get there. So, I looked for a ELF unpacking tool as you requested and the closest I found was ELFsh, which I don't think can help us. Also tried gdb with cgdb and xxgdb frontends, Nemiver, objdump with dissy frontend and others, also with no results. Then, on the disassemble section, which might be what you're looking for, there's something similar to hiew for windows (remember this?). It's called BEYE but used to be BIEW. It's on sourceforge but doesn't have a debian package (I assume you're on debian or derivative). So I compiled it and made a working package. Should I upload it for you? Waiting for directions. jss Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on March 30, 2011, 08:57:41 20:57 Please disregard my last few posts about the Linux ELF files being packed/protected. Somehow the v9.81 download got corrupted and it made things look wierd in IDA.
I've tested my HI-TECH Universal RSA Keygen for LINUX on v9.81 and it's working fine; I couldn't reproduce your problems with or without network connection. I even installed Ubuntu 10.10 (32-bit) in VMware and tested again and it's OK; with and without network connections. My original diagnosis, that it's a problem with your MAC address, is again my best guess without further testing. Title: Re: Hi-Tech PIC Compiler latest versions Post by: jss on March 30, 2011, 10:00:20 22:00 My original diagnosis, that it's a problem with your MAC address, is again my best guess without further testing. I'm a bit lost then. Do you have any suggestion on how I should proceed to debug this problem, please? jss Edit: Could this be a permission problem? I'm doing everything as root, sudo in fact, installing the compiler, running keygen and reactivation, I guess this is correct / necessary, isn't it? Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on March 30, 2011, 11:28:50 23:28 I'm a bit lost then. Do you have any suggestion on how I should proceed to debug this problem, please? jss Edit: Could this be a permission problem? I'm doing everything as root, sudo in fact, installing the compiler, running keygen and reactivation, I guess this is correct / necessary, isn't it? Yes, unless you're installing everything in your home directory you need root privileges. Here's a version of the keygen (http://ifile.it/8s4p29g (http://ifile.it/8s4p29g)) that prints the MAC address that it's locking to; it won't fix your problem but it may give a clue to what's causing it. Try it with and without your network connection and report back. Title: Re: Hi-Tech PIC Compiler latest versions Post by: jss on March 31, 2011, 12:19:33 00:19 ...prints the MAC address that it's locking to; it won't fix your problem but it may give a clue to what's causing it. Try it with and without your network connection and report back. Excellent hunch! Both with net on and off: ==> Locking to MAC Address: 00:00:00:00:00:00 # ifconfig eth1 Link encap:Ethernet HWaddr 08:00:27:4f:4d:86 # no publishing problem, it's a virtual machine inet6 addr: fe80::a00:27ff:fe4f:4d86/64 Scope:Link UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:6070 errors:0 dropped:0 overruns:0 frame:0 TX packets:3189 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:427315 (427.3 KB) TX bytes:224439 (224.4 KB) lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:4 errors:0 dropped:0 overruns:0 frame:0 TX packets:4 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:240 (240.0 B) TX bytes:240 (240.0 B) Extended thanks for your continued support and time. I would click the button 10 times but I think it's not allowed. jss Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on March 31, 2011, 12:47:03 00:47 Excellent hunch! Both with net on and off: ==> Locking to MAC Address: 00:00:00:00:00:00 Very strange that the keygen cannot determine your MAC address! One more to try (http://ifile.it/nzvlpek (http://ifile.it/nzvlpek)); enter MAC address manually (NB: maybe case sensitive) and report back. Title: Re: Hi-Tech PIC Compiler latest versions Post by: jss on March 31, 2011, 01:20:32 01:20 Very strange that the keygen cannot determine your MAC address! ...enter MAC address manually (NB: maybe case sensitive) and report back. Finally success!!! You're brilliant, many thanks. # ./picc --ver HI-TECH C Compiler for PIC10/12/16 MCUs (PRO Mode) V9.81 Copyright (C) 2010 Microchip Technology Inc. Serial number: HCPICP-889900 (PRO) But you're right, it's case sensitive, uppercase is required on the MAC address. Well, my problem is solved, I'll click the 'Thanks' button but I guess you want to completely solve this matter to automatically detect the mac for the benefit of others. That said, me and my boxes are at your entire discretion. Waiting for directions again... jss Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on March 31, 2011, 01:47:39 01:47 # ifconfig eth1 Link encap:Ethernet HWaddr 08:00:27:4f:4d:86 # no publishing problem, it's a virtual machine inet6 addr: fe80::a00:27ff:fe4f:4d86/64 Scope:Link UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:6070 errors:0 dropped:0 overruns:0 frame:0 TX packets:3189 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:427315 (427.3 KB) TX bytes:224439 (224.4 KB) lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:4 errors:0 dropped:0 overruns:0 frame:0 TX packets:4 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:240 (240.0 B) TX bytes:240 (240.0 B) This is the problem; the keygen locks to eth0 but where is your eth0? Title: Re: Hi-Tech PIC Compiler latest versions Post by: jss on March 31, 2011, 11:50:23 11:50 This is the problem; the keygen locks to eth0 but where is your eth0? It doesn't have one, probably a leftover, this is an old virtual machine. But I think I already progressed from that so you can forget it. In fact, I just installed on the physical machine and the problem is that the keygen reports the first nic, eth0, as default when it asks for a MAC addr, whereas the compiler install used wlan0 to communicate with MC because eth0 was down. So, if I accept the default MAC (eth0), it fails; but if I override to the the wlan0 MAC, it succeeds. I could, if you find necessary, disconnect wlan0 and make the whole thing using eth0 but I'm almost sure it would succeed. I didn't because I wanted to let you know the news immediately. jss Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on March 31, 2011, 01:16:42 13:16 In fact, I just installed on the physical machine and the problem is that the keygen reports the first nic, eth0, as default when it asks for a MAC addr, whereas the compiler install used wlan0 to communicate with MC because eth0 was down. I think this is going a bit off-topic so please reply by PM and if a new linux keygen transpires it can be announced here. I'd like to see the output from ifconfig with eth0 connected and then disconnected and also when you are disconnecting these interfaces what exactly are you doing? Title: Re: Hi-Tech PIC Compiler latest versions Post by: ALLPIC on June 07, 2011, 06:33:42 06:33 http://ww1.microchip.com/downloads/en/DeviceDoc/HCPIC18-pro-9_66.exe
same crack working ;D Title: Re: Hi-Tech PIC Compiler latest versions Post by: Manuel on June 21, 2011, 05:28:43 17:28 New Version C pro 9.82
2.3 great job really great! Manuel!! Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on June 21, 2011, 05:50:13 17:50 New Version C pro 9.82 2.3 great job really great! Manuel!! link please? thanks! :) Title: Re: Hi-Tech PIC Compiler latest versions Post by: Wannabe on June 21, 2011, 05:59:38 17:59 http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en542849
Title: Re: Hi-Tech PIC Compiler latest versions Post by: Manuel on September 23, 2011, 06:12:58 18:12 V9.83 PICC PRO/STD/LITE
All platform http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en542849 And .... 2.3 Rocks ! 'njoy. Title: Re: Hi-Tech PIC Compiler latest versions Post by: max on September 24, 2011, 08:57:29 20:57 Hi PICC users,
Does the compiler or the ide support the peripheral code generations like in codevision avr complier? Regards Title: Re: Hi-Tech PIC Compiler latest versions Post by: Manuel on September 24, 2011, 10:36:34 22:36 NONE, sorry.
Better always build everything .... you will find less surprises.... X: Title: Re: Hi-Tech PIC Compiler latest versions Post by: metal on September 25, 2011, 12:42:02 00:42 This can be easily done, even for large PICs, here is a small example for a small PIC:
Code: void setup() Title: Re: Hi-Tech PIC Compiler latest versions Post by: SpaleKG on October 01, 2011, 07:17:15 19:17 Can someone publish source for linux version of crack/keygen.
I want to port it to Mac OSX and try did it work for latest version of compiler for Mac. Best regards. Title: Re: Hi-Tech PIC Compiler latest versions Post by: Mr. Spock on October 03, 2011, 12:37:59 12:37 HI-TECH_C_Compiler_for_PIC18_MCUs_(PRO)_v9.80
Use version 2.3 keygen (see above). Link: http://www.filefactory.com/file/ce1171f/n/HI-TECH_C_Compiler_for_PIC18_MCUs_(PRO)_v9.80.rar Title: Re: Hi-Tech PIC Compiler latest versions Post by: picaboo on October 12, 2011, 04:59:31 04:59 Hello Gurus,
I am having problem in compiling an old simple project using picc v9.83 + mplab v8.76. Let me start by mentioning that I am resuming my PIC activity almost after 18 months. 18 months ago my toolset was mplab v8.36 and hi-tech picc v9.65 (from bunion). I had developed some complex systems using this toolset. Before resuming my PIC activity again, I thought of updating the toolset to latest ones. So, I installed MPLAB v8.76 and hi-tech picc v9.83 (activated by RSA keygen v2.3 above). I confirmed the activation by 'picc.exe --ver' in command terminal. I am using windows XP Professional with SP3. After installing latest toolsuite, I tried to compile a very simple project. LED blinking. This is one of the tutorial project that used to build and run successfully with my 18 months old toolset. Here are the simple c codes. Target device is 16F877A. file - main.c ===== #include <htc.h> __CONFIG(XT & WDTDIS & PWRTDIS & BORDIS & LVPDIS & WRTEN & DEBUGEN & DUNPROT & UNPROTECT); void init(void) { PIE1 = 0b00000001; INTCON = 0b01000000; OPTION = 0b10000000; // port directions: 1=input, 0=output TRISB = 0b00000000; T1CON = 0b00110101; } volatile char counter; void main(void) { counter = 0; init(); ei(); while (1){ PORTB = counter; } file - int.c ==== #include <htc.h> extern volatile char counter; void interrupt my_isr(void){ if((TMR1IE)&&(TMR1IF)){ counter++; TMR1IF=0; } } Following is the error I am getting when I press 'build' button. ================================================================= Build H:\Technical\Electronics\microcontroller\PIC\Projects\portB_LED_blink\portB_LED_blink for device 16F877A Using driver C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe Make: The target "H:\Technical\Electronics\microcontroller\PIC\Projects\portB_LED_blink\main.p1" is out of date. Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 H:\Technical\Electronics\microcontroller\PIC\Projects\portB_LED_blink\main.c -q --chip=16F877A -P --runtime=default,+init,-keep,+osccal,+oscval:0,-download,-resetbits,+stackcall,+clib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -D__DEBUG=1 --double=24 --float=24 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s" Error [192] H:\Technical\Electronics\microcontroller\PIC\Projects\portB_LED_blink\main.c; 10.1 undefined identifier "OPTION" Make: The target "H:\Technical\Electronics\microcontroller\PIC\Projects\portB_LED_blink\int.p1" is out of date. Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 H:\Technical\Electronics\microcontroller\PIC\Projects\portB_LED_blink\int.c -q --chip=16F877A -P --runtime=default,+init,-keep,+osccal,+oscval:0,-download,-resetbits,+stackcall,+clib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -D__DEBUG=1 --double=24 --float=24 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s" ********** Build failed! ********** ============================================================= The "OPTION variable seems to be not defined in the header file. But it used to work with picc v9.65. Is there any change in SFR while I was away? Really appreciate your help. If you think this is not the right thread, please advice me the correct pleace to post it. Thanks. Posted on: October 12, 2011, 05:30:48 05:30 - Automerged Ok, by looking at several header files, I figured that the header format has changed (for good, it seems) and the OPTION is renamed to OPTION_REG. chip_select.h uses a flag _LEGACY_HEADERS to decide if old or new header files should be used. #ifdef _16F877A #ifdef _LEGACY_HEADERS #include <legacy/pic168xa.h> #else #include <pic16f877a.h> #endif #endif legacy/pic168xa.h has OPTION defined, but pic16f877a.h has OPTION_REG defined. How do I set this _LEGACY_HEADERS flag? Directly in my code like this, #define _LEGACY_HEADERS #include <htc.h> Or is there a way to specify it to project options? I searched in MPLAB, but in vain. Would appreciate if anybody can guide me to the right approach. Thanks. Title: Re: Hi-Tech PIC Compiler latest versions Post by: metal on October 12, 2011, 06:04:24 06:04 As long as it has changed for good, why stick to 'OPTION', just use 'OPTION_REG' and you are done. On the other hand, may be you have to include the legacy header file if it exists, I have not tried or looked at the legacy folder, or use this:
#define OPTION OPTION_REG Title: Re: Hi-Tech PIC Compiler latest versions Post by: ME on October 12, 2011, 06:42:01 06:42 Questions like this one are often answered in the Hi-Tech forum
Take a look here: http://forum.htsoft.com/all/showflat.php?Number=215222 (http://forum.htsoft.com/all/showflat.php?Number=215222) best regards Title: Re: Hi-Tech PIC Compiler latest versions Post by: kaizer on October 25, 2011, 03:41:33 15:41 hi guys, anyone of you tried the HI-TECH Universal RSA Keygen (v2.3) for Hitech C PRO 9.82 for PIC10/12/16?
just want to confirm before i try it, my Trial version will expire next month... TIA Title: Re: Hi-Tech PIC Compiler latest versions Post by: marcodassi on October 25, 2011, 05:24:12 17:24 Works perfectly :D
Title: Re: Hi-Tech PIC Compiler latest versions Post by: sertek on November 05, 2011, 01:12:32 13:12 microchip download :
http://ww1.microchip.com/downloads/en/DeviceDoc/PICC_18_9_80_win.zip Title: Re: Hi-Tech PIC Compiler latest versions Post by: XaroRSA on December 05, 2011, 01:11:20 13:11 Can someone help me get the Hi-Tech compiler running in Flowcode PIC version?
Title: Re: Hi-Tech PIC Compiler latest versions Post by: mbandala on December 14, 2011, 07:03:30 19:03 v1.0 is working OK; edit Reactivate-PICC-PRO-9.80 adding the --keyfile switch at the end and then run it. Hi there! The linux keygen works perfectly with 9.83 in Ubuntu/Debian distros, however I had to migrate to Fedora due to my VLSI related work. Folowing the same procedure with Ubuntu, I confirm that the keygen does not work in Fedora Linux. I have tried both Fedora 15 and 16, the keygen confirms a succesful activation but ./picc --ver in terminal shows the Lite Mode warning. I have tried this using the same computer where the keygen worked with Ubuntu, so it must be a distro problem. Any help would be appreciated! Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on December 14, 2011, 07:31:53 19:31 The linux keygen works perfectly with 9.83 in Ubuntu/Debian distros, however I had to migrate to Fedora due to my VLSI related work. Folowing the same procedure with Ubuntu, I confirm that the keygen does not work in Fedora Linux. I have tried both Fedora 15 and 16, the keygen confirms a succesful activation but ./picc --ver in terminal shows the Lite Mode warning. I have tried this using the same computer where the keygen worked with Ubuntu, so it must be a distro problem. Any help would be appreciated! I think v1.1 of the Linux keygen is in this message; http://www.sonsivri.to/forum/index.php?topic=935.msg115455#msg115455 (http://www.sonsivri.to/forum/index.php?topic=935.msg115455#msg115455) Try it and if you have a problem PM or post the output from the keygen. Title: Re: Hi-Tech PIC Compiler latest versions Post by: SpaleKG on December 21, 2011, 10:28:49 10:28 Can I obtain source code of linux keygen version, I want to try keygen on OSX version of HI-TECH.
Best regards. Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on December 21, 2011, 12:34:30 12:34 Can I obtain source code of linux keygen version, I want to try keygen on OSX version of HI-TECH. Here is an old OSX port; should still be working: http://ifile.it/qbdhnye/HT_Keygen (http://ifile.it/qbdhnye/HT_Keygen) Title: Re: Hi-Tech PIC Compiler latest versions Post by: SpaleKG on December 23, 2011, 09:53:33 21:53 Here is an old OSX port; should still be working: http://ifile.it/qbdhnye/HT_Keygen (http://ifile.it/qbdhnye/HT_Keygen) It said activation success but seems it doesnt work :( spale@spale:~$ picc18 --ver (1273) Omniscient Code Generation not available in Lite mode (warning) HI-TECH C Compiler for PIC18 MCUs (Lite Mode) V9.80 Copyright (C) 2011 Microchip Technology Inc. spale@spale:~$ picc --ver (1273) Omniscient Code Generation not available in Lite mode (warning) HI-TECH C Compiler for PIC10/12/16 MCUs (Lite Mode) V9.83 Copyright (C) 2011 Microchip Technology Inc. spale@spale:~$ Maybe I need to know for what version of compiler keygen is and try to use that version. Can you provide that info? Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on December 23, 2011, 10:31:50 22:31 Maybe I need to know for what version of compiler keygen is and try to use that version. It should work on any version but you need to manually search and replace RSA key. Title: Re: Hi-Tech PIC Compiler latest versions Post by: SpaleKG on December 23, 2011, 10:46:00 22:46 It should work on any version but you need to manually search and replace RSA key. If you mean to replace activate.dat I did that (I overwrite original one in /Applications/HI-TECH/picc-18/9.80/bin/). Here is complete procedure: spale@spale:~$ ./HT_Keygen HI-TECH Universal RSA Keygen for OSX v1.0 ==> Enter serial number [e.g. HCPIC18P-654321]: HCPIC18P-654321 ==> Generating new RSA key. ==> Saving new RSA key to activate.dat ==> Writing key file to keyfile.dat spale@spale:~$ cp activate.dat /Applications/HI-TECH/picc-18/9.80/bin/ spale@spale:~$ /Applications/HI-TECH/picc-18/9.80/bin/activate --keyfile=keyfile.dat --serial=HCPIC18P-654321 HI-TECH Product Activator v1.1 Copyright (C) 2011 Microchip Technology Inc. Activation successful. spale@spale:~$ picc18 --ver (1273) Omniscient Code Generation not available in Lite mode (warning) HI-TECH C Compiler for PIC18 MCUs (Lite Mode) V9.80 Copyright (C) 2011 Microchip Technology Inc. UPDATE: Thanks to Top I finally did it. All executable files need to be searched for RSA key (old one) and replaced with context (binary) with generated one (from activate.dat). Now I receive: spale@spale:~$ picc18 --ver HI-TECH C Compiler for PIC18 MCUs (PRO Mode) V9.80 Copyright (C) 2011 Microchip Technology Inc. Serial number: HCPIC18P-654321 (PRO) spale@spale:~$ I will make patcher for auto patching. When I finish that I will let you know. Title: Re: Hi-Tech PIC Compiler latest versions Post by: leosedf on January 15, 2012, 09:35:34 21:35 Can someone help me get the Hi-Tech compiler running in Flowcode PIC version? I was wondering that too, is there any option to use hitech with flowcode?Title: Re: Hi-Tech PIC Compiler latest versions Post by: shila on February 18, 2012, 10:19:37 10:19 Hi ,
i'm in trouble. The command : >Picc --ver sais : c:\Programmi\HI-TECH Software\PICC\9.83\bin>picc --ver HI-TECH C Compiler for PIC10/12/16 MCUs (PRO Mode) V9.83 Copyright (C) 2011 Microchip Technology Inc. Serial number: HCPICP-171073 (PRO) but when i build a project it sais: HI-TECH C Compiler for PIC10/12/16 MCUs (Lite Mode) V9.83 Copyright (C) 2011 Microchip Technology Inc. Serial number: HCPICP-171073 (PRO) please help me. Thanks Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on February 18, 2012, 11:09:19 11:09 but when i build a project it sais: HI-TECH C Compiler for PIC10/12/16 MCUs (Lite Mode) V9.83 Copyright (C) 2011 Microchip Technology Inc. Serial number: HCPICP-171073 (PRO) 1. Uninstall. 2. Run CLEAN.BAT. 3. Re-install. 4. Run HI-TECH Universal RSA Keygen. Title: Re: Hi-Tech PIC Compiler latest versions Post by: Sideshow Bob on February 18, 2012, 11:22:53 11:22 I get the same then running the compiler in lite mode from MPLAB. In MPLAB select (toolbar) project->buil options->peoject Then select the compiler tab and set operation mode to pro or whatever you feel you can handle ;)
Title: Re: Hi-Tech PIC Compiler latest versions Post by: shila on February 18, 2012, 01:13:00 13:13 Perfect!
Just as Sideshow Bob said. Now it work in pro mode: HI-TECH C Compiler for PIC10/12/16 MCUs (PRO Mode) V9.83 Copyright (C) 2011 Microchip Technology Inc. Serial number: HCPICP-171073 (PRO) Title: Re: Hi-Tech PIC Compiler latest versions Post by: shila on February 18, 2012, 05:21:48 17:21 Hi,
which is a valid alternative to "mplab ide" as Ide to program with Htsoft. Mplab X is too heavy , and Mplab Ide 8 is too skinny. I mean an ide with compiler option and auto indent etc. Thanks Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on February 19, 2012, 06:22:41 06:22 I use Visual Studio.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: metal on February 19, 2012, 07:09:23 07:09 how do you configure it, explain to us plz.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on February 19, 2012, 07:31:31 07:31 Create a file called project.cmd(name is not important);
Code: --CHIP=18F4431 Configure PIC used: Code: --CHIP=18F4431 Configure messages to be understood by Visual Studio and to be displayed in standard output. Code: --ERRFORMAT="%f(%l) : error %n: %s" Compile optimize for speed: Code: --OPT=speed In output display total time it took for compiling the project Code: --TIME Warning level Code: --WARN=-9 Forgot these, but can be found on user manual of compiler Code: --ASMLIST This will output files compatible with MPLAB and PROTEUS. Useful for simulation. Code: --IDE=MPLAB Stop compilation after this number of errors: Code: --ERRORS=10 --CALLGRAPH=full --ECHO Output MAP file: Code: -Mproject.map This one tells compiler the maximum identifier length: For example if you have a function called MyFunc(),this one has identifier length of 6 (1M 2y 3F 4u 5n 6c) Code: -N100 Global defines: These are similar to: #define OSC 40000000UL #define GLOBAL_DEBUG 1 #define VERSION_NUMBER 800 Code: -DFOSC=40000000UL Output HEX: Code: -O"Debug\project.hex" Object files output folder: Code: --OBJDIR="obj\slave\debug\8_0_0" Include folders(as you can see,these can be relative paths): Code: -I"..\..\..\source\drv\PIC18F4431" These are project c files: Code: ..\..\..\source\app\2009\adv\slave\AppBrake.c After you configure this file you should tell VS: PICC18.exe @project.cmd This line you should provide it in configuration of your VS project. Sadly on this PC I don't have VS installed to show you a screenshot, but I'msure you will find your way. If there still is interest I'll provide it tomorrow. Have fun! Title: Re: Hi-Tech PIC Compiler latest versions Post by: allunderthesun on March 20, 2012, 01:03:41 01:03 looking for the OSX version. the link is dead?
Title: Re: Hi-Tech PIC Compiler latest versions Post by: allunderthesun on March 20, 2012, 02:36:01 02:36 Can I use the windows version and copy the key to OSX? is it possible?
Title: Re: Hi-Tech PIC Compiler latest versions Post by: robban on March 20, 2012, 03:02:56 03:02 With the risc of getting warned; Let's face it, MPLABX is a mess, and they use us as ginny pigs. I never use it as a default IDE, only when I try to import an already fine .mcp file. Even my MPLAB ICD3 protest when I try to import a project.
The only thing that's working alright is the driver switch, but on the other hand, who needs another switch? Me? Microchip? Title: Re: Hi-Tech PIC Compiler latest versions Post by: danielausparis on May 05, 2012, 12:43:57 12:43 First impressions about Hi-Tech PICC on Archlinux: - installation is smooth as per forum instructions. It has to be made very clear that a working eth0 connection is mandatory for the key management process. - it has to be noted that the dynamically-linked keygen refers to ssl libraries that are quite "old" in Archlinux terms (being a rolling release distribution, it features always latest packages compared to other distros). Workaround: cheat by creating symbolic links from the actual ssl libraries to the libraries asked for by the keygen program. It works, although with a warning. A long term solution would be a source release of the keygen, or a statically linked one. The PICC package, even once installed and validated PRO with the keygen, runs in PRO mode only as long as a working eth0 is available. If not, it reverts to LITE mode (and back). This might be surprising for laptop users. I did a small benchmark of PICC against CC5X (full optimizing version available elsewhere in this forum). I was surprised to find out that CC5X produces about 20% smaller code. The next step will be to deploy the PIC18 version of the compiler. Title: Re: Hi-Tech PIC Compiler latest versions Post by: SpaleKG on October 07, 2012, 10:14:56 22:14 looking for the OSX version. the link is dead? This is RSA key generator, but you need to use some HEX editor and change/replace RSA keys from executables with generated ones. http://turbobit.net/7imhp5fv8el5.html EDIT: This is very strange on MacOSX. In terminal when I check version it said: spale@macpro:/Applications/HI-TECH/picc-18/9.80/bin$ ./picc18 --ver HI-TECH C Compiler for PIC18 MCUs (PRO Mode) V9.80 Copyright (C) 2011 Microchip Technology Inc. Serial number: HCPIC18P-720066 (PRO) In MPLABX when I select toolchain it said: (http://public.gs4trdemo.net/toolchain.png) But when compile in MPLABX then I receive this: (http://public.gs4trdemo.net/output.png) Does this seems that MPLABX have original Microchip RSA keys in binaries ? Or how to fix this issue? Title: Re: Hi-Tech PIC Compiler latest versions Post by: SpaleKG on October 16, 2012, 08:48:08 08:48 Forget about the tar.gz and run files, I have it installed and have the 'whole filesystem tree'. I'll try and explain again :) It looks like the Linux ELF executable files, activate and picc are now packed or protected with something and I am having trouble running them in a debugger. If you try to load activate into a disassembler you'll see what I mean. I don't know anything about unpacking Linux ELF executable files but if you can unpack them then a patch will be simple. At this moment UPX packer for executables is the only one for Linux platforms. Try to unpack binary with UPX. Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on October 16, 2012, 02:00:40 14:00 Does this seems that MPLABX have original Microchip RSA keys in binaries ? Or how to fix this issue? I think I remember seeing a setting somewhere in the IDE that allows you to switch between different versions of the compiler. I guess you have it set to Lite mode so look for this switch and set it to PRO mode and you should be okay. At this moment UPX packer for executables is the only one for Linux platforms. Try to unpack binary with UPX. Seems like you missed my later post saying "Please disregard my last few posts about the Linux ELF files being packed/protected. Somehow the v9.81 download got corrupted and it made things look wierd in IDA." Title: Re: Hi-Tech PIC Compiler latest versions Post by: SpaleKG on October 16, 2012, 07:33:38 19:33 I think I remember seeing a setting somewhere in the IDE that allows you to switch between different versions of the compiler. I guess you have it set to Lite mode so look for this switch and set it to PRO mode and you should be okay. In MPLABX IDE I can click on search and IDE adding all toolchains which are founded to be installed (also can be manually added but that is always about path to bin/ folder). So everywhere it said PRO but when compile/build it mentioning Lite mode colored by red in Output window. However I cant find anything in whole IDE about selecting/switching between Lite/PRO mode. If anyone have this issues on MPLABX with HI-TECH compilers, and find solution, please share. Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on October 16, 2012, 08:07:47 20:07 However I cant find anything in whole IDE about selecting/switching between Lite/PRO mode. If anyone have this issues on MPLABX with HI-TECH compilers, and find solution, please share. You need to look a little harder :) Title: Re: Hi-Tech PIC Compiler latest versions Post by: Okada on January 20, 2013, 05:05:11 17:05 Hi Top
I have a problem using Hi Tech Compilers latest version registered with v2.3 RSA Keygen. See the attached image. If I select Pre Process assembler and Assembler check boxes and Compile I get wrong hex files which doesn't work properly. It is the same with all Hi Tech C compilers. Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on January 20, 2013, 10:58:58 22:58 Please provide a complete project that highlights the problem.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: Okada on January 21, 2013, 03:18:41 03:18 I have attached the project file which creates wrong hex files when Preprocess assembler and Assembler is checked before compiling. See the comment in the .rar file.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on January 21, 2013, 09:04:42 09:04 That code is working; please send the code that is not working.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: Okada on January 21, 2013, 09:18:24 09:18 good hex
http://uppit.com/3q9shep1egc9/uart1_good_hex.rar wrong hex http://uppit.com/2s3abzydzc36/uart1_wrong_hex.rar Title: Re: Hi-Tech PIC Compiler latest versions Post by: Top on January 21, 2013, 10:21:46 10:21 Check the listings for your delay_lcd() function; the 'wrong hex' optimization settings have made it shorter so your ENABLE pulse is too fast for your display. Solution: Change your delay_lcd() function.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: wolfienuke on January 20, 2014, 02:58:53 02:58 Just for any other Mac users (I know there are a few out there) having issues with HT_Keygen, I compiled a quick binary patcher to apply the generated RSA key to any file that contains the old RSA key. This should work for any HI-Tech compilers that HT_Keygen supports. I decided to do this on a whim, when I found myself doing way too many find and replace searches manually.
This does a simple binary find and replace, and only does simple cursory checks to ensure that the RSA keys look valid. I can post the source if anyone is interested, and I would definitely incorporate HT_Keygen if I could find the source for it. Executable is compiled for Mac OS 10.6+ Universal, but I only tested on 10.9. Instructions: Download and unzip posted file. Run "chmod +x" on executable if required Run "./HI-TECH_Hacktivate /path/to/old/activate.dat /path/to/new/activate.dat /path/to/bin/folder/" Title: Re: Hi-Tech PIC Compiler latest versions Post by: wolfienuke on February 27, 2014, 10:19:15 22:19 A couple people have asked me to explain how to use the program I posted above...
1. Install the Hi-Tech compiler you wish to install. Take note of the install path and the serial number. 2. Open Terminal. 3. Run "HT_Keygen" and provide the serial number. This provides a new RSA encryption key. 4. Run "./HI-TECH_Hacktivate /path/to/old/activate.dat /path/to/new/activate.dat /path/to/bin/folder/". This performs a patch on all binary files to replace the old RSA key with the new one. 5. Replace activate.dat and keyfile.dat in bin folder with the ones created by HT_Keygen. 6. Change the current directory to the bin folder. Run "cd $/path/to/bin/folder/". 7. Run "activate --keyfile=keyfile.dat --serial=$YOUR_SERIAL_NUMBER" 8. Run "picc --ver" (or whichever pic compiler you are using). It should say "Pro" if you performed the above tasks correctly. This works on all versions. Title: Re: Hi-Tech PIC Compiler latest versions Post by: Unhappy on March 21, 2014, 09:23:21 21:23 @ Top
Kindly update the RSA keygen 2.3 download link Title: Re: Hi-Tech PIC Compiler latest versions Post by: pickit2 on March 21, 2014, 09:29:37 21:29 @ Top Link in sticky is still working. Kindly update the RSA keygen 2.3 download link Title: Re: Hi-Tech PIC Compiler latest versions Post by: Unhappy on March 21, 2014, 10:13:58 22:13 Link in sticky is still working. Maybe it is not working in my country, anyway shall try again in the morning, If someone can still provide other D/L will be appreciatedTitle: Re: Hi-Tech PIC Compiler latest versions Post by: pickit2 on March 21, 2014, 11:14:06 23:14 RSA keygen 2.3 http://ul.to/xgyr5mbn
Title: Re: Hi-Tech PIC Compiler latest versions Post by: ceedjay on August 24, 2014, 09:18:52 09:18 Im trying to find a working link to the linux keygen but all links i have found so far are dead. Does anyone know where i can download the linux keygen 1.0 or newer?
Title: Re: Hi-Tech PIC Compiler latest versions Post by: folkeu on January 13, 2018, 05:04:00 17:04 Hi,
Where can I find the last HI-TECH C Compiler to download ? Thanks Title: Re: Hi-Tech PIC Compiler latest versions Post by: mitsos on January 13, 2018, 05:07:58 17:07 Title: Re: Hi-Tech PIC Compiler latest versions Post by: Marcustv on June 16, 2019, 06:25:19 18:25 The link no work Can you reupload ? Title: Re: Hi-Tech PIC Compiler latest versions Post by: giappolo on June 16, 2019, 06:47:11 18:47 Link is working,
delete "http://" from address Title: Re: Hi-Tech PIC Compiler latest versions Post by: CHJAY on June 17, 2019, 07:24:46 07:24 This link used to work, but now this link is redirected to "ftp://ftp.microchip.com/" and there is no HITECH compilers on this site.
It seems like ID & PASSWORD is expired. Go to HI-TEC archive page, and enter your ID and PASSWORD. If you don't have one, create a new one. https://www.microchip.com/development-tools/pic-and-dspic-downloads-archive Title: Re: Hi-Tech PIC Compiler latest versions Post by: tavioman on June 17, 2019, 08:42:21 08:42 The link no work Can you reupload ? The link works just fine. Title: Re: Hi-Tech PIC Compiler latest versions Post by: Magnox on June 17, 2019, 01:27:17 13:27 lol - the link works. But... copy it manually (highlight it all and click Copy, not Copy Link). Them remove the http part. Copying the link with Copy Link Location confuses the browser.
Title: Re: Hi-Tech PIC Compiler latest versions Post by: ron on June 26, 2020, 08:35:27 08:35 The link works just fine. The reason for the confusion is because if you login from some countries like India it shows you only two folders with no real files. It does not matter what password you use. Or what link format. The solution is to use a VPN. I was finally able to get in using the Opera Browser and an American VPN. Using the same Userid and password and link provided. I can confirm the user id and password still work. As does the link. Just some countries have been blocked. And re-directed to a dummy folder. Title: Hi-Tech PIC Compiler latest versions Windows/Linux Post by: zelea2 on June 14, 2021, 07:23:06 19:23 This is a re-release of the latest version HiTechC Optimizing Compilers.
They have been discontinued after the company acquisition by Microchip. I think they are still relevant today especially with a makefile and they don't come bloated with the MPLAB X IDE. The remote activation is not possible anymore because the servers for this have been long gone. I've re-written the HiTechC-Activate program which replaces the RSA key-pair and does the activation completely offline. The installer will automatically patch and activate the compiler which will be ready to use with all the optimizations enabled straight away. Title: Re: Hi-Tech PIC Compiler latest versions Post by: danymogh on June 15, 2021, 05:05:57 05:05 This is a re-release of the latest version HiTechC Optimizing Compilers. They have been discontinued after the company acquisition by Microchip. I think they are still relevant today especially with a makefile and they don't come bloated with the MPLAB X IDE. The remote activation is not possible anymore because the servers for this have been long gone. I've re-written the HiTechC-Activate program which replaces the RSA key-pair and does the activation completely offline. The installer will automatically patch and activate the compiler which will be ready to use with all the optimizations enabled straight away. what is the advantage to the alread released RSA keygen v2.3? that one also activates it offline. Title: Re: Hi-Tech PIC Compiler latest versions Post by: zelea2 on June 15, 2021, 05:50:21 05:50 what is the advantage to the alread released RSA keygen v2.3? that one also activates it offline. I don't know about that particular version, but the one that I had required servers and a complicatedactivation, so I've written my own which does everything automatically. Title: Re: Hi-Tech PIC Compiler latest versions Post by: Thiru09 on June 15, 2021, 01:25:41 13:25 danymogh is referring to the great work of TOP, details are in sticky post.
No matter what, your work is good and keep it up. Regards, Thiru |
